Topic: YouTube Track Manager Discussion (Read 14534 times) previous topic - next topic
Re: YouTube Track Manager Discussion
Reply #75
your support always goes above and beyond - thanks for adding so much to my FB experience!
Reply #76
Still very much like+use this plugin!
One question: when loading a youtube track via yttm, the youtube playcount is not shown anymore (which I used for an additional filter via the Skip Track plugin).
When loading the same youtube track directly via foo_youtube, the playcount is available, as shown in the comparison of the properties of the identical youtube track below.
Any hint on how to get the playcount as well with the YTTM plugin?
Reply #77
Forgot my configuration: foobar2000 v1.4.1, JScript Panel v2.1.8, YTTM v3.9.5
Reply #78
I presume you mean the view count, rather than playcount as the only playcount in the pics is 0 in both cases.
View count, and population of the Youtube source fields, is handled by the foo_youtube plugin and so a fix likely requires a bug fix in the foo_youtube plugin itself. For info, there is some difference in handling between loading by YTTM and standard direct loading, i.e. script uses the metadata overriding feature, so artist & title etc are correct, and so the bug likely relates to that. In my tests, the current behaviour is erratic: sometimes view count is present with those sent by YTTM, other times it's missing.
If you really mean view count, then consider pointing 3dyd at this thread to see if it can be fixed.
Reply #79
You are right, I was looking for the view count, not the playcount
I will do that
Reply #80
New Version: YouTube Track Manager 4.0.0
NEW: Improved menu options.
NEW: Touch Control (enable: menu > options > mode)***.
NEW: Selection Mode (set: menu > options). N/A in prefer video mode: videos can't follow selected track.
CHG: Playlists: now only created if required.
CHG: Requires Spider Monkey Panel - if you're unfamiliar with it, then it's based on JScript Panel but has a modern Javascript engine. Spider Monkey Panel can be run alongside JScript Panel, & so other panels can continue to run in JScript Panel if you don't have Spider Monkey Panel versions.
*** for an extra scroll experience, if you don't have a touch screen, enable touch control and drag with left mouse button down.
Updating
Panel properties will be reset as its a new panel. Export JScript panel properties or back-up layouts before updating if you want a record. Importing JScript panel properties isn't supported: panel properties have been overhauled & more key options are now on the menu.
Reply #81
Congratulations on releases!
Here is a congratulatory bug report =)
When right-clicking anywhere the following script error occurs:
Error: Spider Monkey Panel v1.1.5-beta+63bde4e (YouTube Track Manager v4.0.0 by WilB)
list.blacklist is undefined
File: Panel_YT.js
Line: 3549, Column: 54
Stack trace:
  blacklistMenu@Panel_YT.js:3549:54
  MenuItems/this.rbtn_up@Panel_YT.js:3585:17
  on_mouse_rbtn_up@Panel_YT.js:3752:49
PS: Panel_YT.js is your script.
Reply #82
Thanks for the report.
I couldn't reproduce the issue under normal usage.
However, it looks to me as though the blacklist file has become corrupted and isn't in a valid json format for some reason or another, although I've not seen the script write it incorrectly. I could reproduce the effect by manually editing the blacklist file so it wasn't valid. Can you try deleting fb.ProfilePath\yttm\blacklist.json (or rename if you want to keep it) and see if the issue disappears? If that's what it is, I can add some extra validity checking to stop the script error etc.
Reply #84
The problem was caused by an extra new line ('\r\n') in the old `blacklist.json` (generated by foo_jscript_panel). JSON parser does not approve of such symbols :D
[EDIT]: Nvm, investigating further...
[EDIT_2]: Yup, it's a bug in SMP, will be fixed in v1.1.5.
[EDIT_3]: v1.1.5 posted. The bug was caused by incorrect parsing of files encoded in UCS-2 LE (i.e. wide char).
Reply #85
Hi there!
@WilB, thanks for your cool script!
I noticed some differences in design between the JSP and SMP versions:
1. font color (see cursor.jpg)
2. align the highlighted text vertically (see word "Affection" at cursor.jpg)
3. horizontal line color (see line.jpg)
please check it, is this how it should be? or need to lead to uniformity.
Reply #86
Thanks for the feedback
1) Font colour: highlighted text. This seems to effect CUI not DUI. The next version should behave the same way as JSP.
2) Text vertical alignment. I noticed this a long time ago and queried it here. Essentially there are some minor differences at the pixel level between SMP & JSP. I prefer the SMP way on my machine. Changing the vertical size of the layout by 1, 2 or a few pixels might alter the rounding.
3) Line colour. It was a design choice to tone the line intensity down a little, as I thought they were a bit bright before.
Reply #87
New Version: YouTube Track Manager 4.0.1
FIX: Nowplaying view: Artist images should now cycle correctly.
FIX: Corrected font colour of selected text (CUI).
FIX: Corrected slight inaccuracies in text vertical alignment with certain fonts. Behaviour should now be similar to the JScript panel version.
CHG: Added "Lines Embolden" to panel properties. If enabled, lines should render the same as in the JSP version, for users preferring that style.
Reply #88
New Version: YouTube Track Manager 4.1.0
NEW: Black list for images (right click > menu > image). Designed to filter out occasional unwanted LFM artist images. Black list is also used by Biography.
CHG: Updated scrollbar handling. New default button icons + auto-minimises & auto-hides by default. Behaviour & look can be set as previous on settings > display > scrollbar menu.
CHG: Various optimisations.
