Topic: 0.9.2 beta 4 released (Read 41771 times) previous topic - next topic
http://foobar2000.org/beta/index.html
7. May 2006: 0.9.2 beta 2 was obviously released.
18. May 2006: 0.9.2. beta 3 released
27. May 2006: 0.9.2 beta 4 released
awesome any chance of a changelog?
thanks for the update foosion, running it at the moment no problems thus far.
any substantial changes to look for?
I see the converter now supports the latest nero aac encoder. Good.
ReplayGain calculations still get applied only after a further mouse click. Bad.
Can't seem to find Kernel Streamimg in this build.  Am I missing something?
APL support broken... bad
stimulating the audio nerve directly
I just updated and whenever I try playing a song I get
playback error
Unrecoverable playback error: Bug check
Worked fine previously. It occurs even if I change my output device. Only other things different were I updated KS and got the new convolver, but it still happens if I remove them from the components folder.
Does it have LAME profile detection?  I'm itching to combine that with the cool new rename directory tool to add the lame settings to my collection.
Any chance the keyboard shortcuts for Volume set to 0 dB, 3dB, 6dB, 9 dB will return?
I have downloaded the new nero aac encoder. Can you enlighten me as to which folder I should unzip it to for fb2k 0.9.2b to recognise it? TIA.
I've got mine in the foobar2000 folder, where the foobar2000.exe resides. You may have to add a new encoding preset with "Add new"...
You can throw it anywhere. If fb2k doesn't find it, it will ask you where it is.
This was moved to the Monkey's Audio component which will be updated with foobar2000 0.9.2 final.
That's nice, however I've been experiencing problems with MP3+CUE and MP3+APL playback. When you play an MP3 file, seektables are remembered in RAM, so seeking works faster next time (as foobar2000 FAQ says), but if playing CUE/APL, foobar2000 will read through the whole MP3 the next time you play it. This happens only for CUEs which split an MP3 to multiple tracks. Play last track of a 70 min album, start it again and you'll see. That was always fine with foobar2000 v0.8.3, the very first betas of v0.9, but then it works the way I described, and in v0.9.2 too.
* Support for realtime DSP preset editing
Could anyone please tell me what is that supposed to be?
P.S. “Please select a subpage.” looks ugly.
Sort of implies that there shouldn't be a delay when changing or adjusting the settings of a DSP. Doesn't seem to be the case though...
Oh you're right...
I have forgotten to do a "Reload infos from file(s)" hehe
A couple of requests for using the new Nero AAC encoder.
1)  Ability to select neroAacEnc_sse2.exe instead of the non-sse2 version.
2)  Ability to have the extension m4a instead of mp4.
Going to set up a custom encoder for now.  Thanks for all the work.
Answered your own question?
Techspot.com Editor
No, he didn't. Sliders offer a quicker way to change the encoder settings.
