Topic: Not sure where to start in developing a plugin, documentation is fairly limited (Read 913 times) previous topic - next topic
I've been wanting to develop some plugins for foobar2000 and downloaded the SDK only to find it's not only rather hit-and-miss whether things will actually compile since there's lots of version mismatches and Visual Studio 2017 seems to be having a little bit of trouble still, which is fair enough since reportedly only 2013 and 2015 are verified. But there's very little, if any, documentation for writing plugins that I can find.
Can someone point me in the right direction just to start with - I've had a look around on these forums a bit but I've only found outdated tutorials or really specific cases which can't be applied generally. Even some commented code would go a long way!
Cheers in advance if anyone can provide some help! :)
Re: Not sure where to start in developing a plugin, documentation is fairly limited
Regarding VS2017-
The foobar2000 SDK, version 2015-08-03 is compatible with the latest version of Visual Studio 2017 at this time - I just tested it myself.
There was a period in which Visual Studio auto updater would give you broken platform SDK which made lots of my code fail to compile due to Windows.h vs WinSock #include order issues. This appears to have been fixed on their end.
You can load foo_sample workspace into VS2017, retarget to the new toolchain (original projects are VS2010), optionally enable -XP version of the toolchain in project settings, enable /d2notypeopt as per this thread and you're good to go.
foo_sample demonstrates most commonly used parts of foobar2000 SDK, it's a good starting point to learn how the SDK works. Also don't forget to check the readme doc first, it has lots of essential info on SDK architecture.
Regarding VS2017-
Thanks for the help! There's lots of configurations in the foo_sample project that I found need to be copied over to any other plugin you're writing: the compiler option needed to be switched from /MD to /MT in my case - fixed issues when compiling. I also found out there's lots of plugins on GitHub whose code you can look through and get a grasp of what's going on, the foosion subdomain of foobar2000's website is also quite helpful even if it was originally written for the 0.9.x SDK.
