Topic: FFMPEG Command Line (Read 2197 times) previous topic - next topic
FFMPEG Command Line
I am trying to write a batch file to normalize the audio portion of some AVI files. I'm more or less finished, but am have a little difficulty with a couple of the specifics.
I am using this command line to create a temporary audio file:
ffmpeg -i filename.avi -vn -acodec copy -y tempaudio.mp3
I am looking to have the file have a specific Bitrate (128 Kbps) and Sample Rate (48000 Hz). What adjustments would I have to make to the above to achieve this?
Thanks in advance,
John
FFMPEG Command Line
You need to reencode the audio stream. Try:
ffmpeg -i filename.avi -vn -sn -acodec libmp3lame -ab 128k -ar 48k -y tempaudio.mp3
FFMPEG Command Line
That did it. Thanks.
