Topic: Facets (foo_facets) (Read 677503 times) previous topic - next topic
Re: Facets (foo_facets)
Reply #650
@anamorphic I added an "Artist" column to the middle pane [in addition to the "Album" and "Date" columns]. Now, those two albums each have their own separate entries. This might only help for purposes of display? i.e. I use the IPod plugin, here, and noticed that I am having the same issue on my IPOD, one entry for both albums in Album view. I posted a similar question in that forum.  Do you know anything about this?
Reply #651
Sorry - I'm not familiar with how iDevices do anything, but it might recognize "Album Title Sort Order" / ALBUMSORTORDER tag (if foobar maps correctly to 'soal' as referenced for iTunes here) - if you want to try that method in my previous post.
Best of luck 8)
Reply #652
I have two instances of facets in separate UI elements, can anyone tell me how to make a selection in one instance affect another? Say I chose an artist in the first instance, it would show the artists albums in the second.
EDIT* I figure out I just had to set my album list element to playlist instead of library.
Reply #653
Does anybody know if it's possible to switch facets filters using keyboard shortcuts?  These are what I'm referring to:
https://i.imgur.com/9GVf8Sn.png
If I could assign keyboard shortcuts to each of those filters, it would be fantastic!  (I would expect the keyboard shortcut to switch between them when multiple filters is off, and apply / unapply them when multiple filters is on).
Reply #654
So is there currently any way to cache the album art with facets? I saw a few pages back that there was an alternative using jscript, but it's not for Facets. Facets pretty much works perfectly for what I do. If it can cache the album art, it would be perfect.
Reply #655
Does anybody know if there are keyboard shortcuts to switch between filters?  I'm on the brink of resorting to pyautogui, I really want a way to do this.
Reply #656
PyAutoGUI doesn't work on multiple monitors so I gave up and used autohotkey.
Reply #657
Do you mind to share your AHK Script(s) and maybe a smallish how-to?
I'm curious if it will be easy to use *and* easy to set up.
(I know AHK a little, but never get into the depths of it)
