Topic: XLD - Difference between rip from cd and transcode from m4a (Read 6043 times) previous topic - next topic
Hi there
Short question:
Step 1: rip cd using iTunes to Apple Lossless format
Step 2: transcode m4a files to flac using XLD (accuraterip)
Step 3: rip same cd with XLD to flac (accuraterip)
Step 4: compare the log-files
The Log-Files are not the same, it seems that the transcode from the m4a Files are more accurate than the direct rips...
Can someone explain what's going on?
thanks in advance
Udo
Log-File from direct rip from cd:
AccurateRip Summary (DiscID: 0010c5ec-00898ba9-790b580a)
    Track 01 : NG (total 106 submissions)
    Track 02 : OK (v1+v2, confidence 102/112)
    Track 03 : OK (v1+v2, confidence 102/112)
    Track 04 : NG (total 112 submissions)
    Track 05 : NG (total 111 submissions)
    Track 06 : OK (v1+v2, confidence 101/111)
    Track 07 : OK (v1+v2, confidence 101/111)
    Track 08 : OK (v1+v2, confidence 99/109)
    Track 09 : NG (total 110 submissions)
    Track 10 : NG (total 109 submissions)
        ->5 tracks accurately ripped, 5 tracks not
Log-File Transcode from iTunes m4a transcode:
    Track 01 : OK (v1+v2, confidence 97/106, with different offset)
    Track 02 : OK (v1+v2, confidence 102/112, with different offset)
    Track 03 : OK (v1+v2, confidence 102/112, with different offset)
    Track 04 : OK (v1+v2, confidence 102/112, with different offset)
    Track 05 : OK (v1+v2, confidence 101/111, with different offset)
    Track 06 : OK (v1+v2, confidence 101/111, with different offset)
    Track 07 : OK (v1+v2, confidence 101/111, with different offset)
    Track 08 : OK (v1+v2, confidence 99/109, with different offset)
    Track 09 : OK (v1+v2, confidence 100/110, with different offset)
    Track 10 : OK (v1+v2, confidence 99/109, with different offset)
        ->All tracks accurately ripped.
iTunes doesn't support Read Offset, XLD probably does. iTunes doesn't support Write Offset. XLD probably doesn't either (the only one I found that does is EAC).
Have you ever played with these settings?
Search for Read Offset and Write Offset.
eahm, thanks for your reply. No, until now I have not changed this settings. Could the missing Write Offset in iTunes result in a less good result? I'm asking because ripping in iTunes and converting in XLD is much faster as a direct rip in XLD.
Read Offset changes the checksum when you rip and Write Offset changes it when you burn.
I can't say the result is less good, I remember many experts talking about offsets and saying that the audio stream is still the same even if the offset is set differently (reason why iTunes doesn't have an option to change it probably?).
A proper Read Offset means you will have an accurate rip. Rip software query AccurateRip to see if the Offset is set properly (even if AccurateRip itself is not completely accurate). Also ripping software usually calculate AccurateRip automatically.
A proper Write Offset means you could burn the disc and rerip it again and have the very exact copy of the previous rip and the original. Not calculated automatically, there are many tutorial of how to properly calculate it but you'll have to find one since I don't remember which one is the most comprehensive and precise.
Thanks again for your explanations. I think I understand a lot more now.
The offset difference doesn't explain the 5 bad tracks for the XLD rip. The good tracks match the confidence levels of the other rip for the same AccurateRip ID. The XLD rip log might be more helpful (to someone more familiar with that program) to diagnose what might be wrong with the rip method or settings than the AccurateRip results alone.
korth
Does it happen with that CD alone, which could be somewhat a little defective (and the iTunes is a one lucky shot) or is it a consistent behavior? Or maybe a defective reader. By the way, iTunes ripping and XLD burst mode should theorically be the same thing, at a device level (Edit: and so complete a rip at the same speed). Yes, do post the whole log.
... I live by long distance.
korth, yeah... we kept talking about it and I didn't even double check the first post.
Not sure when it was enabled but the current version of XLD for Mac (142.3) does support both Read and Write Offset, adjustable in the "CD Rip" and CD Burn" preferences.
I've made some more tests. In my environment the behavior is reproducible.
I used the same CD as in my first post and another one. The complete logs (from the first CD) are shown below. Thanks for any comments on this.
Rip from CD:
[font=Courier New]X Lossless Decoder version 20130127 (142.3)
XLD extraction logfile from 2013-04-07 12:51:12 +0200
Joe Jackson / Night Music
Used drive : HL-DT-ST DVDRW  GA32N (revision KC12)
Media type : Pressed CD
Ripper mode            : XLD Secure Ripper
Disable audio cache    : OK for the drive with a cache less than 1375KiB
Make use of C2 pointers : YES
Read offset correction  : 103
Max retry count        : 20
Gap status              : Analyzed, Appended (except HTOA)
TOC of the extracted CD
    Track |  Start  |  Length  | Start sector | End sector
        1  | 00:00:00 | 04:01:17 |        0    |    18091
        2  | 04:01:17 | 02:48:50 |    18092    |    30741
        3  | 06:49:67 | 04:42:40 |    30742    |    51931
        4  | 11:32:32 | 04:07:30 |    51932    |    70486
        5  | 15:39:62 | 05:18:30 |    70487    |    94366
        6  | 20:58:17 | 04:28:28 |    94367    |  114494
        7  | 25:26:45 | 06:20:17 |    114495    |  143011
        8  | 31:46:62 | 04:54:70 |    143012    |  165131
        9  | 36:41:57 | 06:13:68 |    165132    |  193174
      10  | 42:55:50 | 05:28:35 |    193175    |  217809
List of alternate offset correction values
        #  | Absolute | Relative | Confidence
        1  |  -101  |  -204  |    10
All Tracks
    Statistics
        Read error                          : 0
        Jitter error (maybe fixed)          : 7
        Retry sector count                  : 3841
        Damaged sector count                : 0
Track 01
    Filename : /Users/admin/Music/Lossless/Joe Jackson/ Night Music/ 01 Nocturne No.1.flac
    Pre-gap length : 00:02:00
    CRC32 hash              : 056CFA4C
    CRC32 hash (skip zero)  : CBB9E4AC
    AccurateRip v1 signature : 7B0D0DF6
    AccurateRip v2 signature : 2C8B9291
        ->Rip may not be accurate (total 106 submissions).
    Statistics
        Read error                          : 0
        Jitter error (maybe fixed)          : 1
        Retry sector count                  : 194
Track 02
    Filename : /Users/admin/Music/Lossless/Joe Jackson/ Night Music/ 02 Flying.flac
    Pre-gap length : 00:00:02
    CRC32 hash              : 809C88D5
    CRC32 hash (skip zero)  : C7D05CBD
    AccurateRip v1 signature : AD74D8A4
    AccurateRip v2 signature : D17B18BB
        ->Accurately ripped (v1+v2, confidence 92+10/112)
    Statistics
        Read error                          : 0
        Jitter error (maybe fixed)          : 0
        Retry sector count                  : 143
Track 03
    Filename : /Users/admin/Music/Lossless/Joe Jackson/ Night Music/ 03 Ever after.flac
    Pre-gap length : 00:01:05
    CRC32 hash              : 4F754114
    CRC32 hash (skip zero)  : 80B21159
    AccurateRip v1 signature : 809ED79D
    AccurateRip v2 signature : 75457F4E
    Statistics
        Read error                          : 0
        Retry sector count                  : 234
Track 04
    Filename : /Users/admin/Music/Lossless/Joe Jackson/ Night Music/ 04 Nocturne No.2.flac
    Pre-gap length : 00:01:67
    CRC32 hash              : DCF14B0C
    CRC32 hash (skip zero)  : 109F691E
    AccurateRip v1 signature : 07F0A5DB
    AccurateRip v2 signature : 896712B3
        ->Rip may not be accurate (total 112 submissions).
    Statistics
        Read error                          : 0
Track 05
    Filename : /Users/admin/Music/Lossless/Joe Jackson/ Night Music/ 05 The man who wrote Danny Boy.flac
    CRC32 hash              : 5B8E07F8
    CRC32 hash (skip zero)  : C5568438
    AccurateRip v1 signature : AE6A7317
    AccurateRip v2 signature : 2A526605
        ->Rip may not be accurate (total 111 submissions).
    Statistics
        Read error                          : 0
        Jitter error (maybe fixed)          : 3
        Retry sector count                  : 426
Track 06
    Filename : /Users/admin/Music/Lossless/Joe Jackson/ Night Music/ 06 Nocturne No.3.flac
    Pre-gap length : 00:01:02
    CRC32 hash              : 3E20D34F
    CRC32 hash (skip zero)  : 84C6E5EA
    AccurateRip v1 signature : 1084ACE1
    AccurateRip v2 signature : 2AB34B62
        ->Accurately ripped (v1+v2, confidence 91+10/111)
    Statistics
        Read error                          : 0
        Retry sector count                  : 442
Track 07
    Filename : /Users/admin/Music/Lossless/Joe Jackson/ Night Music/ 07 Lullaby.flac
    Pre-gap length : 00:00:25
    CRC32 hash              : 7E1988F6
    CRC32 hash (skip zero)  : F3CFCABF
    AccurateRip v1 signature : 13BD2828
    AccurateRip v2 signature : EB5A0E4D
    Statistics
        Read error                          : 0
        Retry sector count                  : 624
Track 08
    Filename : /Users/admin/Music/Lossless/Joe Jackson/ Night Music/ 08 Only the future.flac
    Pre-gap length : 00:00:62
    CRC32 hash              : 43A58A12
    CRC32 hash (skip zero)  : C09E5FE1
    AccurateRip v1 signature : B9F866A6
    AccurateRip v2 signature : 2F707AD3
        ->Accurately ripped (v1+v2, confidence 89+10/109)
    Statistics
        Read error                          : 0
        Retry sector count                  : 468
Track 09
    Filename : /Users/admin/Music/Lossless/Joe Jackson/ Night Music/ 09 Nocturne No.4.flac
    CRC32 hash              : 26CC8EF1
    CRC32 hash (skip zero)  : A67EC799
    AccurateRip v1 signature : 7BE9DD24
    AccurateRip v2 signature : FC01A7FD
        ->Rip may not be accurate (total 110 submissions).
    Statistics
        Read error                          : 0
        Retry sector count                  : 597
Track 10
    Filename : /Users/admin/Music/Lossless/Joe Jackson/ Night Music/ 10 Sea of secrets.flac
    Pre-gap length : 00:00:03
    CRC32 hash              : 9E185832
    CRC32 hash (skip zero)  : 6E940FF9
    AccurateRip v1 signature : 5AC0EA70
    AccurateRip v2 signature : B7A2795F
        ->Rip may not be accurate (total 109 submissions).
    Statistics
        Read error                          : 0
        Retry sector count                  : 519
No errors occurred
End of status report[/font]
Transcode from M4A:
XLD AccurateRip checking logfile
TOC of the selected file
    (1) 103 (confidence 102)
    (2) -101 (confidence 10)
All Tracks
    Album gain              : -2.94 dB
    Peak                    : 0.998444
    CRC32 hash              : 2E4768CC
    CRC32 hash (skip zero)  : 514E287D
Track 01
    Track gain              : -1.82 dB
    Peak                    : 0.998413
    CRC32 hash              : 873E592A
    CRC32 hash (skip zero)  : 8373EE96
    AccurateRip v1 signature : 1EF8DFE7 (4497C0EB w/correction)
    AccurateRip v2 signature : BDC1D749 (039F89C7 w/correction)
        ->Accurately ripped with different offset (v1+v2, confidence 87+10/106, offset +103)
Track 02
    Track gain              : -4.30 dB
    Peak                    : 0.998383
    CRC32 hash              : 7A1E53CF
    CRC32 hash (skip zero)  : EAAE660F
    AccurateRip v1 signature : 9A7901BC (AD74D8A4 w/correction)
    AccurateRip v2 signature : A81F33B9 (D17B18BB w/correction)
        ->Accurately ripped with different offset (v1+v2, confidence 92+10/112, offset +103)
Track 03
    Track gain              : -3.53 dB
    Peak                    : 0.998444
    CRC32 hash              : 2A9C0F36
    CRC32 hash (skip zero)  : 5BEFCE6A
    AccurateRip v1 signature : 09486B41 (809ED79D w/correction)
    AccurateRip v2 signature : DBB282AC (75457F4E w/correction)
Track 04
    Track gain              : 0.75 dB
    Peak                    : 0.982574
    CRC32 hash              : 3DDD2AF4
    CRC32 hash (skip zero)  : 02F64B77
    AccurateRip v1 signature : DFF94524 (15A9D062 w/correction)
    AccurateRip v2 signature : 43CA9AE6 (8A4EB8D4 w/correction)
Track 05
    Track gain              : -1.65 dB
    Peak                    : 0.998444
    CRC32 hash              : AF6F2625
    CRC32 hash (skip zero)  : E79324EF
    AccurateRip v1 signature : 311D27BF (30F2B771 w/correction)
    AccurateRip v2 signature : 7C4CFFCF (A756DF2C w/correction)
        ->Accurately ripped with different offset (v1+v2, confidence 91+10/111, offset +103)
Track 06
    Track gain              : 0.85 dB
    Peak                    : 0.702911
    CRC32 hash              : 7EE63A9B
    CRC32 hash (skip zero)  : 360E2347
    AccurateRip v1 signature : FE74E966 (1084ACE1 w/correction)
    AccurateRip v2 signature : F55571F4 (2AB34B62 w/correction)
Track 07
    Track gain              : -1.83 dB
    Peak                    : 0.998383
    CRC32 hash              : F0D3A986
    CRC32 hash (skip zero)  : F1A65389
    AccurateRip v1 signature : 23F8074F (13BD2828 w/correction)
    AccurateRip v2 signature : FE325365 (EB5A0E4D w/correction)
Track 08
    Track gain              : -5.10 dB
    Peak                    : 0.998444
    CRC32 hash              : 610B97B8
    CRC32 hash (skip zero)  : 73907ED8
    AccurateRip v1 signature : DD62F168 (B9F866A6 w/correction)
    AccurateRip v2 signature : 37581ECF (2F707AD3 w/correction)
        ->Accurately ripped with different offset (v1+v2, confidence 89+10/109, offset +103)
Track 09
    Track gain              : 1.56 dB
    Peak                    : 0.691467
    CRC32 hash              : 31C628ED
    CRC32 hash (skip zero)  : 8BCA8DD3
    AccurateRip v1 signature : 94394BDA (75DE1507 w/correction)
    AccurateRip v2 signature : 8E680E17 (948D1D91 w/correction)
        ->Accurately ripped with different offset (v1+v2, confidence 90+10/110, offset +103)
Track 10
    Track gain              : -2.26 dB
    Peak                    : 0.886932
    CRC32 hash              : 2DF36F65
    CRC32 hash (skip zero)  : BEF0B3DD
    AccurateRip v1 signature : 9644EE4A (25AD1B1C w/correction)
    AccurateRip v2 signature : 01F54FE4 (91CB837C w/correction)
A sample-by-sample comparison might be shed some light..
To satisfy a hunch, could you check to see if there was a channel reversal in any of the errantly-ripped tracks?
Please also try XLD in burst mode.
Hi greynol
Tried XLD with Ripper Mode: Burst, the log is below (->All tracks accurately ripped.)
I'm quite new to this stuff, can you tell me how I can check if there was a channel reversal?
XLD extraction logfile from 2013-04-07 14:26:01 +0200
Ripper mode            : Burst
Disable audio cache    : NO
Make use of C2 pointers : NO
    Track 01 : OK (v1+v2, confidence 97/106)
    Track 04 : OK (v1+v2, confidence 102/112)
    Track 05 : OK (v1+v2, confidence 101/111)
    Track 09 : OK (v1+v2, confidence 100/110)
    Track 10 : OK (v1+v2, confidence 99/109)
Track 01
    CRC32 hash              : 2E69307C
    AccurateRip v1 signature : 4497C0EB
    AccurateRip v2 signature : 039F89C7
        ->Accurately ripped (v1+v2, confidence 87+10/106)
Track 02
Track 03
Track 04
    CRC32 hash              : 6032EF87
    AccurateRip v1 signature : 15A9D062
    AccurateRip v2 signature : 8A4EB8D4
Track 05
    CRC32 hash              : 1AA264F4
    AccurateRip v1 signature : 30F2B771
    AccurateRip v2 signature : A756DF2C
Track 06
Track 07
Track 08
Track 09
    CRC32 hash              : 488195C8
    AccurateRip v1 signature : 75DE1507
    AccurateRip v2 signature : 948D1D91
        ->Accurately ripped (v1+v2, confidence 90+10/110)
Track 10
    CRC32 hash              : 33C21F62
    AccurateRip v1 signature : 25AD1B1C
    AccurateRip v2 signature : 91CB837C
[/font]
I'll try to check for channel reversals. Thanks for the codebox hint.
What does an accurate rip in burst mode mean, compared to the XLD secure ripper?
Smudeli,
Did you try using the secure ripper with 'Make use of C2 pointers' turned off?
(Settings from the rip log above: rip with the errors)
[color=#FF0000]Make use of C2 pointers : YES[/color]
(Settings from the rip log above: the good rip)
Ripper mode : Burst
[color=#FF0000]Make use of C2 pointers : NO[/color]
The only reference I found was [a href=\'index.php?act=findpost&pid=771077\']this post[/a].
korth
korth
I turned 'Make use of C2 pointers' off, seems like the way to go.
XLD extraction logfile from 2013-04-07 15:01:54 +0200
All Tracks
    Statistics
        Read error                          : 0
        Retry sector count                  : 0
Track 01
    Statistics
        Read error                          : 0
Track 02
    Statistics
        Read error                          : 0
Track 03
    Statistics
        Read error                          : 0
Track 04
    Statistics
        Read error                          : 0
Track 05
    Statistics
        Read error                          : 0
Track 06
    Statistics
        Read error                          : 0
Track 07
    Statistics
        Read error                          : 0
Track 08
    Statistics
        Read error                          : 0
Track 09
    Statistics
        Read error                          : 0
Track 10
    Statistics
        Read error                          : 0
No errors occurred
Ripped some more CD's, everything works perfect!
Thanks to all for your input.
Regards, Udo
I'd still like to know how the files differ. Asking the drive to return C2 pointers should not affect its ability to return error-free data; rather, this suggests a problem with implementation somewhere.
I had a similar problem with XLD way back in 2008, and I posted comparison logs here:
http://www.hydrogenaudio.org/forums/index....st&p=589849
To wit: never bother to enable C2 pointers on XLD. It doesn't work. My subsequent experimentation with drives that are acknowledged to successfully report C2 information showed that they still didn't play nice with XLD, returning different CRCs. I didn't have that problem when using those very same drives with dBpoweramp.
