Topic: TTA: The free lossless True Audio compressor (Read 32345 times) previous topic - next topic
Seems the Winamp plugin can't seek album-sized files?
No problem. Winamp can to seek album-sized files. We are don't keep a 'seek map' in a file. Plugin requires to build a 'seek map' at start. All of TTA plugins do it in background while playing. This mean that seek command will be queued if seek map is not ready. It requires some time for album-sized files.
Indeed, it takes 40 seconds of playback here to build a seek map for the album, while for a 5 min track it appears ready from the start.
ald
Does TTA support other then 44.1 sampling freqz, e.g. 96 khz ?
ald
it does .
One more thing ... foobar2k plugin seems to redraw (continuously) foobar main window during tta file playback
@ald
I successfully compiled ttaenc on MacOS X! (just had to remove the #include <malloc.h>, you should stick to standards)
But it doesn't let me encode wav files:
File:    [Cesaria Evora - Voz D'Amor - Amdjer de nos Terra.wav]
Error:  not compatible file format
I used EAC to create the wav file, any idea about the error?
I'm just guessing, but it sounds like an endianness issue in TTA source code.
You may be right foosion, it looks like the program interprets file data as longs which will misbehave on PPC hardware.
Reply #32
Yes. TTA code has no support for Big Endian byte order.
Please wait for the next release of the TTA encoder.
-- Alexander
ald
I found TTA 3.0 encoded files slight bigger in size that TTA 2 encoded files ( both were encoded with the same parameters )
Is it a result of seek map addition or compression algorithm was changed?
Reply #34
ald -
also, 3.0 still has doesn't compile cleanly for *nix/linux from the source tarball provided (same error as i reported for the pre-3.0 release)
later
Reply #35
I havent seen this ebing mentioned anywhere, so i thought i announce it here in this thread :
http://corecodec.org/projects/tta/
TTA is a corecodec project now, and as soon as Alexander will give us a hint that his current 2.0 version is stable enough we will try to make DirectShow based en/decoder, as well as matroska muxing/playback capability for it ..... stay tuned, there is more to come from Corecodec .....
Reply #36
Sorry for later answer,
Sorry for no announcement about TTA 3.0.
We are waiting for Neuston's firmware release.. It should appear at end of this week, but TTA 3.0 already released. We decreased compress ratio in version 3.0 (TTA1 format) for  hardware compatibility. At now it's a top compression level for audio files, which can be played by the most of hardware players. I going to open CVS at corecodec.org. In other branch of TTA project we will try to get a maximum compression. It will be different TTA format.
- TTA1 format release (fixed compression mode);
- more faster in operation speed;
- precalculated seek map added into the TTA format;
- can decode files with errors;
- different byte order support;
- reduced memory requirements for hardware playback.
- TTA development library for HW players released;
- all supported plugins were updated;
All of the plugins and library code were published under LGPL.
TTA1 format description:
http://tta.corecodec.org/index.php?menu=format
Hardware support page:
http://tta.corecodec.org/index.php?menu=hardware
TTA 3.0 comparison results:
http://tta.corecodec.org/index.php?menu=comp
Thank you in advance for your comments,
-- Alexander
Reply #37
Question:
Why TTA didn't plays via CUE with foobar2000?
Igor
Reply #38
Because I never use CUE. I will look at the plugins code to support this mode if it's required.
-- Alexander
Reply #39
It's required.
For now it's only one thing that stops me from using TTA.
Igor
Reply #40
Question:
Cause the TTA PlugIn for fb2k is inherently broken right now.
Read this thread for more information.
Reply #41
It's required.
OK. Going to resolve this problem at soon. New plugin will to appear at end of next week.
TTA PlugIn for fb2k works good for me and I have no any bug reports about one.
In a separate thread we talking about future modifications in a plugin's code.
Reply #42
and what about an xmms plugin?
anyways, the latest source at corecodec is working (with those compile errors, still - probably gcc3.3 issue) and at the RW Debian Rep
later
Reply #43
In process ;-) Please contact to Pavel Zhilin (pzh@iszf.irk.ru) directly to get more info about Linux software.
Lastest source completely working. gcc3 shows warnings, not errors. Shown warnings is not critical. You may to disable it by removing -Wall parameter in the Makefile.
