FLAC support is (unfortunately!) not built-in to Snow Leopard. Here is a list of the native formats/codecs:
Audio file and data formats:
'3gpp' = 3GP Audio (.3gp)
data_formats: 'aac ' 'samr'
'3gp2' = 3GPP-2 Audio (.3g2)
'adts' = AAC ADTS (.aac, .adts)
data_formats: 'aac ' 'aach'
'ac-3' = AC3 (.ac3)
data_formats: 'ac-3'
'AIFC' = AIFC (.aifc, .aiff, .aif)
data_formats: I8 BEI16 BEI24 BEI32 BEF32 BEF64 UI8 'ulaw'
'alaw' 'MAC3' 'MAC6' 'ima4' 'QDMC' 'QDM2'
'Qclp' 'agsm'
'AIFF' = AIFF (.aiff, .aif)
'amrf' = AMR (.amr)
data_formats: 'samr'
'caff' = Apple CAF (.caf)
data_formats: '.mp1' '.mp2' '.mp3' 'QDM2' 'QDMC' 'Qclp'
'Qclq' 'aac ' 'aach' 'aacl' 'alac' 'alaw'
'dvi8' 'ilbc' 'ima4' I8 BEI16 BEI24 BEI32
BEF32 BEF64 LEI16 LEI24 LEI32 LEF32 LEF64
'ms\x00\x02' 'ms\x00\x11' 'ms\x001' 'samr'
'ulaw'
'm4af' = Apple MPEG-4 Audio (.m4a)
data_formats: 'aac ' 'aach' 'aacl' 'alac'
'MPG1' = MPEG Layer 1 (.mp1, .mpeg, .mpa)
'MPG2' = MPEG Layer 2 (.mp2, .mpeg, .mpa)
data_formats: '.mp2'
'MPG3' = MPEG Layer 3 (.mp3, .mpeg, .mpa)
data_formats: '.mp3'
'mp4f' = MPEG-4 Audio (.mp4)
'NeXT' = NeXT/Sun (.snd, .au)
data_formats: I8 BEI16 BEI24 BEI32 BEF32 BEF64 'ulaw'
'Sd2f' = Sound Designer II (.sd2)
'WAVE' = WAVE (.wav)
data_formats: UI8 LEI16 LEI24 LEI32 LEF32 LEF64 'ulaw'
'alaw'
If you are able to QL FLAC files, it is a good bet that Fluke is the "culprit". You can also look in /Library/QuickLook/ and ~/Library/QuickLook/ to see if you have a custom QL generator for FLAC.
