Topic: Time Length Audjustment Tools Quality Comparison (Read 3555 times) previous topic - next topic
ok finally i found the time to do a quality comparison of various tools able to do timelength adjustments on audio streams
Test Setup
for my comparison i used the great ABC/HR audio comparison tool (simply a must when doing "ear-based" quality comparisons  )
i tested the following tools:
- Audacity 1.2.1
- Adobe Audition 1.0
- BeSweet v1.5b27 - OTA
- BeSweet v1.5b28 - Soundtouch
- Sonic Foundry Sound Forge 6.0
- Prosoniq Timefactory 1.6.1
i tested a 12.721 secs long stereo sample with 44.1khz samplerate
the original sample was a (not good quality) recording in mp3 format i had sync problems with when combining with a 25fps video stream
with 24.996fps the sync problems were gone, therefore i decided to use this situation for doing a 24996/25000 (99.984%) audio conversion, together with this quality comparison to be able to get sync at 25fps at the maximum quality possible
First of all, as most tools offer different options, i did some internal tests to find out which setting would bring the best result:
1) Audacity
i noticed that doing a length change from the source mp3 directly in audacity will lead to less quality than if feeding audacity with a .wav -> therefore i decoded the .mp3 to .wav in besweet first
i compared a tempo change only vs. tempo->pitch change sample => tempo-change only provided better quality (especially regarding the background noise which the pitch change somehow seemed to filter out)
2) Audition
i compared a tempo change only vs. tempo+pitch change sample => tempo+pitch provided better quality (the background noise sounded more than the one in the source)
3) Besweet Soundtouch
i compared a sample using the "rate" option (tempo+pitch change) vs. a tempo only sample => the range sample was better (the difference was not that big tough, when compared to the other pretty clear results)
4) Sound Forge
i compared a sample using the "mode 1" option vs. the "mode 3" option offered => mode 1 was better
5) Timefactory
i compared with vs. without "preserve formants" => without was better (the difference was not that big here too)
this means that finally i tested the following settings:
- BeSweet v1.5b27: OTA - Change Frame Rate from 24496 to 25000
- BeSweet v1.5b28: -soundtouch( -rate 0.99984 )
- Audacity 1.2.1: Change Tempo: 0,99984
- Adobe Audition 1.0: Time/Pitch -> Stretch: Ratio: 99.984, Precision: High, Stretching Mode: Resample (preserves neither)
- Sonic Foundry Sound Forge 6.0: Time Stretch: Mode 1 99,98%
- Prosoniq Timefactory 1.6.1: Duration 99.984%, Algorithm: Polyphonic (best)
Results
first of all some statistical results:
Tool  Length (secs)    Size (bytes)
Source  12.721  2.244.140
Timefactory    12.719  2.243.780
Audition    12.719  2.243.780
Sound Forge    12.719  2.243.800
BS (OTA)    12.691  2.238.824
Audacity    12.599  2.222.508
BS (Soundtouch)    12.595  2.221.808
note that the correct length of the output should be 12.719 secs (12.721x0.99984)
now the quality comparison results from the double blind listening test in abc/hr (max. 5.0/min. 1.0 points possible) and my comments on the different tools:
Prosoniq Timefactory    5.0 (no difference to the source hearable)
Adobe Audition  5.0
Sound Forge  4.3
Besweet (Soundtouch)    2.7
Audacity  1.5
Besweet (OTA)  1.0
ABC/HR Version 0.9b, 30 August 2002
Testname: Time Shorten Test ( 99.984% )
1L = C:\Eigene Dateien\Eigene Videos\Test\Audio\timestretch\bond_soundforge-mode1.wav
2L = C:\Eigene Dateien\Eigene Videos\Test\Audio\timestretch\bond_ota.wav
3R = C:\Eigene Dateien\Eigene Videos\Test\Audio\timestretch\bond_prosoniq-P0 0 T1.00  1.wav
4L = C:\Eigene Dateien\Eigene Videos\Test\Audio\timestretch\bond_audacity.wav
5R = C:\Eigene Dateien\Eigene Videos\Test\Audio\timestretch\bond_soundtouch-rate.wav
6R = C:\Eigene Dateien\Eigene Videos\Test\Audio\timestretch\bond_audition-tempo-pitch.wav
General Comments:
1L File: C:\Eigene Dateien\Eigene Videos\Test\Audio\timestretch\bond_soundforge-mode1.wav
1L Rating: 4.3
1L Comment: 11.6 - 12.7 secs -> very small detail missing
2L File: C:\Eigene Dateien\Eigene Videos\Test\Audio\timestretch\bond_ota.wav
2L Rating: 1.0
2L Comment: horrible
4L File: C:\Eigene Dateien\Eigene Videos\Test\Audio\timestretch\bond_audacity.wav
4L Rating: 1.5
4L Comment: seems to have a stereo problem - after ~2 secs the right channel becomes stronger
5R File: C:\Eigene Dateien\Eigene Videos\Test\Audio\timestretch\bond_soundtouch-rate.wav
5R Rating: 2.7
5R Comment: 0.0 -1.5 secs -> the background noise seems to be at a lower volume
ABX Results:
Original vs C:\Eigene Dateien\Eigene Videos\Test\Audio\timestretch\bond_soundforge-mode1.wav
   61 out of 92, pval = 0.001
Original vs C:\Eigene Dateien\Eigene Videos\Test\Audio\timestretch\bond_ota.wav
   9 out of 9, pval = 0.002
Original vs C:\Eigene Dateien\Eigene Videos\Test\Audio\timestretch\bond_prosoniq-P0 0 T1.00  1.wav
   14 out of 29, pval = 0.644
Original vs C:\Eigene Dateien\Eigene Videos\Test\Audio\timestretch\bond_audacity.wav
Original vs C:\Eigene Dateien\Eigene Videos\Test\Audio\timestretch\bond_soundtouch-rate.wav
   24 out of 31, pval = 0.002
Original vs C:\Eigene Dateien\Eigene Videos\Test\Audio\timestretch\bond_audition-tempo-pitch.wav
   42 out of 85, pval = 0.586
Conclusion
Sad but true, the opensource time adjustment tools cant keep up qualitywise with the commercial tools at the moment
I only tested a small time length adjustment but it was already enough to sort a whole bunch of tools out qualitywise, not to speak of that the opensource tools also werent able to hit the desired exact length
If you really need to change the length of your audio stream and you cant solve the problem with simply changing the framerate of your video, i would recommend you to use Prosoniq Timefactory or Adobe Audition as i couldnt hear a difference to the source when using these two tools in this test, and believe me i really tried to
Nice! Thanks for this Bond.
I wonder how good/bad SoX would be...
I'm not surprised that TimeFactory won. It's really an excellent tool (and the price reflects it). I only find it kinda strange that it's output was the farthest from the desired lenght.
Prosoniq plans to release MPEX3 soon, and that will probably spawn a new TimeFactory version (maybe even better! OMG!)
I'm pleasantly surprised at Audition. Didn't know it was so good.
And I had no high expectations for Audacity and BeSweet, really
