Topic: [SUGGESTION] Laurent de Soras' resampling (Read 1794 times) previous topic - next topic
Just discovered:
Resampler
A C++ library for high-fidelity resampling. Designed for real-time software samplers and synthesisers. CPU-friendly. Implements the technique described in my article The Quest For The Perfect Resampler.
HIIR
A library in C++ for: 1. Changing the sampling rate of a signal by a factor two, in both directions (upsampling and downsampling); 2. Obtaining two signals with a π/2 phase difference (Hilbert transform). It is made of a two-path polyphase IIR filter, implemented with FPU, 3DNow! and SSE instruction sets.
http://ldesoras.free.fr/prod.html
Hope that inspires !
Forward Agency NPO
In progress we (always) trust.
As they are both licensed under the LGPL, they are rather unsuitable for use in a foobar2000 component as they would have to be segregated into separate DLLs to comply with the license.
Both SoX and PPHS are great, high-fidelity resamplers. While there's nothing wrong with more, don't fool yourself into thinking that foobar2000 doesn't already have a lot of them.
About SoX Resampler:
"Uses SoX 14.3 resampling algorithm
(http://sox.sourceforge.net/, rate.c, Copyright © 2008 robs@users.sourceforge.net)
DSP plug-in for foobar2000 1.0+ written by lvqcl.
Resampling algorithm is inspired by, and builds upon some of the ideas presented in 'The Quest For The Perfect Resampler' by Laurent De Soras;
http://ldesoras.free.fr/doc/articles/resampler-en.pdf"
SoX 'rate' effect is "inspired by, and builds upon some of the ideas presented in `The Quest For The Perfect Resampler' by Laurent De Soras"
Added: ...a bit too late.
