Topic: [0.9]Rating with Masstagger (Read 45213 times) previous topic - next topic
Hi, Your script RatingDown dosen't work! Both Scripts Add +1!?
I reuploaded it. It should now work.
Great! Now it works fine
It of course would be also possible to create extra Scripts for the ratings from 1 to 5. I personally think there is no need for it.
@Tiis: Good to hear, that it works fine for you.
sorry. how do i load up these scripts?
snively:
It's quite easy. Rightclick on a playlistitem. Choose "Tagging" -> "Edit tags". And now you can click "Load from file".
Have a nice evening!
I can use the scrips, but how did you assign the shortcuts to it??
Mr. Happy: Goto "Preferences" -> "General" -> "Keyboard shortcuts" -> "Add new" -> enter in filter list by: "Rating". Now select one of the two scripts and assign in the textbox beneath the shortcut you want to use.
Problem is when I enter "Rating" in 'filter list by' the window below goes empty....  Should I insert the scripts somewhere (or copy them to a specific folder_??
[a href="index.php?act=findpost&pid=373824"][{POST_SNAPBACK}][/a]
You should do this first:
snively:
[a href="index.php?act=findpost&pid=373535"][{POST_SNAPBACK}][/a]
Since there is no more quicktag I decided to build my own Masstagger scripts.
[a href="index.php?act=findpost&pid=373263"][{POST_SNAPBACK}][/a]
Is the above mean that there isn't the slimest chances for quicktag?!
While the scripts are simple enough, I think it's simpler this way:
RatingDown - Replace 0 with whatever minimum rating you want
$max(0,$sub($if2(%RATING%,3),1))
RatingUp - Replace 6 with whatever maximum rating you want
$min(6,$add($if2(%RATING%,3),1))
They also look nice. Mine got complicated, since I had to work around a problem, when there was no ratingtag.
Do your scripts work with unrated files?
Yep  They default to 3 in this case.
snively:
I can't seem to get this to work either, I load the file then what am I supposed to do? Under tagging > scripts all mine ever says is [last used], am I supposed to see RatingUp in there too?
Have you clicked "Load from file"?
Yeah, right clicked on a file tagging > edit tags then load from file and this is what I get:
Like I said I never have seen anything other than last used in the dropdown box.
nice done.
id like to edit your script, in order to tag my files with "album_rating", but it doesnt work if i change the %rating% into %album_rating%, any ideas?
Ah, now I see. You have to write "Rating +1" or "Rating -1" down, where "last used" is written. Then you have to click "save". Now you have to repeat it for the second script.
Does this solve your problems?
nice done.
Should work. Have you pressed the "save"-button after applying the changes?
yes, when i did it, it writes the whole code-expression you use in these scripts into my properties field: album_rating.
the rating of single files goes well.
I think I know, whats going wrong. I'll post tomorrow. I'm quite busy right now.
What you could try. Copy the expression and click "Clear", then "Add". Now play around
Yes it does, although I would have never thought of doing that. Thanks.
Good!
@generalverdacht: Have you also suceeded?
unfortunatly not...
