Topic: 0.9.2 beta 4 released (Read 41779 times) previous topic - next topic
* Support for realtime DSP preset editing
Could anyone please tell me what is that supposed to be?
For example, now when you select Equalizer in DSP manager and do "configure selected", the you can change the settings and hear the effect. In the previous version you had to press OK first.
I suppose this will affect other DSPs in a similar way.
A couple of requests for using the new Nero AAC encoder.
1)  Ability to select neroAacEnc_sse2.exe instead of the non-sse2 version.
2)  Ability to have the extension m4a instead of mp4.
Going to set up a custom encoder for now.  Thanks for all the work.
1) You could just rename it to neroAacEnc.exe. Don't you rename oggenc2.exe to oggenc.exe for easier use?
2) Agree.
For real, it works! (Not for resampler though  )
stimulating the audio nerve directly
When trying to load flac files in 092 b2 encoded with FLAC v1.1.2a I get this error
Failed to load DLL: foo_flac.dll
Reason: This component is missing a required dependency, or was made for different version of foobar2000.
Failed to load DLL: foo_flaccer.dll
all my other flac files work, any ideas?
the strange thing is that the songs still play fine...
get rid of foo_flac and foo_flaccer. they are both useless as foo_input_std has FLAC installed into it. they are also incompatible with 0.9 because of the fact that all 0.83 plugins don't work with 0.9
thanks heaps worked like a charm ,just wondering why it only came up as an issue, maybe the flac fronend installed the dll's
I have a small suggestions and one bug found in fb 0.9.2beta playlist manager.
First my suggestion:
Plz add a transparency slider to the equalizer !!!
Next a small bug in playlist manager:
because of missing drag&drop ability of playlist-tabs (that would be a great thing) and missing shortcut to move tabs left/right I have used the playlist manager. When moving lower playlists to the top (ctrl+shift+up), the moving playlist stops one before top. Maybe it's better to try it out, you will see what I mean...
Now that specifying what tags we want written to our files is only available though the tag type option, would it be possible to have that merged with the properties dialog box so that me may alter our tags and select what type they should be in one step?
Reply #35
well, one thing that I think I haven't seen before is context menues for windows folders! My dream came true! (had to install older version of foobar just to have them and then delete and put new one in same folder before)...
Reply #36
I'll update the thread-title!
edit: Unfortunatelly this has to be done by a Mod - I have not the needed privileges.
Reply #38
Thank you very much!
By the way this version seems to work smoothly for me!
Reply #39
Are there any plans to support the "ORIGARTIST" ID3v2 field in the final version? I've just realised that it's not displayed.
(Maybe a few other fields are not recognized yet, but i'm missing the ORIGARTIST currently)
Reply #40
The name in foobar for that frame is ORIGINAL ARTIST
Reply #41
Thnx. It was apparently a problem with Special file infobox's reload function. After reloading from foobar's propertities window it appeared.
btw. the same people using different avatars on different forums is confusing a bit
Reply #42
Thanks, Peter and foosion!
Now MP3+CUE works fine. Waiting for an updated version of foo_ape (or is it already there?).
Gambit  test-tast-tust
Reply #45
ARTIST WEBPAGE URL
COMMERCIAL INFORMATION URL
CONTENT GROUP
COPYRIGHT
FILE WEBPAGE URL
ORIGINAL ALBUM
SOURCE WEBPAGE URL
UNSYNCED LYRICS
WRITER
ISRC
REMIXED BY
ENCODING SETTINGS
ORIGINAL RELEASE DATE
OWNER
PUBLISHER URL
I'm sure you can find the frame names by yourself
Reply #46
ARTIST WEBPAGE URL
CONTENT GROUP
COPYRIGHT
FILE WEBPAGE URL
ORIGINAL ALBUM
SOURCE WEBPAGE URL
UNSYNCED LYRICS
WRITER
ISRC
REMIXED BY
ENCODING SETTINGS
OWNER
PUBLISHER URL
Wow, thanks a lot. I didn't realize I missed out so many
Now all we need in foobar is a way to remove items from the 'Field name' list again (typo's)
Reply #47
You can already wipe out the history with an right click on the drop down box. Although you can't remove specific entries. EDIT: you can
Reply #49
Nice, didn't knew that. Thanks for correcting my misinformation.
