Topic: Bad Sample, Bad Test, or Good Ears (Read 4803 times) previous topic - next topic
Recently, I have been ABXing my music with foobar2000 to decide on the format and bitrate to use on my phone. Most of my results seem unsurprising, but one group's music seems to compress quite poorly. I have included a sample where I seem to be able to ABX on qaac -V 127 and lame V0. Nero AAC Q1.0 came out a bit better, though it also produced the highest bitrate at 404 Kbps. I seriously doubt this is my ears, so I was wondering if this is just a really hard sample or if I might be screwing up my tests. I noticed that the original has quite a bit of clipping. Could this make it more difficult to compress transparently?
Results and Samples: http://www.hydrogenaudio.org/forums/index....howtopic=100450
If the original is clipping, you may want to apply replaygain (or just reduce the peak level a couple dB manually) before encoding to make sure it doesn't clip even worse after transcoding to lossy.
I think you are right. I did a quick test with the original with qaac -V 91 both before and after reducing it by 3 dB in Audacity. I went from 20/20 to 9/20.
Original:
foo_abx 1.3.4 report
foobar2000 v1.2.4
2013/04/17 17:03:08
File A: E:\abx\original.flac
File B: E:\abx\qtaac-tvbr91.m4a
17:03:08 : Test started.
17:03:17 : 01/01  50.0%
17:03:28 : 02/02  25.0%
17:03:35 : 03/03  12.5%
17:03:42 : 04/04  6.3%
17:03:52 : 05/05  3.1%
17:03:57 : 06/06  1.6%
17:04:04 : 07/07  0.8%
17:04:09 : 08/08  0.4%
17:04:15 : 09/09  0.2%
17:04:23 : 10/10  0.1%
17:04:29 : 11/11  0.0%
17:04:35 : 12/12  0.0%
17:04:42 : 13/13  0.0%
17:04:48 : 14/14  0.0%
17:04:54 : 15/15  0.0%
17:04:59 : 16/16  0.0%
17:05:03 : 17/17  0.0%
17:05:10 : 18/18  0.0%
17:05:16 : 19/19  0.0%
17:05:22 : 20/20  0.0%
17:05:33 : Test finished.
Total: 20/20 (0.0%)
Original -3dB:
foobar2000 v1.2.4
2013/04/17 17:05:48
File A: E:\abx\original-alt.flac
File B: E:\abx\qtaac-tvbr91-alt.m4a
17:05:48 : Test started.
17:06:01 : 01/01  50.0%
17:06:09 : 01/02  75.0%
17:06:19 : 01/03  87.5%
17:06:33 : 01/04  93.8%
17:06:45 : 02/05  81.3%
17:06:55 : 02/06  89.1%
17:07:04 : 02/07  93.8%
17:07:13 : 03/08  85.5%
17:07:19 : 04/09  74.6%
17:07:30 : 04/10  82.8%
17:07:38 : 04/11  88.7%
17:07:56 : 05/12  80.6%
17:08:09 : 05/13  86.7%
17:08:27 : 06/14  78.8%
17:08:41 : 06/15  84.9%
17:08:50 : 06/16  89.5%
17:08:58 : 07/17  83.4%
17:09:09 : 08/18  76.0%
17:09:21 : 08/19  82.0%
17:09:33 : 09/20  74.8%
17:09:42 : 10/21  66.8%
17:09:49 : Test finished.
Total: 10/21 (66.8%)
