Topic: CUETools versions 1.9.5 through 2.1.6 (Read 1428182 times) previous topic - next topic
Re: CUETools versions 1.9.5 through 2.1.5 (current)
Reply #2950
The forum mangled my post. At the end of point 1, it should be:
"the box replaced my input with a [ 0 ] and sets the cursor to the left"
It seems "[ 0 ]" without the spaces gets processed as a numbered list item...
Reply #2951
Sorry for triple-posting: Any plans to add UTF-8 log writing?
Thanks I love this program. I use it a lot to process many rips.
Reply #2952
edit: I just tested it out:
Spoiler (click to show/hide)
It's alive!  :)
Thanks, after tinkering a bit with wine and playonlinux I got CUETools working with no problems. Fortunately I had my old windows config from the days of winXP floating around with all my presets and everything...
Before this I was running it with mono on linux, but that way only works with WAV files, now I can save an extra step of transcoding and some tagging... and verifying in one step is much easier.
Reply #2953
- install wine (any version really, it's been working for me for several years, I'm currently using 3.0rc6)
- install wine-mono (or whatever it is called on your distribution)
- create a new win32 prefix (WINEARCH=win32)
- install dotnet20sp2 using winetricks. It shows a couple of errors (i.e. "mono not installed", even though it is), but the process finishes fine
- install vcrun2008
- copy the CUETools folder to your prefix/drive_c/Program Files/
- launch CUETools.exe with WINEPREFIX set to your prefix
It takes a while to launch, but it does launch fine. The only problem I had was that configuring it as I wanted crashed on some steps.
What I did was configure it as I want on a windows machine, then copy the settings.txt to my linux one.
is there any benefit to install wine-mono in first place when dotnet20sp2 gets installed right afterwards? afaik, mono is a replacement for dotnet and gets uninstalled by winetricks when you attempt to install dotnet anyways.
Reply #2954
A word of warning to those using CUETools 2.1.6 on linux (WINE): Do not use the libFLAC decoder! For some reason, it doesn't produce valid output. The audio checksum differs on every decoding attempt (verify/encode), and of course no accurateRip/CTDB match is possible.
i just tested and split an accurate flac image of mine with libflac and with cuetools encoder under wine 3.0 rc5.
the result is still accurate, but the bitrate of the libflac encoded files are higher by 2 bits and the encoder is also much faster!
which version of wine do you use? have you tried a new prefix?
Reply #2955
sanskrit44, did you test using the libFLAC decoder? (I haven't tested myself, just looking for more information)
[attachimg=1]
korth
Reply #2956
no, i have tested the encoders. no differences between libflac and cuetools on my side. btw it was a wav image that i had split up. my mistake.
Reply #2957
ok, i have tested again (flac image this time) and set libflac encoder + decoder and the result is still accurate.
Reply #2958
Do you know where I find this settings.txt file? I have CUETools running in an XP VM. I would love to not have to use a VM to run CUETools, it's the only WIndows program I use. Thanks!
Reply #2959
Wow, I've been running CUETools 2.1.5 in kvm (Linux VM) with XP for years. Running CUETools 2.1.6 under wine 3.0 on the same system is 7.5x faster (6 seconds vs 45 seconds) for a verify on the same album. Fortunately I did not encounter any crashes using wine, all the config screens worked fine. The font size is microscopically small on my 4K monitor though.
Reply #2960
I was wondering if there is any possibility to add a "blank/unknown" option for metadata, or simply a button to erase all the info.
I often encounter some singles that don't have the right information in the DB, but CUEripper will auto-select the first result. Then, I have to remove all the fields one by one (I do just override some, but there are some of the fields I never manually fill in, like barcode, so I still need to delete them).
Reply #2961
I often start CUETools, and even if my computer is not a beast, I'm noticing the program is a bit slow to start.
I have had unchecked "Check for updates" to avoid network request at startup, but that was not the culprit.
So, I just investigated a bit using Process Monitor:
* One of the main culprit seems to be csc.exe. It seems that at each startup you are compiling stuff on the fly, which is temporarily put in the Windows temp folder. Maybe the compilation results could be cached/stored and reused? (I guess that's what Paint.net does)
* The form drawing might also takes some time. Maybe raising the .NET Framework version could help? 2.0 is quite outdated... (on a related note, I found an article that might be of interest)
Reply #2962
Yeah, the csc.exe problem was also recently discovered with CUETools EAC plugin. Turns out that how Xml serialisation works in .net - it compiles the data types to an Xml serializer class on the fly and doesn't even cache the result, but it's possible to pre-compile it and ship with the product. It's already fixed in the plugin, will be fixed in the next CUETools release also.
As for WPF/4.0, i've been playing with it, and i plan to do it sometime. CUETools has so many controls though, that creating a WPF UI for it is a LOT of work.
CUETools 2.1.6
Reply #2964
Hey, thanks for the hint, I am interested.
As to you wondering what the update does, the answer can be found in the post right above yours.
Best regards
deus-ex
Reply #2965
I'm only starting with 2.1.7 work. Version bump is the first step so 2.1.6 can be now officially declared the stable version. I'll update the change log at some point, but for now there's not much news, mostly housekeeping. Updated libFLAC version, added support for tagging opus files, switched to using .NET Framework 4.0... I guess the only exciting thing is BLUTools, which is in very early stages, and is meant to extract PCM audio tracks from audio Blurays. Just point it to an input folder with unencrypted Bluray copy, choose output folder, select a title set etc and click the copy button.
CUETools 2.1.6
Reply #2966
How can I connect a new Monkey's Audio 4.33 as an external encoder?
Reply #2967
version 2.1.7 does not copy the images from iso.wv to the folder with the converted CD. In 2.1.6 is OK.
Reply #2968
External encoders must support piping (stdin/stdout).
Prerequisites for 2.1.7
korth
Reply #2970
but it was Monkey's Audio that I failed to get to work
Are you using a patched version that supports stdin/stdout?
This will work in 2.1.7
mac.exe v3.99 (a special version that is patched to support stdin/stdout)
put mac.exe in CUETools folder
Extention: ape
Path: mac.exe
Parameters: - %O -c%M
Modes: 1000 2000 3000 4000 5000
or use the built-in MAC_SDK
If you don't see the built-in MAC_SDK then check the Prerequisites
korth
Reply #2971
Extention: ape
Path: mac.exe
I know about the built-in encoder. I was interested in the encoder of the latest version 4.33, but it does not work. Special encoder. to which you gave a link too refuses to work . Exception returned code -1.
Reply #2972
IIRC this special version works with stdin on Linux, but not on Windows.
Reply #2973
I'll soon update CUETools to Monkey's Audio 4.33. In my tests it's going to be slightly slower though, due to the lack of assembly optimisations present in the old library. I'm too lazy to port them over.
CUETools 2.1.6
Reply #2974
please still correct copy of images from an iso iso.wv
