Topic: Post cannot be edited anymore (Read 1953 times) previous topic - next topic
I am using IE5 and cannot edit this post again.  It seems that the html of the page is somehow opening up in the form and not allowing the rest of the edit page to load.
http://www.hydrogenaudio.org/forums/index....hl=&#entry86058
WARNING:  Changing of advanced parameters might degrade sound quality.  Modify them only if you are expirienced in audio compression!
Yeah, it is a known forum bug in quote-handling sometimes, which should be fixed in IPB 1.2.
The only thing you can do is to copy the text from the forum view and create a new message. A moderator will remove the double post.
Juha Laaksonheimo
