Topic: Extracting embedded cue sheets from FLAC & WV (Read 10712 times) previous topic - next topic
I have a number of WV & FLAC files with embedded cue sheets, is there an app which can extract the embedded cue sheets so i have a .flac file and a .cue sheet?
thanks
mark
Foobar2000 (select one track -> Utils -> Edit Cuesheet)  Also for FLAC u can use metaflac (FLAC metadata editor) with '--export-cuesheet-to=FILE'
Thinking Outside The Box
It can be done from the command line with
metaflac --export-cuesheet-to="mycuesheet.cue" "myflacflilewithcuesheet.flac". You can also use foobar to view the cuesheet and copy and paste to a new file by right clicking on the file and selecting the option under "utils"
Edit: I am not redundant. Kirya's post wasn't there when I started! :-P
Eric
perfect thanks a million
