Topic: Lame 3.96.1 compiles (Read 3869 times) previous topic - next topic
are there any differences with lame 3.96.1 from rarewares and mitiok. Does anyone know why the exe sizes are different? I can't seem to find anything on the topic.
probably different compilers / flags.
Nothing but a Heartache - Since I found my Baby ;)
I too am interested as to the differences.  Donunus, please try encoding the same .wav (from commandline) and post about any difference.  I downloaded the Mitiok compile 3.96.1 a while back and the commandline says it's 3.96 (I notice this after encoding 100's of CDs...)
[a href="index.php?act=findpost&pid=312282"][{POST_SNAPBACK}][/a]
That happened to me before but i downloaded another copy and its 3.96.1 is now in the command line. This is still from mitiok. havent tried the rarewares one. just downloaded it now for backup.
I want a few comments first before I experiment but so far the only problem of the 3.96.1 I'm currently ripping with at preset extreme is that sometimes there are time errors with the mp3s(1 out of a thousand or so). I rip the same songs again and it fixes the problem. sounds better IMO than the recommended 3.90.3 Lame. I trusted my impulses  after listening to just a few songs that it didn't sound as dry and seemed to have better PrAt than the older lame.
This has been brought up many times.  I'm not sure if this thread is still valid:
http://www.hydrogenaudio.org/forums/index....topic=20759&hl=
Here are my own tests and some info:
Must be different flags, same compiler in readme from package:
Compiled with icl 4.5 & nasm.exe & dll were compressed with UPX executable packer http://upx.sourceforge.net/
mitiok
The results from the two compiles are bit-identical:
INFO (foo_bitcompare) : Comparing:
INFO (foo_bitcompare) : location: "file://C:\Documents and Settings\_____\Desktop\lame3.96.1\Layla.mp3" (0)
INFO (foo_bitcompare) : location: "file://C:\Documents and Settings\_____\Desktop\lame-3.96.1\Layla.mp3" (0)
INFO (foo_bitcompare) : No differences in decoded data found.
INFO (foo_bitcompare) : Finished successfully.
Here's my speed test, the values fluctuate each time I run them probably because of other things eating up CPU time, but there is no clear winner.  I would venture to say whatever different flags used have no effect on anything, at all.
Rarewares: 7.9299x
Mitiok: 8.0164x
Rarewares: 7.9505x
Mitiok: 7.9442x
Rarewares: 7.8996x
Mitiok: 7.9916x
EDIT: This is on a P4, AMD tests may be different.
So negligible differences in speed, basically...
I assume anyone would agree?
"The way we see our world is better than yours."
