Topic: [TOS #6] New to Foobar: some issues (Read 1940 times) previous topic - next topic
These are probably noob questions, but I'm having trouble with a few things. Wondering if I could get some help.
1: I'm having difficulty making a "recently added" autoplaylist so that it displays tracks that have been added in the last week. I can do it for 2 weeks, but I don't know how to make it display for anything less that. Not sure what I'm doing wrong. I've got foo_navigator.
2: I've got Columns UI. I want to add a "Ratings" column but in Columns UI, Playlist View I can't add the string because you can't add patterns. How do I get star ratings to display with Columns UI? I've got foo_quicktag, foo_playcount.
3: I've added a column call "Added" which shows the date the song was added, but what I'd like to do is be able to display them in a chronological order by pressing the heading, like how when I press the "Album" heading it shows all albums in alphabetical order.
4: I've used foo_fileops to copy my music to my mp3 player. It seems it can't overwrite files. I've added the SendtoDevice component but it crashed when I used it. I'm going to try again and see if it will work. Does SendtoDevice overwrite files? Is there a similar component out there?
thanks.
1. Main menu Library, Search:
%added% DURING LAST 1 WEEK SORT ASCENDING BY %added%
Then press the [...] button to create an autoplaylist from that search. Further help:foo_navigator adds a history function for played files. It has nothing to do with what you are looking for.
2. Main menu File, Preferences, Display, Columns UI, Playlist view -> tab "Columns":
Create a column, choose the tab "Scripts", paste the following code:
[$repeat(★,%rating%)]
If your ratings are saved in your files replace %rating% with $meta(rating)
3. Main menu File, Preferences, Display, Columns UI, Playlist view -> tab "General": tick "Enable sorting using column titles"
Thanks for the help. Still have some problems, though.
I've tried both of these and neither display properly. I checked my files and some have ratings saved in them.
I had this ticked already. I've tried unclicking/clicking other options to see if they conflicted but it seems not.
2. I'm using this code. symbol_rating is a global variable. I didn't have any problem with
it. Can you describe how yours displays improperly?
$repeat($get_global(symbol_rating),%rating%)
$get_global(special_color2)
$repeat($get_global(symbol_rating),$sub(5,%rating%))
3. Sorting doesn't seem to work in autoplaylist. You can try in a normal playlist.
It just doesn't display anything.
I tried this code and [UKNOWN FUNCTION] is displayed.
ahh that's a shame.
