Topic: Biography Text, Album Info, Picture. www.last.fm (Read 14532 times) previous topic - next topic - Topic derived from Re: WSH Panel Mod scr...
Re: Biography Text, Album Info, Picture. www.last.fm
@kgena_ua
really great script !!!
if you include "album review" in the context menu, please change in properties,"default img path" to "default img path bio" and allow a new path for "album review" (default img path album review).
so that 2 different images can be displayed if nothing is found.
thx
lender1257, thanks.
I'm thinking about reviewing the album. The idea is interesting.
My problem is my English. Basically, I understand, but the subtleties
I.m. UR5EQF
@kgena_ua
i've sent you a mail
There were some changes on the LastFM website.
Biography & Albums & Similar artist info. www.last.fm
version "15122017
for wsh panel mod and jscript panel
language - left mouse (or left mouse + Shift)  double click on the text  (main menu or menu properties to set - select en,it,zh,de,pl,pt,ru,tr,fr,sv,ja);
font size - Shif + mouse wheel on the text or text header (menu properties to set);
move text - press left mouse button on the text and move;
hide text - mouse mbtn dblclk on the text header;
previous, next img. - mouse wheel on the img;
select artist, albums or similar artisr info - left mouse double click on the img  (main menu);
img. interval setting - Shift + mouse wheel on the img;
for advanced settings see menu properties;
added: background transparency under the text - Ctrl + mouse wheel on the text.
over all wishes I work
I.m. UR5EQF
@kgena_ua
i PMed you
@kgena_ua
hi
version 171215 crashes on both panels (jscript + wsh)
[/img]
Reply #30
no one else has this problem?
Am I doing something wrong?
hi kgena_ua
no chance to get version 15.12.2017 running
updating from old to new script --> crash
new installation:
i have deleted jscript- and wsh-panel totally; deleted tmp_Biography
inserted jscript-panel new with script from 15.12.2017 --> crash, same error as described.
when i delete tmp_biography and i start foobar without playing music (stop), tmp_biography and the bio of the last played %artist% will be allocated automatically.
hope you can help
Reply #33
@kgena_ua
i have found an error in your script 15.12.2017
changed it, and now new version is doing fine
changed red marked field from old to new
Reply #34
@kgena_ua
another crash with version 15.12.2017
field "priny" not defined; line 1613 - at a change of the %artist%
could it be that this should be "print" ???
please have a look on it
thanks
Reply #36
hi kgena-ua
I assume it's print. (I don't know this programming language.)
I like your script very much.
what i'm missing is a remap-field for %artist% in properties.
this field should be very long and fillable with titleformatting script. so that every user can enter what he wants.
I myself have almost 800 different %artist% and last-fm doesn't always save as I do it.
the result should then be used to search as %artist%.
I hope you can make this possible. then the script would be perfect, for me.
best regards
Reply #37
@kgena_ua
another please:
please include a refresh-function in your script. (delete folder and new download)
to fix download-errors
thanks
Reply #38
"Biography & Albums & Similar artist info. www.last.fm"
version "18022018"
Added: review of playing or selected album.
language - left mouse (or left mouse + Shift)  double click on the text  (main menu  to set);
select artist, albums (most popular and release date), similar artisr or album info - left mouse double click on the img  (main menu);
The script is not compatible with the previous version, saved data must be deleted.
I.m. UR5EQF
Reply #39
hi kgena_ua
really great work; all works perfect
thanks
are you planning to install the other features i've posted ?
this is for you - for great work
Reply #40
this is for you
Thank.
this field should be very long and fillable with titleformatting script. so that every user can enter what he wants.........
if I understand correctly you want to be able to, for example through a dialog box, enter the name of the artist.
I.m. UR5EQF
Reply #41
hi
1) maybe in properties a new line named "remap artist". (very large)
in this field i will enter with titleformatting script, all changes of my %artist%-tags, so last.fm will find the text.
if "remap-field" not is space search with this new "remap-field" as %artist%, in all other cases with %artist%.
for example:
$if($or($strcmp(%artist%,'ALLMAN BROTHERS BAND'),$strcmp(%artist%,'ALAN PARSONS PROJECT'),$insert(%artist%,'THE ',0),),)$replace(%artist%,'CHRIS FARLOWE & THE HILL','CHRIS FARLOWE WITH THE HILL')$replace(%artist%,'YUSUF','CAT STEVENS')
means:
my tag                                  result in remap-field (should be like in last.fm)
ALLMAN BROTHERS BAND     THE ALLMAN BROTHERS BAND
ALAN PARSONS PROJECT       THE ALAN PARSONS PROJECT
CHRIS FARLOWE & THE HILL   CHRIS FARLOWE WITH THE HILL
YUSUF                                  CAT STEVENS
2) refresh function (maybe under "delete empty folders")
thx
Reply #42
for example:
means:
thanks I understood
I.m. UR5EQF
Reply #43
hi
maybe remap %album% (i don't use it) could be useful for other people
thx
Reply #45
script - no download possible
Reply #47
I'm sorry, I thought you already finished it.
input line is ok.
thx
Reply #48
"Biography, Albums, Similar and title artist info. www.last.fm"
version "030322018"
Added:
review of playing or selected album;
menu item "Refresh" (default is false, see menu Properties);
remap artist (menu Properties);
"img border thickness"  (menu Properties).
select artist, albums (most popular or release date), similar artist, album or title info - left mouse double click on the img  (main menu);
I.m. UR5EQF
