Topic: Upscaling MP3 to DSD (Read 2459 times) previous topic - next topic
Re: Upscaling MP3 to DSD
Hi Mitch,
who are these guys believing that decoding from a lossy format to whatever lossless format could improve quality? They tell you some alternate truth. The only thing that rises will be the bitrate ;)
There's only one way to improve the SQ of MP3 (assuming it's non-transparent versus the original). You'll need to find a way to reverse time and add back the data that the encoder discarded. If you find such a technique, please don't keep it to yourself. Reversing time would be something a great many people would be interested in!
In the real world, compressing to MP3 is a one-way, lossy process that cannot be undone. Any quality reduction on encoding (audible or not) is impossible to reverse. If you've "read somewhere" to the contrary, it's safe to dismiss the notion as not based on reality.
Thanks for the replies.  I am sorry but I was inaccurate in my choice of words in my first question.  The iFi web page does not say it improves sound quality, but that by changing to the DSD format it removes some of the harshness from the mp3 format sound, thus making it more 'analog' sounding and thus, for me at least, more pleasant to listen to.  I appreciate that the lost bits can never be recovered.  I suppose that the conversion is something like applying a filter to the sound (?).
Anyway - I cannot try it out for my self because I cannot find a way to convert from mp3 to DSD, and this is where I would like some help if possible please.
Mitch
It won't sound any different. DSD and PCM will produce identical audio. The DAC chip in your sound card will convert PCM to similar presentation as DSD is without wasting disk space or consuming extra system resources.
Usual audiophoolery.
To convert PCM/mp3 to DSD you need foobar2000 with foo_input_sacd and foo_dsd_processor - https://sourceforge.net/projects/sacddecoder/files/foo_input_sacd/
Using this method it is impossible to save result to disk. Conversion can be done on-the-fly during playback only.
Thanks again guys,
Just so you don't think I am making this up, I thought I would include the link to the iFi Technical Note (hope I am allowed to do this);
https://ifi-audio.com/wp-content/uploads/2018/07/JRMC-MP3-to-DSD512.pdf
The method does use the Foobar plug-in, but as far as I can see, it only runs in JRMC (which I do not have) and although I have the iFi Micro USB, unfortunately I do not have one of their DACS.  There are a couple of professional software suites that may do the conversion, but they are very expensive.  I had hoped that by just using the Foobar plug in I could do it totally within foobar using my own DSD capable DAC.
From your advice however it seems like I might be wasting my time, but even so, just to appease my own curiosity, I would like to have a go if anyone could tell me how (without buying JMRC, an iFi Dac or expensive software).
On the plus side, the work on the time machine is going well, just a few minor issues to resolve.  However, as interesting as I find digital audio, my first trip will be back to 1960 to buy as many new Decca SXL recordings as I can!
Thanks all,
Mitch
If your MP3 sound harsh, they will of course show the same harshness after creating DSD out of them. And why DSD? Linear WAV surely has at least the same capabilities when using higher bit depth and sample rate (I surely do NOT recommend doing so)
The only thing that I can imagine might possibly help - apart from the obvious bullshit-enhanced placebo - is if the MP3 file exceeds digital full scale and clips upon playback, AND somewhere in the conversion/playback chain there is something that will do the right thing with DSD but not with MP3.
A peak-aware player avoids this. In foobar2000, use ReplayGain tags and under Preferences -> Playback at the second-to-top pull-down, choose an option that prevents clipping according to peak. Which is a good thing to do in any case, so I take the opportunity to recommend it even when the issue is total bogus and likely borders on fraud ...
Edit: Just for the sake of the bullshit here: Does not fb2k work in 32-bit floating-point internally? So if upsampling is good for your placebo, then you should get it automatically! :-D
Memento: this is Hydrogenaudio. Do not assume good faith.
This is like copying a VHS tape to Blu-Ray or DVD...    You don't get Blu-Ray/DVD quality.   Except anybody can play a standard format shiny disc but you're stuck with this oddball DSD format.
MP3 is lossy, but a good quality MP3 can often sound identical to the uncompressed original, even a high-resolution or DSD original, in a blind ABX test.
There is one thing you can do to "partially restore" an MP3 - There is something called a harmonic exciter effect that generates high frequency harmonics.   It can be used to replace the high frequencies that are thrown-away by MP3 compression.     The big problem is, if you are hearing compression artifacts it's usually not the loss of high-frequencies you're hearing, and the other problem is that it's impossible to know what the original high frequencies were so you can't restore the original sound.    But, still you can "improve" or "enhance" the sound, just as you can enhance the sound with EQ any other effect.    And, you can save-as WAV or FLAC, or make a CD, etc.  There's no need for DSD.
There is a free exciter plug-in for Audacity (also free) if you want to play-around with it.
Right, this is beginning to get beyond my level of competence, but nevertheless very interesting - it is great that one can learn so much from this Forum - thanks very much.
Just about to go and download Audacity and the plug in - a new strand of interest!  However I still cannot help but wonder why the blind testing the iFi guys did produced positive results.  I cannot see how the article in the Tech Note would be a sales pitch as recommending a conversion like this would not help sell their DACs - they must have heard something - but WHAT?
As a 'city boy' not sure that I would know what bull s..t sounds like - is it better than mp3 ???
Mitch
It is good practice though the effect of encoded data going over full scale being audible over a listener’s entire library isn’t all that likely.
Blind doesn’t mean the test was properly controlled.
Yes, the all too common ignorant placebophile bullshit.  Nothing new here.
Why only “some?”
The iFi page is incorrect, whether deliberately so or not. The red herring there (or bait?) is the "analog" sound claim. You cannot hear bits and bytes, you can only hear analog sound, so ALL sound is analog. I suspect that the "harshness" alluded to is an indirect reference to the long-held and erroneous idea of "stairsteps" in digital, making it harsh. The idea that digital is in any way harsh (or stair-stepped) just because it's digital is completely false and only shows a lack of understanding of A/D and D/A conversion.
By all means play with the idea for your own curiosity but beware of convincing yourself that there's an improvement. Only a properly controlled test will establish that (e.g. ABX).
Why only “some?”
Huh. I didn't see that nuance at ifi-audio.com, and lo and behold, that document says "takes the digital harshness out of the music".
Everyone knows that it isn't the significant learning from the thread, so unless the OP feels like clarifying whether the "some" was injected due to not fully buying the claim or whatever ...
The OP needn’t clarify anything.
For those who still get even a modicum of entertainment the use of “some” was pretty obvious: digital is inherently harsh so mp3 can only be made less harsh.
Loudspeaker manufacturer
Pavlovian
Digital is definitely not 'harsh'
[MODERATION]
I'm terribly sorry, I meant to reply to your post, not edit it.  You spent a great deal of tmie writing your response.  I was only be facetious, however.
I don’t believe the forum software has the ability to revert changes. If you happen to have a saved copy in your drafts I can restore it to that point.
-greynol
Thank you for taking the time to reply.  I understand what you say to some extent, although I would not know how to go about setting up the listening test you mention in your final para.
Primarily I am a 'vinyl -man', and so I am well aware of the difference between good and bad recordings on vinyl (not why they are good or bad you understand - just that some sound a whole lot better than others), this is why I have been collecting early Decca SXL recordings for many years.  I have had a CD/SACD player for a long time, but when it comes to choice of listening medium, it has always been vinyl.  Now however I am trying to understand more about digital audio.
I have always preferred SACD to CD, because I felt, that in general, the quality of the mastering and recording were more consistently good, and the sound was a little more like vinyl I suppose.  I have a fairly decent collection of DSD128 and DSD64 files (the 64s are mainly ripped from my now redundant SACD collection) and if not listening to vinyl it is these DSD files I tend to play - I have not listened to a CD for quite a while.
I also have a large collection of mp3 and ripped CDs which I do not listen to at all -  and so when I saw the iFi Technote saying that by converting the mp3 to DSD it removed some of the harshness I thought it might be worth a try.
All the comments above seem to suggest that this may not be so - but that is academic, because I still do not know how to convert them and give it a try!
Thanks again
Mitch
Rollin told you how to convert everything you play in foobar2000 to DSD on-the-fly. But if you don't have DSD capable DAC you'll need to convert DSD back to PCM. Note that the audio will still not change though, it's just resampling and good resampling has always been transparent.
