Topic: No DTS from WAV (Read 4006 times) previous topic - next topic
No DTS from WAV
I just installed this card and  have problems playing back dts-files in .wav-Format.
Playback from DVDs works perfectly, both AC3 and DTS.
I got Win XP Pro here, and I tried many hints written in this forum,
played with graphedit, installed dtswavsource, etc.
but I only get white noise playing back the files, with either player
(winamp, mpc, wmp, bsplayer, zoom player, windvd.
The settings on all players are, as far as I know, correct,
which means I activated spdif-passthrough wherever possible.
Any hints on this problem?
Anything is appreciated!
Thanks in advance for your answer.
Koxx
No DTS from WAV
Are you using an ASIO plugin for Winamp? Make sure you have the equalizer (and any EQs on your soundcard) off.
No DTS from WAV
Hi, thanks for your reply!
Yes, I tried it with ASIO, too.
I used the ASIO4ALL Program
and the ASIO Output plugin from: http://www3.cypress.ne.jp/otachan/
Any EQ is turned off, but still noise
Any other idea?
Koxx
No DTS from WAV
If you are trying to send 44.1 kHz DTS output through S/PDIF to an external decoder it is not going to work because your soundcard resamples the signal to 48 kHz. A DTS wave file is usually 44.1 kHz. DD and DTS audio tracks on standard DVD-Video discs are 48 kHz.
An Envy24 chip based card could do that, for example Terratec Aureon Space.
[span style='font-size:7pt;line-height:100%']Edit: added "usually"[/span]
No DTS from WAV
[{POST_SNAPBACK}][/a]
According to this thread
[a href="http://www.hydrogenaudio.org/forums/index.php?showtopic=3982&hl=]http://www.hydrogenaudio.org/forums/index....wtopic=3982&hl=[/url]
it's possible with the XFire 1024.
Sadly I cannot reach Mr. S_O.
Koxx
No DTS from WAV
Sadly I cannot reach Mr. S_O.[{POST_SNAPBACK}][/a]
I read quickly through that thread and I think S_O explained that he converted the 44.1 kHz source files to 48 kHz.
Terratec says this:
External connectors.
Digital-Out, optical, 48kHz (TOS link)
2 x Line-Out, stereo (3,5 mm)
Line-In, stereo (3,5 mm)
Mic In, mono (3,3mm)
MIDI/Joystick Interface (IBM 15 pin Sub-D)
Onboard connectors.
Digital-In, 32, 44.1 and 48kHz
2 x CD audio In, stereo (MPC3)
Aux In, stereo (MPC3)
Wavetable connector (WaveBlaster pin compatible)
From: [a href="http://supporten.terratec.net/modules.php?op=modload&name=Sections&file=index&req=viewarticle&artid=6]http://supporten.terratec.net/modules.php?...article&artid=6[/url]
[span style='font-size:7pt;line-height:100%']Edit: submitted accidentally before it was ready.[/span]
No DTS from WAV
You can play flawlessy DTS or DTS/Wav files with the method shown here
