Topic: No sound coming out of speakers (Read 1704 times) previous topic - next topic
I am trying to get Foobar 2000 latest edition to play music files but it is silent. It shows a signal that indicates the mp3 is recognized and is playing but I can't get the speakers to play. HELP!  I also can't get the album cover artwork to change as the selection changes. My old foobar worked great for years. I'm using windows7. Thank you.
Things that could cause this:
Foobar's volume is too low.
Windows' volume is too low or muted.
Windows is using the wrong output device.
You're not properly connected to your sound system.
Your sound system's volume is too low.
... I could go on forever
One thing you can try: do other apps make sound? Then we'll know if it's specifically Foobar or something else going wrong.
Quote from: oldiesinc link=msg=0 date=
HELP!
We get it. You obviously came here for help.
Check setting at: Preferences > Playback > Output > Device
Check for errors at: View > Console
Select one of these, or both:
Preferences > Display > Selection Viewers > Prefer currently playing track
Main menu > Playback > Cursor follows playback
Are... are the speakers turned on?
Thank you guys, I'm going to start running through the ideas you offered and try each one out until we get this thing licked. I'm really pleased that you guys helped me out so quickly. I am so glad to be back here  again. I'll keep you posted. btw ,I always check the speakers for a power source    before I do anything
Volume is at 90% everywhere and sounds fine now. Thank you
