Topic: Dolby Atmos to Ambisonics B Format conversion? (Read 3828 times) previous topic - next topic
Is it theoretically possible to render a Dolby Atmos stream into a Ambisonics B Format auditory scene?
This is just something I've been wondering about.
Re: Dolby Atmos to Ambisonics B Format conversion?
Yes, I think it would be quite possible. You would have to translate the coordinates of the x,y,z,w of ambisonics to whatever encoding device Atmos uses for its 9.1 bed. However, bear in mind that Atmos uses objectsas well as a bed so I can't see how you could extract "moving" objects from an ambisonic soundscape (eg a plane flying around) and translate them into an Atmos object automatically - it would have to be done manually and would take ages. Somebody may already be doing it though and developing some sort of algorithm - not that I know of anyway.
augustine, it seems you got it backwards, the question is "from Atmos to Ambisonics", not vice versa.
I'd also like to know if there is an answer to this; "Atmos => Ambisonic"
