Topic: Plugin for enable / disable DPSs? (Read 2909 times) previous topic - next topic
Hi guys! I have a question and hope you can help me. Do you know any plugin that allows me to enable / disable DSPs from within the GUI?
The problem is as follow: For normal stereo sources (that is nearly 100% of my music collection) I use the Matrix Mixer DSP to map the front left channel to back left etc. But if I play 5.1 sources like some OGG or DTS files I don't want the Matrix Mixer in my DSP chain! So I have to go everytime in the preferences and disable / enable the DSP... and lose my Matrix Mixer configuration
Do you know any plugin that integrates into the GUI and allows me to disable a DSP? Would be awsome if you could help me!
Many thanks
Did you use ColumnsUI?
UPD: Ouch... I've read "Channel Mixer" instead of "Matrix Mixer", so I cancel my question.
Use foobar's builtin DSP presets instead of disable/enable the DSP plugin.
My English is very good!
...in comparison with my Korean language...
Can you explain what you mean?
Just take a look into the preferences page of the dsp manager and you will see what he means!  Once a preset is created you won't loose that configuration.
My English is too poor, so I can't explain in more details. Just look on screenshot.
