Hi, I've just bought Lateralus by Tool (Gifted away the old one in panic), and decided to rip it once more - perfectly.
Trouble, however, arises in the very last minutes of the CD, where EAC gets some trouble reading the disk, starts error correcting, spins down, spins up again, down, up, etc.
Again, this CD is mint fresh. Completely untouched by human hands, out of the box. I've configured my drive settings in EAC correctly using AccurateRip. My drive is a rarely used Plextor PX-740a drive.
I tried ripping Ænima, and it (also completely untouched CD) rips perfectly without errors.
When ripping into individual tracks, AccurateRip reports that everything worked out perfectly:
Track Ripping Status [Disc ID: 00233e73-c612800d]
1 Accurately Ripped (confidence 8) [bd8d378e]
2 Accurately Ripped (confidence 7) [ede6f6e1]
3 Accurately Ripped (confidence 7) [9297b9c0]
4 Accurately Ripped (confidence 7) [8e5230ed]
5 Accurately Ripped (confidence 7) [cda45379]
6 Accurately Ripped (confidence 6) [8ee82a6a]
7 Accurately Ripped (confidence 7) [2d39fd1e]
8 Accurately Ripped (confidence 7) [db813dad]
9 Accurately Ripped (confidence 7) [bf464073]
10 Accurately Ripped (confidence 7) [79d55034]
11 Accurately Ripped (confidence 6) [331026cf]
12 Accurately Ripped (confidence 7) [58948108]
13 Accurately Ripped (confidence 6) [9d9373a1]
_______________________
All Tracks Accurately Ripped.
However, the EAC log tells a different story.
EAC extraction logfile from 21. May 2006, 2:25 for CD
Tool / Lateralus
Used drive : PLEXTOR DVDR PX-740A Adapter: 1 ID: 0
Read mode : Secure with NO C2, accurate stream, disable cache
Read offset correction : 618
Overread into Lead-In and Lead-Out : No
Used output format : Internal WAV Routines
44.100 Hz; 16 Bit; Stereo
Other options :
Delete leading and trailing silent blocks : No
Native Win32 interface for Win NT & 2000
Track 1
Filename D:\eac\out\Tool - 01 - The Grudge.wav
Peak level 98.8 %
Track quality 100.0 %
Copy CRC E031C821
Copy OK
Track 2
Filename D:\eac\out\Tool - 02 - Eon Blue Apocalypse.wav
Peak level 42.3 %
Track quality 99.8 %
Copy CRC 09AE4997
Copy OK
Track 3
Filename D:\eac\out\Tool - 03 - The Patient.wav
Peak level 98.8 %
Track quality 99.9 %
Copy CRC A7770112
Copy OK
Track 4
Filename D:\eac\out\Tool - 04 - Mantra.wav
Peak level 37.0 %
Copy CRC 217C3515
Copy OK
Track 5
Filename D:\eac\out\Tool - 05 - Schism.wav
Peak level 98.8 %
Copy CRC F7497C96
Copy OK
Track 6
Filename D:\eac\out\Tool - 06 - Parabol.wav
Peak level 72.8 %
Copy CRC 9AD4154E
Copy OK
Track 7
Filename D:\eac\out\Tool - 07 - Parabola.wav
Peak level 98.8 %
Copy CRC 19C5F6D2
Copy OK
Track 8
Filename D:\eac\out\Tool - 08 - Ticks & Leeches.wav
Peak level 98.8 %
Copy CRC BA384629
Copy OK
Track 9
Filename D:\eac\out\Tool - 09 - Lateralus.wav
Peak level 98.8 %
Copy CRC BB6D8391
Copy OK
Track 10
Filename D:\eac\out\Tool - 10 - Disposition.wav
Peak level 74.8 %
Copy CRC 9548965B
Copy OK
Track 11
Filename D:\eac\out\Tool - 11 - Reflection.wav
Peak level 98.8 %
Copy CRC B1AF10C7
Copy OK
Track 12
Filename D:\eac\out\Tool - 12 - Triad.wav
Peak level 98.8 %
Copy CRC 17CA921A
Copy OK
Track 13
Filename D:\eac\out\Tool - 13 - Faaip de Oiad.wav
Peak level 100.0 %
Copy CRC CD4F3B83
Copy OK
No errors occured
End of status report
As you can see, the track quality is not 100% on all tracks. Am I being too paranoid? Am I misunderstanding what "Track Quality" means in EAC? Is there a way to fix this?
