Topic: USB/FIREWIRE support added to foo_cdda.dll (Read 17082 times) previous topic - next topic
I had a problem using foobar2000 with firewire or USB attached devices, foobar2000 did not recognize the devices. I couldn't find any solutions on the internet so I patched the foo_cdda.dll myself.
For anyone else that has the same problem, here is a copy of my patched version of foo_cdda.dll with firewire/usb support added.
Two files are attached:
foo_cdda.zip which contains the patched foo_cdda.dll, just unzip in the components dir.
scsipt.zip which contains the patched akrip source file, scsipt.c. This can be unziped in the foo_cdda/akrip directory in the SDK package.
[attachment=1366:attachment] - Non debug version ;-)
[attachment=1365:attachment]
Nice, thanks you
Is there another link to the downloaded file? I downloaded successfully but it gave me an error message when I opened it indicating the file was corrupted.
[{POST_SNAPBACK}][/a]
Ditto! I'm looking for exactly this fix (see my thread from [a href="http://www.hydrogenaudio.org/forums/index.php?showtopic=31948&st=0&p=278275&#entry278275]last night[/url]). But I can't get the file to download.
PEace,
Mike
The upload forum is seemingly broken, when used with Firefox. With IE I could DL anothe uploaded file which was corrupt with FFX, and all I got was an "index.php". Well, I renamed it to index.zip, and voila', it could be unzipped. Give it a try
Life is Real...
(But not in audio :) )
I checked the download to make sure the zip is not corrupt. Works fine for me.
But just is case, here is a rar.
Just for the record: I had trouble opening the file with Windows XP's built in zip support - always got a corrupted file message. Once I tried it with [a href="http://www.7-zip.org/]7-zip[/url] (which is freeware), everything was fine and dandy.
Now I only need to find out whether it helps ...
Mike
Mike
[a href="index.php?act=findpost&pid=278473"][{POST_SNAPBACK}][/a]
YES!!
It works perfectly. My USB player is now recognized.
Where do I send the flowers?
Mike Gray
