Topic: foo_dsp_effect (Read 154119 times) previous topic - next topic
Re: foo_dsp_effect
Reply #402
Like the previous post, I would like to thank you for all your work
Personally I dream that you can see an interest to integrate foo_dsp_centercut and make it a bit more adjustable
Re: foo_dsp_effect
Reply #403
Whats that filter? What needs to be more adjustable in it? Is it a simple stereo seperation effect ala Amiga?
Re: foo_dsp_effect
Reply #404
I mean a wet/dry mixer instead of today on/off mode
Re: foo_dsp_effect
Reply #405
Will have to see what it actually does.
Uploaded beta 1 of 0.40. Hopefully works okay and fixes the current issues in the UI elements.
Re: foo_dsp_effect
Reply #406
I see on beta, by just changing IIR Filter Type will enable it even without check the Enabled
Re: foo_dsp_effect
Reply #408
It's fixed. :)
Re: foo_dsp_effect
Reply #409
Any other bugs I should know about?
Re: foo_dsp_effect
Reply #410
It's not bug but just cosmetic. Chorus and Echo have same description on status bar.
Re: foo_dsp_effect
Reply #411
I'll fix that when beta 3 comes.
Re: foo_dsp_effect
Reply #412
Beta 3 up, hopefully the remaining bugs with the other effects are fixed before merging in the new unreleased effects.
Re: foo_dsp_effect
Reply #413
Thanks mudlord, incredible plugin, can't wait to try the unreleased effects!
Re: foo_dsp_effect
Reply #414
My priority atm is ironing out the last bugs that are in there before adding in the other stuff that I worked on in a unreleased component. It would be nice to know if there is still any left. The obvious ones I see should be gone now at least.
Re: foo_dsp_effect
Reply #415
Thanks for the awesome plugin Mudlord.
Got a minor bug for you - Upon closing foo and re-opening the new playback rate checkbox doesn't stay ticked (but it is still enabled so needs a double click to disable again).
Also a pet peeve - personally I prefer the pitch / playback rate / tempo etc to be separate items as you had prior to the update, to be added as a layout item individually instead of clumped together, but this is just me.
Keep up the good work!
Re: foo_dsp_effect
Reply #416
The forgotten checkbox only applies when playback rate is selected on its own, or with pitch enabled also. Pitch will remain ticked on re-opening foobar but not pb rate. However when tempo is ticked, it remembers pb rate also after exiting foobar.
Re: foo_dsp_effect
Reply #417
Try beta 4.
It also has some new effects that I added.
I unfortunately had conflicting reports that people wanted the clumped together UI element since they use the component professionally in their DJ work.
So yeah, I am not sure what to do.
Re: foo_dsp_effect
Reply #418
@mudlord if I may  Im not sure how this works code wise finer grained control is always better so i would keep that the default but group them together via checkbox like  "enable DJ mode/professional workflow" ?  if possible as i said I am no expert so not sure that will work?
Re: foo_dsp_effect
Reply #419
From what I understand that will complicate things with the UI Element API interface. Which means I would have to create separate UI element instances for each dialog.
Thats just how DUI element design works I think :<
Re: foo_dsp_effect
Reply #420
mudlord,
You've added a compressor to 0.40 beta 4? I'm pretty sure it's from foo_dsp_effect but I'm easily confused. Anyway....
Just letting you know the Ratio option is labelled "Ratio: 1.00 ms". I assume that's not correct?
Also, the behaviour of the sliders is a little odd. It's no big deal, but as an example "release time" defaults to 200 ms, but if you adjust any slider it changes to 197.50ms and the next step up is 227.00 ms. It seems a bit odd you can't at least select the default value, or that it changes when you adjust another slider. Most of the them behave in a similar way.
Cheers.
Re: foo_dsp_effect
Reply #421
How does the Skip Track effect work? Is it a replacement for the foo_skip component?
Re: foo_dsp_effect
Reply #422
@yetanotherid those problems will be looked at for next beta. seems some of them are typos.
The compressor it implements is now from Windows itself, so the old compressor can be discarded. Which I will do sooner or later.
@Parole I think you are mistaken, my DSP set has no "Skip Track" effect.
Re: foo_dsp_effect
Reply #423
I had absolutely no idea Windows has a compressor.
I use my PC as my media player with RockSteady normalising the volume, courtesy of ffdshow, but is the built in compressor something a mere mortal can access?
Re: foo_dsp_effect
Reply #424
The compressor is a DirectX Media Object, been in Windows since Win98.
