Topic: A wav file which I cannot convert to mp3 (Read 9379 times) previous topic - next topic
The subject says it all.
A corresponding topic is here.
Audacity did the trick.
it's not at all clear to me why you would want to convert it anyway. the original file is smaller than the resulting mp3.
Perhaps this is why?
Duration:0:00.821 (13130 samples)
Sample Rate:16000 Hz
Channels:1
Bits per Sample:4
Bitrate:64 kbps
Codec:IMA ADPCM
Encoding:lossy
John
My compiles and utilities are at http://www.rarewares.org/
Player compatibility?
An MP3 file can be made to be smaller than this source file. I used foobar 2000 v.0.9.4.2 beta 2 and LAME 3.97r for these:
--noreplaygain --preset 40 -m m --resample 24 --lowpass 11
[attachment=2729:attachment]
--noreplaygain --abr 24 -m m --resample 16 --lowpass 8
[attachment=2730:attachment]
--noreplaygain -m m --resample 16
[attachment=2731:attachment]
The first file has the best audio quality of these three (the command line is my usual speech setting for LAME MP3).
Alex B, are you can upload codec LAME 3.97r?
[quote author=ge-de link=msg=496021 date=1180788171]Alex B, are you can upload codec LAME 3.97r?[/quote]
"r" means the offcially released 3.97 version. The release was quite new back then and I wanted to differentiate the used version from the 3.97 betas.
LAME 3.97: http://rarewares.org/dancer/dancer.php?f=109
Alex B,
There is an Audio Identifier's screenshot:
To me it is necessary LAME 3.97r.
Whether you have it?
I cant convert this wav file no matter what software i use!. Can anyone help?
The file has 9 channels, which may be the problem.
try: lame -r -v fd.wav fd.mp3
Ok, if it has 9 channels, that could be a problem. Maybe "audacity" or some other audio editor may help.
khajah,
9 channels!  Are you trolling?
Anyway, here you go: (attachments)
EDIT
Adobe Audition thinks that the 9 channels are as follows:
front left, front right, center, LFE, left surround, right surround, back center, side left & side right.
Would you mind explaining where did you get such a file and what you would like to do with it.
