Topic: ICC (Read 11989 times) previous topic - next topic
ICC
Don't do too much work with it, though.  I'll be putting out a new version with some new interface features sometime today.
I hope that includes things like
play_focused
and some access to the things you are doing with your keyboard shortcut support, etc.
ICC
The playlist_oper "gets" seem to work from my component but not the "sets".
ICC
That's really odd that you're unable to set the focused item.  What exactly is it doing?  It is defocusing the currently selected, or just taking no action at all?  But I can't control what the playlist_oper does.  I'm only caching a reference to speed up searches.
Things like play_focused are done through the play_control and playlist_oper classes, so I won't be duplicating that functionality.
Most of the new functionality I'm adding is to allow searching of lists other than the playlist, and to have more control over exactly how they are searched.  I've also added code to show and close the search window, but there's no code to control the window.  It's just like pressing the hotkeys.
ICC
It simply does nothing.  The focus isn't changed at all.
I'll keep messing around with it.
ICC
Damn you.    I was going to tell you that you must have unzipped over the old one so it's still there, but it was my fault.  I forgot to remove the old one from the zip.
P.S.  Gone now.  No other changes, though.  You can just delete it from the folder.
ICC
Reply #32
I included the new playlist_find.h and made no other changes but now I alwasy get -1 for the search result.
Still just calling
      int findPos = global_playlist_find::get()->search(m_Hot[Title1].GetText(),g_play_oper->get_focus());
      g_play_oper->set_focus_sel(findPos);
is there any other setup or did the search() semantics change?
ICC
The search semantics actually did change a little (start_index is now included in the search, whereas it was previously not included), but that doesn't explain why you're getting -1 as the result every time.  By sending the selected item, it should (likely) just be returning it every time.
int findPos = global_playlist_find::get()->search(m_Hot[Title1].GetText()); // you can drop the g_play_oper->get_focus()
edit:
Can you post an example of what m_Hot[Title1].GetText() returns, along with your playlist formatting string, your playlistfind string, and any other data you think might be important.  (If you've got "match only beginning" enabled, etc.)
ICC
Reply #34
edit:
I got it working again.  Here's how if you want to try to see what happened.
I delete playlistfind, ran foobar which cleaned out the config, reinstalled.
I think that just coping this most recent version over the one I had from this morning or yesterday, whenever it was caused some config problems.
EDIT
Actually, I can't get playlist_find to work reliably after I close foobar and restart.  Removing it, running foobar, the reinstalling seems to clear it up for the first run.  This is just via the supplied UI not from my component calling via the service ptr.
Hum, I can't reproduce that reliably either.  I have seen it not work from my code and from the default UI.  But its working now...
I should call it a night while I'm ahead.
/EDIT
now, still can't set the focused item.
I was wondering, would you consider from a design standpoint and as a test to include the focus setting in playlist find.
So something like
search(const char*, int index, bool wrap, bool updatefocus);
I'm wondering if this would work for me.  I have everythign in place to use playlist find except that I can't figure out why the focus stuff won't work from my message loop. (I still think foobar is locking me out somehow).
Also question.
You say don't derive from your playlist class yet the interface declares the methods as virtual and the class is preceded by NOVTABLE.
Just wondering about that one.
ICC
Reply #35
I'm not really understanding the problems you're having.  I'm not having any trouble getting playlistfind to work after restarting foobar.  :\
Also, if your code can't set the currently focused item as a result of threading issues, mine won't be able to either, because it'll be getting called from your thread.  It will run under your thread, not the main thread.
So search(const char*, int index, bool wrap, bool updatefocus); would be functionally identical to search(const char*, int index, bool wrap); followed by a call to playlist_oper::get()->set_focus_sel().
If you can work your code problems down into a small sample, I might be able to take a look at it.  I don't know if I'll be able to tell you anything, though.
As for not deriving from the interface, that message is for you ("you" meaning all other developers).  If you derive from the interface, you will cause problems.  There should be exactly one derivation of the interface, and my plugin provides it.
ICC
Reply #36
Here's the source of some of your problems:
from play_control.h:
//important: you should call api commands declared in this header ONLY from main thread !!
I've got no clue how you can work around that, but then, I don't know the internal structure of wsgui, so I've got no clue why you're even using separate threads.
ICC
Reply #37
Well, that explains a lot.  This is my first attempt at using WTL (Windows Template Library) and I was under the mistaken impression that I needed something like this to drive my window.
    MSG msg;
    while (sRunning && GetMessage ( &msg, NULL, 0, 0 ) > 0 )
 TranslateMessage ( &msg );
 DispatchMessage ( &msg );
The only way to do that was with a thread and I was creating a thread to run that.
The above is not needed at all - I didn't realize how the message loop worked in general I guess.  My window still gets messages without the above and this happens in the context of the "main thread".
So, I removed the threaded message pump and voila I can set the focused item
Now I'm still having problems with playlist_find not working but I can focus on that now and try to get you some better information.
One thing I noticed is when it stops working I get access violations in foobar every time I type a key in the playlist_find edit box.
First-chance exception in foobar2000.exe: 0xC0000005: Access Violation.
I also noticed I get
metadb_handle leaks, 22 objects
when I close foobar if I have run playlist_find but not if I haven't run playlist_find.  I have 22 items in my playlist.
This might be related to
    bool do_matching(const char * str, int playlist_index) {
 static string8 out;
 out.reset();
 if (search_list)
     search_list->get_item(playlist_index)->handle_format_title(out,get_search_format(),NULL);
 else
     g_oper->get_item(playlist_index)->handle_format_title(out,get_search_format(),NULL);
but I'm not sure (ie. get_item returns a ref'ed handle? ).
ICC
Reply #38
OK, some progress but no explanations.  Everything seems to work but only in a release build.  If I run my component in the debugger playlist_find does not work.
In the release build it seems fine and working well  You can type a search directly into wsgui, it will pop up the foobar main window and set the focused item to the current playlist_find search hit.
I'll have to try another service and see if I have the same experience.
ICC
Reply #39
I'll look into it some more.
ICC
Reply #40
Hmm.  When I build playlistfind as a debug, I get some problems.  I'm trying to figure out what's going on.
ICC
Reply #41
If it would help I can post my working version of wsgui that support playlist find and you can debug playlist find when wsgui is generating the calls into the service.
ICC
Reply #42
BTW
I understand that I was just wondering why the methods were declared as virtual.  I'm just making sure I understand how the service set up works in case I ever want to make one.
ICC
Reply #43
Right now I don't need you to post your code.  I've got some other odd things I need to track down first.  Maybe later, though.
The interface methods must be declared as virtual, or it wouldn't be possible to override them in a subclass.
ICC
Reply #44
Oh, OK, I didn't see this part
class global_playlist_find_impl : public global_playlist_find
global_playlist_find is an abstract interface.  I missed that.
ICC
Reply #45
Playlist Find 0.6.b11.012
compiled: 2003.06.07
[0.6.b11.012]
Fixed:   Potential memory leak
Added:   Pass keystrokes to foobar toggle
Changed:
  Reorganized config slightly.  Disables invalid options properly.
Changed:
  Now clears the current selection if a matching entry is not found.
Fixed:   Wierd bug with the "global" search format.
http://gelaed.com/resources/cplusplus/foo_...laylistfind.zip
http://gelaed.com/resources/cplusplus/foo_...istfind-src.zip
danZ, try it now.  I had a couple of wierd bugs sneak in.  I'm not sure if your issues will be fixed or not, though.
ICC
Reply #46
[0.6.b11.012]
Changed:
Changed:
Works!  Debug and Release builds.
Care to share what was up?  No crashes when I do search_backwards either which I had in the last build.
Cool, thanks.
ICC
Reply #47
Well, I'll give you a hint.
this (the original, broken code):
playlist_find_impl()
    search_list = NULL;
    char * search_format = NULL;
    srch_type = SEARCH_DEFAULT;
is definitely not the same as this (the new, not so messed-up code):
    search_list = NULL;
I'm honestly not sure why it was working for me.
ICC
Reply #48
One thing - might be how I'm calling pfind but I think I did it the same as foo_playlistfind
If I type 2 chars past the last match.
So
b - match
be - match
bec - no match
beck - no match
then backspace to
bec
I get a crash when it calls search_backwards
Happens every time but I can't repro on your edit box.
The callstack is in foo_playlistfind.dll when the exception occurs.
      int findPos = -1;
     if (wasBack)
         findPos = global_playlist_find::get()->search_backwards(m_KeyFocus->GetText());
     else
         findPos = global_playlist_find::get()->search(m_KeyFocus->GetText());
     playlist_oper::get()->set_focus_sel(findPos);
wasBack is true when I'm processing VK_BACK key.
ideas?
EDIT
m_KeyFocus->GetText() just returns a const char* ptr to "bec"
and I if I only type one char past the last match then backspace no crash.
/EDIT
ICC
Reply #49
Well, the obvious question is whether "m_KeyFocus->GetText()" could be returning NULL.
Assuming that's not the case, then the problem is apparently in search_backwards().  I'll take a look at it.
I should mention, though, that search_backwards() probably isn't doing what you are expecting.  Search backwards searches from bottom to top, meaning that it should be finding the last entry when you are calling it, rather than the previously found entry.
