Topic: ColumnsUI panel does not get created in Release build (Read 1644 times) previous topic - next topic
During release testing of Columns UI support for my component I hit a problem:
- The component gets registered correctly and recognized by Columns. I can even add a panel with my component but the create_or_transfer_window() method is never called (Established with good old fashioned printf debugging because the debugger is not available)
Obviously the Debug build works flawlessly (I think).
Does anybody know what causes this?
Re: ColumnsUI panel does not get created in Release build
Is the extension_base::get_extension_guid method correctly implemented (returning a stable GUID and not e.g. an uninitialised variable)? Are there multiple panels sharing the same extension GUID? Similarly, is the window::is_available method correctly implemented?
If it's not any of those, if you share a project that reproduces the problem I'm sure someone will be able to find the problem.
Thank you for reply. No, it's not any of those: static GUID variable, 1 panel, is_available() = true. Here is the wrapper I'm using:
CUIElement.h
Looks like you're sharing a single GUID for DUI and CUI instances. Try separate ones.
edit: thinking about it, I doubt this is the issue but I've always done it. :P
edit2: looking at some old I code I had, maybe get_class_data needs to be implemented. But I would have expected you to have compile errors if it was really necessary??
		class_data& get_class_data() const override
__implement_get_class_data_ex(L"some unique class name here", L"", false, 0, WS_CHILD | WS_CLIPSIBLINGS | WS_CLIPCHILDREN, 0, CS_DBLCLKS);
Are you sure get_extension_guid isn't returning a dangling reference? Try changing GetGUID() to return a reference.
Thx, marc but why does the Debug version work flawlessly then?
It must be something the compiler optimizes away in a Release build.
I tried that this morning based on your earlier suggestions. GetGUID() just returns a static GUID. It's shared code between DUI and CUI. DUI works in the Release build as usual.  Replacing it with the actual GUID did not help.
static GUID GetGUID() noexcept
        static const GUID guid = GUID_UI_ELEMENT_SPECTOGRAM;
        return guid;
And is the GUID also not used during registration in the CUI panel inventory? I can select it while modifying the layout. It's just the window that is not created.
It doesn't – it's a static method that returns a GUID. That GUID is a copy of a static variable, but that's irrelevant because a copy is being made.
The DUI method doesn't return a reference, while the CUI one does. Hence it doesn't matter if the GUID outlives the function with the DUI method. (The CUI one is a only reference for historical reasons.)
If the GUID is changing every time., then CUI won't be able to later locate your service and call it. Similarly, the name of the panel will be replaced with <unknown> in the layout tree. In a debug build the deinitialised memory is probably being filled with something like 0xDDDDDDDD, so it ends up working because it's constant.
In any case, I changed GetGUID to return a const GUID& and built your component. I was then able to add it to the layout in CUI without problem.
Bottom line: rookie mistake. I always thought GUIDs were considered value types, not reference types.
Thx. for the help.
