Topic: play_item issue (Read 2565 times) previous topic - next topic
play_item issue
when I call this from foo_remote:
play_control::get()->play_item( track ) ;
it is OK
but if the song finishes it does not start next song in playlist but next song of the previous song )
sample:
I start to play no 1 song
I call play_control::get()->play_item( track ) ; (track no 5)
Track 5 finishes
Song 2 is played instead of 6
play_item issue
It think that's how it's always been. If you want song 6 to be played after song 5, you should use playlist_oper::play_item, which takes a playlist index as its argument. That's the only way I know, that should work.
play_item issue
Alllright, I now use ->setSelectFocus() which works.
play_item issue
Will that actually work if follow selection is turned off?
play_item issue
play_item() has never been seriously tested, I think I need to have a look at it's implementation on my side.
[edit] ... hrrm, seems to do exactly what I wanted it to though. Playlist-related behaviors of that function weren't supposed to be predictable or whatever.
