Topic: Coming from FLAC files to WavPack (Read 13299 times) previous topic - next topic
I have just recently gotten a Sansa Clip+ and put RockBox on it.  I have been running my FLAC files on the device and have switched to WavPack.  While I love the lossless quality, I would like to get more content on my 32GB sd card.  I'm considering moving to high bitrate lossy WavPack.  I have a fairly discerning ear, so I'm not certain this is even a good idea.  I'd appreciate advice from anyone who has performed a similar process.  Is the lossy format transparent?  Does the soundstage suffer much?
I'm thinking about using the -b400fx3 switch after playing with them a bit.
Only you can test that. Do some ABXing and find out.
If you're going for lossy instead of lossless anyway, it would make more sense to use the codecs which are made for this purpose from the beginning. Vorbis and AAC (not Nero or FAAC!) should be the best there, so I guess you should give these at least a try.
I went with wavpack hybrid to not have to keep two collections of the files. On my pc I have the .wv + .wvc, on my clip+ only the .wv
Went with 385kpbs  for the lossy part because it somehow made the combined size smaller. Probably because less has to be corrected at higher bitrate.
You could try running the battery bench with wavpack vs. other codecs. For my clip I had a 10 minute longer runtime than flac, but I didn't test the other lossy format because having to convert the music every time I want to add music to my player is too much of a hassle for me.
Are you saying that because they were designed for lossy they have psychoacoustic models already? Or do you recommend for some other reason?
Yes, modern lossy codecs are not intended to give any bit-perfect output, but to "fool" your ears with more or less complex psymodels. Lossy WavPack for sure has some kind of psymodel too, but not as advanced. There's actually no reason in your situation to use anything different but Mp3, AAC, etc.: They will give you better quality, while also being far more supported. You could start with Lame or the AAC encoder from Winamp/Itunes at 192 kb/s and ABX (a program for blind testing) it against WavPack at similar bitrates.
If you haven't already, please read this prerequisite:
http://www.hydrogenaudio.org/forums/index....showtopic=16295
There is no point in proceeding with the discussion until this has been satisfied.
The lossy mode is definitely transparent. I find 300k to be perfect quality on normal music while 350k (-b350x5) yields excellent quality for even the most demanding stuff.
wavpack 4.8 -b256hx6c
Is there any incentive to waste about 160-200 kbps by not using a modern MP3 or AAC encoder?
I guess if one does not want multiple collections or transcoding there is yet another option in the encoding world. I think a traditional encoder @ 150..200 yields excellent if not transparent quality in most cases . If one can be happy with with a single mp3 library there is an advantage with universal playback and small files, However many here are managing multiple libraries and that somewhat the advantage of non-mp3/aac formats.
I did some ABX testing and took Gainless' advice to try a codec specifically created for high quality lossy encoding.  I compared WavPack lossless to Ogg q 10.  The test results tell me that I really can't tell the difference.  I realize now that I should have run both tests in a row, but it doesn't detract from the idea that I just don't know the difference, especially when you consider that on test 1 I may have gotten it correct but I thought the Ogg sounded better.
foo_abx 1.3.4 report
foobar2000 v1.2.4
2013/04/12 08:08:26
File A: C:\Users\...\Desktop\03-Holy.ogg
File B: C:\Users\...\Desktop\03-Holy.wv
08:08:26 : Test started.
08:11:19 : 01/01  50.0%
08:12:10 : Test finished.
Total: 1/1 (50.0%)
foobar2000 v1.2.4
2013/04/12 08:12:59
File A: C:\Users\...\Desktop\03-Quake.ogg
File B: C:\Users\...\Desktop\03-Quake.wv
08:12:59 : Test started.
08:17:34 : 00/01  100.0%
08:17:54 : Test finished.
Total: 0/1 (100.0%)
You misunderstand the purpose of the test. It is not to decide which sounds better, but whether or not something is indistinguishable from the original.
In this case the WavPack lossles IS the original, and the test is whether or not the ogg sounds different. Whether you thought the ogg sounded better or worse is immaterial, as long as you could tell that it sounded different.
FWIW, it is highly unlikely that you could tell an ogg q 10 from the original.
Agreed, I do not feel I can tell the difference.  I only mentioned that I thought the ogg file "sounded better" is just further evidence to support that any differences were merely perceived and not actual.
Placebo effect in action. Did you read the link I gave?  It essentially tells you to do anything but run tests with a single trial.
If your interest is the preservation of soundstage, you should really begin testing at 80kbits and the work your way up until you find something that satisfies your needs.  Even with the most discerning ears, other problems appear long before soundstage is compromised.
Regarding multiple collections, what is the difference between having lossy + lossless and lossy + correction?  You have two sets of files either way.
Again, I think time should be spent ensuring the OP understands how to judge performance of lossy encoding before being complicit in reinforcing the notion that he "needs" to use a grossly inefficient format. This is especially the case when there was an expressed desire to fit more music on a portable.
If your interest is the preservation of soundstage, you should really begin testing at 80kbits and the work your way up until you find something that satisfies your need.  Even with the most discerning ears, other other problems appear long before soundstage is compromised.
Thank you, I plan on doing a better analysis next time especially considering your soundstage advice.  Will post results if interested.
Yes, but you only have one set of metadata complete with covers, replaygain, custom tags etc. When transcoding from foobar, it doesn't preserve replay gain tags or cover (or I don't know how), so I have to go back and re-tag the files after conversion. With wv+wvc I just copy the wv and I'm done.
Not to mention pure lossy (say mp3) + lossless (say wv) uses more space than wv+wvc
That sounds like a problem with your choice in file management software.
For use on a portable?
Taking this comment generally, surely you aren't taking Kohlrabi's point into account. Are you prepared to back this up with data that includes double-blind listening tests?
You're more than welcome to suggest me a (free) conversion software that does keep all the tags *shrug*
As for the size part, I'm not sure what you mean. Having two separate collections would mean you have, for example
- one wv of a song, 16,6 MB
- one mp3 of a song, 4,52 MB
This totals in ~21MB size
Having the same in wv+wvc would result in
- one wv of a song, ~4,6Mb
- one wvc of a song, ~12MB
totalling in ~17MB MB size. That's 4Mb more space per song, and I have a big music library.
I don't particularly care about "hdd space being cheap", I don't have the money to afford more anyway.
ABXing would not change the fact that keeping both the lossless and the lossy results in higher space usage, while wavpack hybrid has both lossy and lossless in one package at nearly the same size as the lossless alone. Thus lossy, no matter at which bitrate  is a +alpha on space usage.
Of course going pure lossy would give you much better space efficiency, because the transparency can be reached with much lower bitrate than going pure lossless. The reason I go hybrid is not because I am claiming to hear the difference between lossless and lossy (which I don't), but because of space and metadata reasons. When on my PC I am using my ripped lossless archive, when I'm on my portable devices, I use the lossy part.
I didn't recall the correction file being smaller than the lossless file by about the size of the lossy file.
Thanks for pointing out what I really should have investigated prior to posting.
The size of the correction file depends on how low you go on the lossy bitrate (since it has to correct more for a low bitrate lossy). I experimented with the bitrates and at 385kbps the wv+wvc results in files that are around the size or smaller than flaCL -11, while going down on the bitrate (~250) would result in wv+wvc being larger than flaCL -11, so I put that as my "sweet spot" since I didn't want my library to grow.
I found the same sweet spot. I go with -b 384.  Does it make any difference that 384 is evenly divisible by 8 and 385 isn't, given that wavpack doesn't use floats in it math?
(if this is question that makes me look hebetudinous, i apologize in advance :") )
Music lover and recovering high end audiophile
This time I ran an ABX on FLAC vs. OGG (q6).  It appears that I could tell a difference, but got fooled a couple times.  Apparently there was a 22.7% chance I guessed on them all.
foobar2000 v1.1.6
2013/04/13 11:52:02
File A: C:\Users\...\Desktop\12-The Menzingers-I Can't Seem To Tell.flac
File B: C:\Users\...\Desktop\12-The Menzingers-I Can't Seem To Tell.ogg
11:52:02 : Test started.
11:54:41 : 01/01  50.0%
11:56:19 : 01/02  75.0%
11:57:44 : 02/03  50.0%
11:59:55 : 03/04  31.3%
12:00:12 : 04/05  18.8%
12:01:36 : 04/06  34.4%
12:04:12 : 05/07  22.7%
12:04:12 : Test finished.
Total: 5/7 (22.7%)
Whereas FLAC vs. OGG Q8 had me completely fooled.  I think I found my bitrate.  Thanks guys!
foobar2000 v1.1.6
2013/04/13 12:13:39
File A: D:\Clip+\OGG-8\Alkaline Trio-This Addiction-2010\12-Kick Rocks.ogg
File B: D:\FLAC\#-D\Alkaline Trio\2010-This Addiction\12-Alkaline Trio-Kick Rocks.flac
12:13:39 : Test started.
12:14:19 : 01/01  50.0%
12:15:57 : 02/02  25.0%
12:17:02 : 02/03  50.0%
12:18:24 : 02/04  68.8%
12:18:41 : 02/05  81.3%
12:19:40 : 02/06  89.1%
12:20:03 : 02/07  93.8%
12:20:59 : 02/08  96.5%
12:21:00 : Test finished.
Total: 2/8 (96.5%)
foobar2000 v1.1.6
2013/04/13 11:52:02
Total: 5/7 (22.7%)
You'd want to (at least!) achieve 5% confidence to have a conclusive result. With your result the 7 trials are not enough to be conclusive.
Fooled, or happen to guess incorrectly?  That first log does not show a distinction.
Do at least 12 trials and do not have the results revealed until the test is finished.
[on synchronizing tagsets]
Hm? Any hint to share?
