Topic: ESLyric - an alternative lyric show component (Read 43937 times) previous topic - next topic
0 Members and 10 Guests are viewing this topic.
Re: ESLyric - an alternative lyric show component
Reply #50
found another bug for JS scripting
info.Title=DARAKENA for song with %TITLE%=DARAKENA (TV-size). However, Search Preview under Lyric Save configuration shows the correct %TITLE%=DARAKENA (TV-size)
Reply #51
emm.. , esl do some pre-process for keywords before searching by default, and not plan to change it, sorry.
Reply #52
this is not about transform encoding. it's incorrectly cutting off strings...
Reply #53
[/quote]
you try "xxx (Album Version)"
Reply #54
[/quote]
looks like some sort of regex pre-processing are done, so texts in those brackets are removed. not sure how we are supposed to search even with online sources if full title won't be available
Reply #55
First of all, thank you for this incredible plugin. I have been looking for an updated desktop lyric since Crintsoft Mini Lyrics
Would like some more features on this:
- Some menu option for offset+, offset- with maybe 0.5s predefined, it would be easier
- The same +offset, -offset starting from the current line to the end of the file when editing the lyrics, makes editing faster since many songs are already timed correctly but they might add some kind of delay when on concert
- Automatically split lines in 2 on the desktop lyric panel instead of horizontally scrolling (i know it might mess with the lines 1 and lines 2 configuration)
- A scrolling mode for desktop lyric panel
- Force to show artist, title and album if present before any lyric start on desktop lyric panel (or maybe make it optional sticky, so it shows all the time)
- A visual cue to start the lyric if a considerable amount of time has passed since the last line, maybe about +15s (just like old karaoke)
  - Consider a phantom line of silence if between timestamp has maybe +6s, (its very rare for a line to be longer than that, this should make the karaoke mode more precise, most lines are about 3-4s long)
Reply #56
found a bug on the latest ESLyric
info.Title, info.Artist and info.Album content that you get in start_search of your js script are already converted to Simplified Chinese if there are any CJK characters, but the configure panel Lyrics Save section's preview shows the original correct content
the printed tf.Eval("%title%") result when enabled advanced customer search shows title is not converted to Simplified Chinese at this point
add the same CJK characters to directory name and confirmed that info.RawPath is not converted to Simplified Chinese
would be good to have a function to get the original Foobar2000 native meta data to workaround this type of issue in the future
is it possible to make tf - ITitleFormat object global, so we can use Eval("%TITLE%") to grab the original %TITLE% from FB2K?
tf-related function can only be called in main thread. to make it simpler, esl doesn't provide such a tf object.
Reply #57
no more new features. :(
Reply #58
Aww, maybe opensource it
