Topic: [Title Formatting Help] Check if directory exists (Read 743 times) previous topic - next topic
I have to check if an arbitrary directory (inside library folder) exists. I will explain why I need this. I usually arrange my music this way:
+ Music
   + Artist 1
      + Album 1
      + Album 2
   + Miscellaneous // Misc songs from various artists (maybe also from the "Artist 1" or "Artist 2").
                   // Album tag NOT present.
Using facets, I can group all artist's songs from the "Miscellaneous" folder into just 1 "Various artists", simply checking if the %album% tag exists. My need is to exclude from the "Various artists" group those songs for which a folder in the main root "Music" exists, and group songs into the right facets artist view. Real example:
+ Music
   + Editors
      + An End Has a Start
      + In This Light and on This Evening
   + Miscellaneous
      - Editors - Munich.mp3
      - Foals - Spanish Sahara.mp3
My custom facets "algorithm" I was thinking is:
  • Build the full directory path from the current song eg. C:\Users\Gremo\Music\Editors. I can do this.
  • Check if the directory exists. This is the main issue.
  • If yes, output "%artist% (grouping Editors - Munich.mp3 with "Editors" submenu)
  • If not exists, output "Various Artits" (putting Foals - Spanish Sahara.mp3 into it)
  • Continue with the next song
Thanks for helping. Other solution accepted. If you can't understand my needs, just ask.
2. Check if the directory exists. This is the main issue.
Unfotunately this can't be done. You can only evaluate the inherent properties of a given file.
