foo_input_dts.dll constantly being deleted by Antivirus software 2018-07-09 18:34:46 On my home computer, my Anti-virus has been deleting foo_input_dts.dll, even when I tell it to restore the file and leave it alone, it will eventually ding it again. My home system tags it as a reputation thing, essentially claiming that there are so few users using that file, it must be a virus. I've had this problem on my home system for a while, and I can get around it, but now my work computer (where I have no control over the anti-virus software) has decided it's malware and I can't even reinstall it. The software at work flags it as Gen:Variant.Razy.361336 - whatever that means. Any insight would be helpful.
Re: foo_input_dts.dll constantly being deleted by Antivirus software Reply #1 – 2018-07-09 23:13:09 False positive. I don't have a code signing certificate, so software has to build a reputation to bow to the Antivirus Overlords.Here's the VirusTotal report, if you don't believe me:https://www.virustotal.com/#/file/cf223a82c2c3dc7ed3cf338c01a0713f0c2f54bb58fd0fca823b497aabc93a47/detection Last Edit: 2018-07-09 23:16:20 by kode54
Re: foo_input_dts.dll constantly being deleted by Antivirus software Reply #2 – 2018-07-10 10:08:35 @kode54: You only tested the .fb2k-component file. The .dll does unfortunately get some false positives, even among major suppliers.https://www.virustotal.com/#/file/6d56184432db1a942d2b3399e00120274601ce0d297dc8f1832f63fba70c66b2/detection
Re: foo_input_dts.dll constantly being deleted by Antivirus software Reply #3 – 2018-07-10 11:04:46 Apparently, I shouldn't be enabling debugging info in my releases, even though it's the only way to trace crashes from user crash logs, other than rebuilding a local copy with debugging info, then manually adding code offsets to the load address and tracing in a debugger.
Re: foo_input_dts.dll constantly being deleted by Antivirus software Reply #4 – 2018-07-10 11:17:42 I'm deleting the component from everywhere it's published. Clearly, Peter needs to add his own DTS support to the application, using FFMPEG, and clearly, it will be better than anything I can offer.
Re: foo_input_dts.dll constantly being deleted by Antivirus software Reply #5 – 2018-07-10 11:30:01 Why delete? Does it do any harm except an odd question now and then?
Re: foo_input_dts.dll constantly being deleted by Antivirus software Reply #6 – 2018-07-10 11:32:40 It is a false positive that I have no idea how to solve, because I'm not a member of the antivirus cartel.
Re: foo_input_dts.dll constantly being deleted by Antivirus software Reply #7 – 2018-07-10 12:24:56 Still: "Why delete?"
Re: foo_input_dts.dll constantly being deleted by Antivirus software Reply #8 – 2018-07-10 13:24:01 You solve false positive issues by reporting them to the anti-virus company that makes the mistake. In this case most of the hits come from Bitdefender engine.
Re: foo_input_dts.dll constantly being deleted by Antivirus software Reply #9 – 2018-07-13 09:47:55 I for one will definitely keep it around unless, like you say, really some better solution becomes available.
Re: foo_input_dts.dll constantly being deleted by Antivirus software Reply #10 – 2018-07-14 03:42:43 I don't even know how to report false positives to Bitdefender. I'll get right on that.E: Well, I'll get on it when I have my dev machine up and running again. Last Edit: 2018-07-14 03:48:10 by kode54
Re: foo_input_dts.dll constantly being deleted by Antivirus software Reply #11 – 2018-07-14 22:43:02 Why should you have to remove your component just because anti-virus software doesn't know what it's doing?
Re: foo_input_dts.dll constantly being deleted by Antivirus software Reply #12 – 2018-07-15 07:19:49 I was just being overly dramatic, is all. It's back up, with the same description. And apparently, someone has already submitted it to Bitdefender as a false positive, as it's only popping up in some obscure anti-virus software that don't really provide a mechanism for reporting false positives.
