Storing MP3 files with Foobar2000 and Halb27's lame 3995m
Reply #7 – 2015-11-20 12:55:32
...About the questions, I have some further argumentation: 1) my question was about the stable/unstable thing, since I saw your 3100m lame ver. and I thought that one was based an "alpha" build and I wanted confirmation about lame 3995m being the stable one. 4) ok I'll second your suggestion, but reading things that you wrote quite time ago I saved this to remind me the behaviour of your lame.exe:V0's default cvbr level is 4.0. Using the --cvbr x option overrides the default cvbr level. Using a cvbr level better than 4.0 together with -V0 or -V1 can improve those small issues which still exist when using -V0. E.g.: -V0 --cvbr 0 (ca 316 kbps) is an extremely high quality alternative to cbr 320. Can I still benefict of the improvement with -V0 --insane_factor 1.0 or is this a different way to encode mp3 than --cvbr 0? Believe me, I can and I want to trust your words with my eyes closed, but if you could spend 2 words about the differences I would really appreciate it (still knowing that my ears will never found any!) 5) Here I have a little misunderstanding: if "lowpass -1" means disabled -> default lame -V0's lowpass behaviour = disabled? or does "lowpass -1" mean that with that I'm using default lame V0's value? If yes, is it 19500 and you lowered it to 18300 in your 3995m version? (again, as you said, I understand that there are no hearable differences, but I just want to understand this simple thing, thank you!) 6) in more words, I mean: is it true that no degrees can occour if, for eg I do several times the encode to-from one big loseless file into multiple loseless files? Like from one flac to more flac files, then from the multiple flac just created again into one flac etc etc. Is it working in some way like compression with zip files, so that I can zip&unzip to infinite without degree of the containt? (obvious anyone can answer to this common question, sorry for the OT) 1) lame3995m is based on Lame 3.99.5 which is the current release version. So: yes, this is the stable version. 2) Using --cvbr 0 the minimum bitrate constraints are high. On occasion this can have a negative effect on the size of the bit reservoir. The bit reservoir allows locally for a significantly higher audio bitrate than 320 kbps, and one of the special things my Lame variant does is trying to keep the bit reservoir large. --insane_factor 1.0 has the priority on holding bit reservoir extremely large at the expense of having no significant (theoretical) quality advantage over standard Lame at (rare) times. But that's all theory and the audible quality is not expected to be different. 5) lame3995's --lowpass switch does the same as the original, so lowpass -1 switches the lowpass off which is the default behavior for Lame 3.99.5 -V0. 6) As I said I have no experience with this procedure. I personally would split the files using a wav editor. Sure if you have the cue files already your procedure is easier to do. I second sundance's proposal for using lossyFLAC. Worth to consider, especially if you can allow for a bitrate ~400 kbps.
