6-bit PCM sample 2012-12-29 17:58:46 For this topic:http://www.hydrogenaudio.org/forums/index....96786&st=25
6-bit PCM sample Reply #2 – 2012-12-29 19:27:43 True, and amplifiyng the sample to peak at 0 db would also help. Loud samples like the next examples sound quite ok with 6-bit. I just uploaded this sample to dispel any notion that MP3s have a 25 dB dynamic range (actually it has around 125 dB) http://www.hydrogenaudio.org/forums/index....;f=1&t=6377 .I don't know how to do noise shaping or dithering with 6 bits as the bitcrusher I use does not have that (which is understandable as the very reason for a bitcrusher is to color/distort the sound).EDIT - Actually not even 6-bit PCM has just 25 dB of dynamic range/signal to noise ratio. It is cca 36 dB for 6-bits. Last Edit: 2012-12-29 19:33:09 by Neuron
