Re: Library Tree Reply #50 – 2018-04-10 17:45:11 New Version: Library Tree 1.4.0.2Requirement as reply #48. Last Edit: 2018-04-10 18:05:55 by WilB
Re: Library Tree Reply #51 – 2018-05-02 19:37:14 Hi,I use CaTRoX (QWR Edition) theme and I have some trouble with long opera/classical tags: https://imgur.com/a/KRREcZ7Would it be possible to fix this in a next update?Thank you in advance.
Re: Library Tree Reply #52 – 2018-05-03 17:37:36 I can't actually reproduce the issue, despite trying some very long tags, & so its not clear what the problem is. I note also that the CaTRoX playlist doesn't seem to have rendered correctly either (tracks 06, 08 & 10). So I wonder if its possibly something to do with the theme/underlying panel stack splitter handling??Library tree uses a simple draw text function and that hasn't changed for ages, but it looks as though the text isn't being clipped correctly (i.e. no end ellipsis ...) for some reason.It may be helpful to post some of the problematical opera/classical tags in case its some how due to the presence of certain characters etc.To exclude a settings issue you could do the following. Right click library tree & choose panel properties. At the bottom choose export to ensure you have a back-up of panel properties. Then choose clear panel properties to reset to default to see if the issue persists. Last Edit: 2018-05-03 17:41:32 by WilB
Re: Library Tree Reply #53 – 2018-05-03 19:17:59 You are right about the playlist, the glitch is everywhere. I tried a proper portable installation without CaTRoX and got the same issue on Library Tree though.I send you the folder in PM, would be great if you could find where it comes from. The problem appears when you check "View by Artist". Last Edit: 2018-05-03 19:23:41 by Novatic
Re: Library Tree Reply #54 – 2018-05-04 10:53:47 Quote from: Novatic on 2018-05-03 19:17:59You are right about the playlist, the glitch is everywhere. I tried a proper portable installation without CaTRoX and got the same issue on Library Tree though.That's really weird, I could not reproduce the issue neither in playlist nor in the Library Tree script. It seems that text clipping is broken in your player for some reason. What OS are you using? Also please attach your component list (Preferences > Components > Copy report).@WilB: should we move this discussion to https://hydrogenaud.io/index.php/topic,111060.msg954816.html ? Last Edit: 2018-05-04 10:56:33 by TheQwertiest
Re: Library Tree Reply #55 – 2018-05-04 11:15:59 @Novatic: I responded in main thread. See link above.
Re: Library Tree Reply #56 – 2018-08-13 09:59:26 Is there some "playlist search" script? I don't need "library search", just script with search box, that can search active playlist and send results to #Playlist Search? Is something like this exist? Last Edit: 2018-08-13 10:09:58 by mire777
Re: Library Tree Reply #57 – 2018-08-13 15:23:19 I don't have one and don't know if one exist. There's always foo_quicksearch? Last Edit: 2018-08-13 15:42:59 by WilB
Re: Library Tree Reply #58 – 2018-08-13 16:31:12 Quote from: WilB on 2018-08-13 15:23:19I don't have one and don't know if one exist. There's always foo_quicksearch?Yes, but in script i can easily edit some things how I like.. Anyway thanks..
Re: Library Tree Reply #59 – 2019-01-17 11:39:49 New Version: Library Tree 1.4.0.3This is maintenance update to fix compatibility with JScript Panel 2.2.0+. There are no new features.Requirement as reply #48.
Re: Library Tree Reply #60 – 2019-01-20 17:38:22 New Version: Library Tree 2.0.0REQUIREMENT: Spider Monkey Panel 1.1.4+Please post discussion here.
Re: Library Tree Reply #61 – 2019-01-25 11:33:22 New Version: Library Tree 2.0.1REQUIREMENT: Spider Monkey Panel 1.1.5+Please post discussion here.
Re: Library Tree Reply #62 – 2019-01-25 16:57:10 @WilBThank you very much for your hard work. Now everything works like a charm
Re: Library Tree Reply #63 – 2019-01-27 18:06:08 New Version: Library Tree 2.0.2REQUIREMENT: Spider Monkey Panel 1.1.5+Please post discussion here.
Re: Library Tree Reply #64 – 2019-02-17 19:58:51 Hello WilB,I am getting this error as I click on the top line All Music when in View by Folder Structure mode.Error: Spider Monkey Panel v1.1.5 (Library Tree v2.0.2 by WilB)too many arguments provided for a function callFile: <main>Line: 1681, Column: 103Stack trace: get_selection@<main>:1681:103 Populate/this.lbtn_dn@<main>:1606:49 on_mouse_lbtn_down@<main>:2323:188Regards,Andrea
Re: Library Tree Reply #65 – 2019-02-17 20:08:48 Hello WilB,and I am getting also many "out of memory" errors ...This is what pop-up as I run a search:Error: Spider Monkey Panel v1.1.5 (Library Tree v2.0.2 by WilB)out of memory
Re: Library Tree Reply #66 – 2019-06-10 12:23:48 New Version: Library Tree 2.1.0REQUIREMENTS:Spider Monkey Panel 1.2.1+FontAwesome (new requirement)Please post discussion here.
Re: Library Tree Reply #67 – 2019-07-10 17:24:21 New Version: Library Tree 2.1.1Requirements are as above.Please post discussion here.
Re: Library Tree Reply #68 – 2019-09-25 12:14:31 New Version: Library Tree 2.1.2REQUIREMENTS:Spider Monkey Panel 1.2.1+FontAwesomePlease post discussion here. Last Edit: 2019-09-25 13:08:16 by WilB
Re: Library Tree Reply #69 – 2019-11-08 17:45:49 New Version for JScript Panel: Library Tree 1.4.0.4REQUIREMENT: JScript Panel 2.3.1+This is a maintenance update intended for users who wish to continue using a JScript Panel version. There are no new features compared with earlier 1.4.x.x versions. It's recommended that you use the latest Spider Monkey Panel version if at all possible, e.g. it has a newer feature set and is more actively developed.CHANGELOGCompatibility fix for JScript panel 2.3.x seriesPlease post discussion here.
Re: Library Tree Reply #70 – 2019-11-08 17:51:23 New Version: Library Tree 2.1.3REQUIREMENTS:Spider Monkey Panel 1.2.1+FontAwesomePlease post discussion here.
Re: Library Tree Reply #71 – 2019-11-09 08:15:17 @WilB Thank you for update I have one question, what exactly is the font "FontAwesome" required for?
Re: Library Tree Reply #72 – 2019-11-09 10:26:59 FontAwesome is a symbols and logos font. Sadly, the latest and most feature filled versions of it are closed source, unlike older versions. I wonder if anyone maintains an open version with newer glyphs, developed independent of the original creator?
