Topic: CUETools 2.1.7 & 2.1.8 libFLAC error "Arithmetic operation resulted in an overflow" (Read 4174 times) previous topic - next topic
In CUETools 2.1.7 when i try to encode something to FLAC using libFLAC encoder this results in error "Arithmetic operation resulted in an overflow.."
Core i3 3245, Windows 7 SP1 32bit, NET Framework 4.6.1, MSVC 2015
Re: CUETools 2.1.7 libFLAC error "Arithmetic operation resulted in an overflow"
Thanks, i'll look into it.
CUETools 2.1.6
Getting this with v.2.1.8 on Win 10 x64 and Win 7 x86.
Went back to v.2.1.6 and all ok again.
Re: CUETools 2.1.7 & 2.1.8 libFLAC error "Arithmetic operation resulted in an overflow"
I have tried to reproduce this issue by encoding dozens of albums using CUETools 2.1.8 and libFLAC using default settings.
So far not hit. The error "Arithmetic operation resulted in an overflow" has not appeared yet.
It would be good to have an album, where this error occurs, for debugging.
In my case, it was Willie Nelson's Spirit.  I was using libFLAC at compression 6.
Is there a way to erase all settings back to default?
Thanks for the info about an album, where the error occurs.
The default compression setting for libFLAC is "5".
The settings file is typically stored here:
"%APPDATA%\CUE Tools\settings.txt"
Which is "C:\Users\%USERNAME%\AppData\Roaming\CUE Tools\settings.txt"
If you backup and remove this settings.txt file, the default settings are restored after the next start of CUETools.exe.
Another possibility is to rename the file "user_profiles_enabled" to e.g. "user_profiles_disabled".
After the next start of CUETools.exe, a fresh default settings file is generated in a subdirectory, where the CUETools zip file has been unpacked:
"CUE Tools\settings.txt"
Thanks.  After deleting the %APPDATA% folders, v.2.1.8 rips without error.
Sorry to say that I still see this error creating image & cue in CUERipper v.2.1.8 when using libFLAC compression 5 burst.  Switching to cuetools solves it.
Thanks for the additional information.
Does this mean, that the error only occurs on your system, when Burst mode is used and that it is OK in Secure mode?
Two more questions:
- With which drive model does this error occur?
- Does the error occur with every album or just single ones?
It's an "HL-DT-ST DVDRAM GH24NS50 ATA Device".  It's happened on 3 out of 3 CDs I've tried, after gap detection at about 2% completion.  Error on Burst, Secure, and Paranoid.
@Apesbrain In the meantime I can reproduce the issue "Exception: Arithmetic operation resulted in an overflow.", when encoding using libFLAC. It happens, when CUERipper is running in 32-bit mode. Could you please check on your Win10 64-bit system, if Task Manager shows "CUERipper" or "CUERipper (32-bit)", after CUERipper has been started?
X
Normally, CUERipper would run in 64-bit mode on a Win10 64-bit system. For testing, I could force CUERipper to run in 32-bit mode using
CorFlags.exe CUERipper.exe /32BITREQ+
from the Visual Studio Developer Command Prompt and reproduce the issue.
In Task Manager, it says "CUERipper" on my Win 10 x64 system.  These latest errors, however, were on my Win 7 x86 server.  I'll test both again.
EDIT: Confirmed, the issue seems only to be on the x86 system.
