Topic: playlist_manager / main_thread_callback (Read 2257 times) previous topic - next topic
I just want to make sure I understand this and I'm not missing something.
As far as I can tell, there is no way to call functions in playlist_manager that returns a value, either as an "out" parameter or a return type, from a worker thread. main_thread_callback can be used for functions that do not return a value, but I can't find a mechanism to call functions that return a value and that need to be called on the main thread from a worker thread.
When you implement main_thread_callback, add some additional state to the object like a future, or if you lack those, an event and a place where the data needs to be.
struct task : main_thread_callback
  future<T> value;
  some_state state;
  virtual void on_run()
    value = static_api_t<playlist_manager>->get_somesuch(state.foo, state.bar);
  service_ptr_t<task> my_task(new service_impl_t<task>());
  my_task.state = ...;
  static_api_t<mtc_whatever>->enqueue(my_task);
  auto T = my_task.value.get();
TL;DR -- you can put arbitrary state in your main_thread_callback implementation.
See my generic in_main_thread function for foo_wave_seekbar to see how one may do something similiar.
Stay sane, exile.
Thanks very much for the tip zao, and especially for the source code.
I think your "function object" solution makes perfect sense. As long as the main_thread_callback_manager queues them and processes them in order I think I can use main_thread_callback_manager with your "function object" solution.
Thanks again
PS. multiple edits on this post, hopefully I was talking to myself.
The intent of my example is that you dispatch a task to the main_thread machinery, and then you block, waiting for the result.
If you want to do something asynchronous, you can instead have the main_thread_callback raise some kind of event, or post a callback
back to a similar machinery for your workers.
If you do that, I suggest bundling some uniquely identifying information with the callback, so you can determine what request a delayed response belongs to.
Stay sane, exile.
