Topic: Wavpack support in Mixxx ! (Read 2593 times) previous topic - next topic
Greetings to all ,
I thought some people here might be interested to know I've almost finished adding
WavPack support in Mixxx (www.mixxx.org). The code is functionnal and available
from launchpad ( https://code.launchpad.net/~beltoid97/mixxx/wavpack ). It will
probably be merged to the trunk eventually, after v1.8 is out , which should be
pretty soon.
It supports mono / stereo /multichannel files (will only open the 2 front channels)
with 8bit unsigned, 16 signed, 24s and 32s (sorry no 32-bit float) . It should work
with lossy or lossless files, but I haven't enabled hybrid .wvc support - I'll wait for
test reports before adding that in.
If you can run bazaar on your system, you're more than welcome to try
out this build !
~Happy new year~
