Topic: DTS from acid or smth. (Read 5533 times) previous topic - next topic
Hello,
Is there possible to make six waves from my acid pro project ? (Because i can't render audio as dts). And if it isn't, maybe there are some other programs which can do the same or similar jobs ?
P.S are there any high quality loops over the net (for ex. 96hz) ?
thanks
[a href="index.php?act=findpost&pid=278240"][{POST_SNAPBACK}][/a]
Sure. It's unintuitive, but you can make mono stubs with ACID Pro. In ACID Pro 4, you choose File, Render As, and choose Wave (Microsoft). Then you need to change the profile. Next to Template: choose Custom. In the dialog that pops up, for the Channels: option, choose Mono. Choose OK, then Save. Counter-intuitively, this will not down-mix the project, but will create six mono files named "ProjectName Left.wav" etc.
I have not encountered any.
"Facts do not cease to exist just because they are ignored."
—Aldous Huxley
I use acid pro 4 only for the mixage of track audio.
Nevertheless, you can use Surcode Dts.
[a href="index.php?act=findpost&pid=278354"][{POST_SNAPBACK}][/a]
I have ACID Pro 5 and I regularly export to 6 or 7 channels and then encode with the ProSeries DTS encoder which is 96/24 capable (in 5.1 only). The SurCode encoder is much cheaper but it does not do 24 bit 96 encoding or 6.1 discreet. SONY have recently made available 24 bit loop collections  of which I have 2 sets and they are absolutely supurb. Keeping the 24 bit in tact is quite nice so for me the extra is worth it. Unfortunately the loops are not 96khz but 44.1 (that was a let down when I got them)
no2dvd, are you sure you can hear the difference between 24/48 and 24/96?
(plz watch out TOS #8 when you reply)
[a href="index.php?act=findpost&pid=289533"][{POST_SNAPBACK}][/a]
Did he say at all that he can hear differences?
As I see it, he is expressing regret that loops are at 44.1kHz. He might be referring to the fact that it's better to do processing on higher frequency sampling rates.
As I see it, he is expressing regret that loops are at 44.1kHz. He might be referring to the fact that it's better to do processing on higher frequency sampling rates.[a href="index.php?act=findpost&pid=289538"][{POST_SNAPBACK}][/a]
Yes and also if he has the source in 24/96 and he wants to release it in 24/96, it could be useful. But there is also the possibility that it doesn't worth it.
From my experience, bit depth is more significant than frequency rate for processing. Also, if you resample a 48 to 96 then make the processing and back to 48, I think you will have a worst result than make it gently in the native frequency rate.
That's right, it's not so important to hear the difference as it is to be able to say with a straight face that 'This is a DTS 96/24 recording"
[a href="index.php?act=findpost&pid=289658"][{POST_SNAPBACK}][/a]
You didn't really answer the question.
And it's important to be sure that you do hear the difference, otherwise you could bother for nothing (and maybe for a worst result).
[a href="index.php?act=findpost&pid=289713"][{POST_SNAPBACK}][/a]
I don't have any 96 khz loops so I can't tell you. But upsampling from 44.1 to 96 doesn't make them worse. Of course I want to bother if I have 24 bit loops, I don't want to use 16 bit DTS if I can use 24 bit.
