Topic: A problem for Lame (Read 4826 times) previous topic - next topic
A problem for Lame
It's been several times that when listening to a French woman singer not everything was totally alright to me though I was not able to properly abx it.
With 3.98b6 the problems seemed to have disappeared - until today.
Here is a snippet from the track 'Là ou je suis née' from Camille's album 'Le sac des filles': [attachment=4131:attachment]
In the phrase 'il n'ya pas de phares' the ph-sound is not correct. I just abxed it 10/10 using Lame (3.98b6) -V0.
Strange thing is with all these french singer problems: I can hear the problems while just listening intensively, but when it comes to abxing I'm having a hard time.
lame3995o -Q1.7
opus --bitrate 140
A problem for Lame
If you can exclude placebo, so that this "pattern" is reproducable, then i may have an explanation for this "strange" phenomenon: subconscious and conscious perception. When you ABX, then you quite probably shift focus to conscious perception. The other listening situation where you describe that you can often notice that something is wrong, may be a more "intuitive and heuristic" approach to listening. How to check for that is quite simple: Dont change your mindstate when ABXing.
A problem for Lame
If you can exclude placebo ...
As long as I can't get proper ABX results I can't of course. In a sense I'm quite happy I finally was able to really abx this kind of problem.
...When you ABX, then you quite probably shift focus to conscious perception. The other listening situation where you describe that you can often notice that something is wrong, may be a more "intuitive and heuristic" approach to listening. How to check for that is quite simple: Dont change your mindstate when ABXing.
Guess that's the explanation. Unfortunately I'm pretty unsuccessfull so far shifting conscious mindstate to nonconscious when abxing.
lame3995o -Q1.7
opus --bitrate 140
A problem for Lame
... Strange thing is with all these french singer problems: I can hear the problems while just listening intensively, but when it comes to abxing I'm having a hard time.
It needs a lot of concentration because the differences are so small, but I didn't have problems with finding them. I don't know if I can describe the differences correctly, but I would say that the singer's voice has lost some of the crispness (it doesn't "sparkle" as much) and the long vowels have slightly different pitch towards the end of each breath in the -V0 encoded sample.
foo_abx 1.3.1 report
foobar2000 v0.9.4.5
2007/12/31 00:11:25
File A: U:\test\Lame Problem\LaOuJeSuisNee.flac
File B: U:\test\Lame Problem\LaOuJeSuisNee (3.98b6-V0).mp3
00:11:25 : Test started.
00:14:20 : 01/01  50.0%
00:15:21 : 02/02  25.0%
00:15:46 : 03/03  12.5%
00:16:22 : 04/04  6.3%
00:16:44 : 05/05  3.1%
00:17:40 : 06/06  1.6%
00:18:26 : 07/07  0.8%
00:18:48 : 08/08  0.4%
00:19:27 : 09/09  0.2%
00:19:53 : 10/10  0.1%
00:19:55 : Test finished.
Total: 10/10 (0.1%)
