Topic: official CD writing support component (Read 42641 times) previous topic - next topic
is cd-text still not supported in the latest release?
any way to manually choose a speed in the writeaudio options ?
Yes. Use a real recorder, not the image recorder.
[a href="index.php?act=findpost&pid=324883"][{POST_SNAPBACK}][/a]
..that is ?
Whichever CD-R drive that you have. Provided you have Nero Burning ROM installed.
[a href="index.php?act=findpost&pid=324902"][{POST_SNAPBACK}][/a]
I can't seem to use a speed different then maximum on audio cd writer options ...nothing is listed bar maximum
why ?
Fantastic plugin...
Use it with Case's Gap Killer, and you can write Gapless CDs!
I've tested this against Nero (setting the pregap to 0 seconds) and its far better between tracks.
On some tracks there is no gap at all, but with others there is a slight click - but it's much shorter than what Nero can deal with.
I'm assuming that it's because because after the gap has been removed, the track no longer aligns on a CD sector, but its a step in the right direction.
All I need now is CD-Text support, so I can see the tracks in my car stereo!
This may save me from having to rip my house music again into CUE+WAV...
[a href="index.php?act=findpost&pid=142237"][{POST_SNAPBACK}][/a]
"J.J."
Reply #32
Where is the Case Installer and/or Gap Killer?
What website or URL?
"J.J."
The link is broken, is there another?
Is over the of = % over 100
Reply #34
Yes, on the foobar components webpage:
[a href="http://www.foobar2000.org/components.html#foo_burninate]http://www.foobar2000.org/components.html#foo_burninate[/url]
Reply #36
Link is still broken!!
also the link on the foobar2000.org is broken!!
tx
Reply #37
The links and files are not broken. Just outdated / removed. (I challenge you to find a way to actually navigate to them via http://www.foobar2000.org/ )
Reply #38
I'm sure I read somewhere on here (sorry, searched but can't find it), that this component can work with certain Nero DLLs in the fb2k folder, thus negating the need to have Nero "fully" installed. Is that complete rubbish? If not, which DLLs do I need and which folder do they need to be in?
I actually assume that I'd need to install Nero first, then collect the DLLs, and then uninstall Nero.
And I may just keep Nero installed anyway, but it's been bugging me to find out if foo_burninate can be used without a full Nero install.
Reply #39
I just noticed that foo_buninate was updated on the 4th of August. It is version 2.0.1 now! Get it on the official components-page.
Reply #40
is this burninate component planned to be ported to vista, or does anyone have it working on vista?
or maybe is there anyone working on a cd burner that doesnt need nero? foobar is so good, and the simplest solution for burning gapless cds (for me at least). the nero dependency, while powerful, really kind of sucks. i hope cd burning in foobar under vista comes back alive. or i figure out whats wrong with mine...
Reply #41
Is there anyway to get this working with Nero Lite?
Reply #42
I tried that, but I don't think so.
If anyone knows which DLLs you need to have in which folder and can uninstall Nero, let us know.
Reply #43
can anyone choose a CD burning speed? mines always blank!
Reply #44
Nero libraries were used because most of burner owners have it installed (legally or not), please don't pretend that you have a problem with that.
If you want a component using cdrdao, then go write it, then deal with GPL licensing issues (by taking GPL strictly, you can't include GPL code in fb2k components, because all components are linked to fb2k SDK which uses different license).
You don't need to link to cdrdao, it comes as an executable that takes command line arguments all you need to do is generate a .cue file and appropriate .wav file then run it. This allows you to distribute cdrdao with your plug-in without violating the GPL (to be safe though it would be a good idea to include the cdrdao source as a .tar.bz2 or .tar.gz alongside the executable, this would be the entire extent of your GPL obligations). This does agree with the official FSF stance, since your plug-in would not be linked to cdrdao, it would not be covered by the GPL. You could in fact use a modified version of cdrdao that is easier for you to communicate with (over stdin/stdout of cdrdao), provided that you include the source to your modified version.
Reply #45
Hello,
I have Nero 6.6.16 installed on my system (with NCAB custom-built installer) and have just tried burning several FLACs with Foobar.  Everything went along fine until the burn reached the end, when an error window popped up with a message that Foobar crashed, and to check the log.  It is below.
I can burn fine with Nero, is there something wrong with the Nero installation?  Nerocom.dll not registered (for other programs that use Nero API?)??
Any help would be much appreciated.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 01E36065h
Access violation, operation: read, address: 01E36065h
Call path:
Registers:
EAX: 00000001, EBX: 01866AE8, ECX: 0396FF84, EDX: 7C90EB94
ESI: 01866AE8, EDI: 00000000, EBP: 0396FFEC, ESP: 0396FFAC
Unable to identify crash location
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F5000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F01000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 7E410000h - 7E4A0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D5000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 10029000h
comdlg32                        loaded at 763B0000h - 763F9000h
MSCTF                            loaded at 74720000h - 7476B000h
foo_albumlist                    loaded at 00A20000h - 00A67000h
OLEAUT32                        loaded at 77120000h - 771AB000h
foo_burninate                    loaded at 00A70000h - 00AA7000h
VERSION                          loaded at 77C00000h - 77C08000h
foo_cdda                        loaded at 00AC0000h - 00AF5000h
foo_converter                    loaded at 00B20000h - 00B89000h
foo_dsp_std                      loaded at 00BB0000h - 00BF1000h
foo_freedb2                      loaded at 00C20000h - 00C60000h
foo_input_monkey                loaded at 00C80000h - 00CCA000h
foo_input_std                    loaded at 00CF0000h - 00E03000h
foo_masstag                      loaded at 00E30000h - 00E7F000h
foo_out_ks                      loaded at 00EA0000h - 00ECA000h
SETUPAPI                        loaded at 77920000h - 77A13000h
foo_rgscan                      loaded at 00EF0000h - 00F38000h
foo_ui_std                      loaded at 00F60000h - 00FB7000h
UxTheme                          loaded at 5AD70000h - 5ADA8000h
xpsp2res                        loaded at 20000000h - 202C5000h
Apphelp                          loaded at 77B40000h - 77B62000h
netapi32                        loaded at 5B860000h - 5B8B4000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
shdocvw                          loaded at 7E290000h - 7E3FF000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                          loaded at 77B20000h - 77B32000h
CRYPTUI                          loaded at 754D0000h - 75550000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
WININET                          loaded at 771B0000h - 77256000h
WLDAP32                          loaded at 76F60000h - 76F8C000h
urlmon                          loaded at 7E1E0000h - 7E280000h
Secur32                          loaded at 77FE0000h - 77FF1000h
ksuser                          loaded at 73EE0000h - 73EE4000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 7C80B683h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "GetModuleFileNameA" (+000001B4h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C80B690h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "GetModuleFileNameA" (+000001C1h)
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
CD Audio Decoder 2.1.1  (foo_cdda)
ReplayGain Scanner 2.0.2  (foo_rgscan)
foobar2000 core 0.9.4.3  (Core)
WMA Decoder 1.1  (foo_input_std)
Album List 3.2.0  (foo_albumlist)
Standard DSP array 1.0  (foo_dsp_std)
Default User Interface 0.9acc  (foo_ui_std)
FLAC Decoder 1.1.0  (foo_input_std)
Monkey's Audio decoder 2.1.2  (foo_input_monkey)
Kernel Streaming Output 1.2.2  (foo_out_ks)
Masstagger 1.6  (foo_masstag)
Audio CD Writer 2.0.1  (foo_burninate)
Converter 1.0.1  (foo_converter)
freedb Tagger 0.5.2a  (foo_freedb2)
Reply #46
Bump.  Anyone?
The nerocom.dlls are all in the right place.  Can someone look at the error log in the previous post and tell me what's wrong?
Reply #47
Can't tell for sure, but AFAIK you need Nero 7 to use this component.
stimulating the audio nerve directly
Reply #48
Oh crap, really?!  I refuse on principle, as Nero 7 is one of the most bloated software packs out there, and 6 is just fine.  If it's true, it's lame.
Reply #49
You still can convert to WAV with any options you like (dithering, RG, DSP) and burn. Or you can try reinstalling Nero, which may fix the problem.
And, Nero 7 is fine, just don't install those lots-of-tools for audio/video/images.
