Topic: Dynamic range (Read 2188 times) previous topic - next topic
Dynamic range
I have been trying to figure this out for days and I cannot seem to find the answer.  I would like to go through my music (mp3, ogg, flac) and find the dynamic range.  I am not an audio engineer, so I am not sure if this is really possible.  Was looking to calculate a response like "TT Meter."  I am using sox and have the stat and stats output parsed, but not sure how to calculate the DNR from the numbers.
stat provides: (will put json encoded at the bottom for both stat and stats)
Metric                                      Regular                                      RMS
Samples read                                1109022
Length (seconds)                            12.573946
Scaled by                                    2147483647.0
Maximum amplitude                            0.891235                                    6.886618
Minimum amplitude                            -0.891266                                    -6.886854
Midline amplitude                            -0.000015                                    -0.000118
Mean norm                                    0.085137                                    0.657858
Mean amplitude                              0.000163                                    0.001256
RMS amplitude                                0.129416                                    1.000000
Maximum delta                                0.521088                                    4.026469
Minimum delta                                0.000000
Mean delta                                  0.023000                                    0.177719
RMS delta                                    0.034364                                    0.265534
Rough frequency                              1863
Volume adjustment                            1.122
and stats provide:
Metric                            Overall                          Left                            Right
DC offset                        0.000199                          0.000199                        0.000126
Min level                        -0.891266                        -0.891266                        -0.891266
Max level                        0.891235                          0.891235                        0.891235
Pk lev dB                        -1.00                            -1.00                            -1.00
RMS lev dB                        -17.76                            -17.67                          -17.85
RMS Pk dB                        -9.05                            -9.05                            -9.12
RMS Tr dB                        -49.86                            -49.86                          -49.78
Crest factor                      -                                6.81                            6.96
Flat factor                      10.24                            10.86                            9.43
Pk count                          56                                61                              51
Bit-depth                        16/16                            16/16                            16/16
Num samples                      555k
Length s                          12.574
Scale max                        1.000000
Window s                          0.050
And "TT Meter" gives:
Number of Samples: 554511
                            left                right
Peak value:    -1.00 dB  ---    -1.00 dB
Avg RMS:      -15.27 dB  ---  -15.45 dB
DR channel:    12.17 dB  ---    12.31 dB
Official DR value:  DR12
Can I calculate a useful DNR from the sox statistics numbers, similar to "TT Meter"?  I do not mind complex calculations, I am just not sure which values can be used for the DNR formula.
Thanks for any possible help!
Sincerely,
John
stat in json:
[{"Metric":"Samples read","Regular":"1109022","RMS":{}},{"Metric":"Length (seconds)","Regular":"12.573946","RMS":{}},{"Metric":"Scaled by","Regular":"2147483647.0","RMS":null},{"Metric":"Maximum amplitude","Regular":"0.891235","RMS":"6.886618"},{"Metric":"Minimum amplitude","Regular":"-0.891266","RMS":"-6.886854"},{"Metric":"Midline amplitude","Regular":"-0.000015","RMS":"-0.000118"},{"Metric":"Mean norm","Regular":"0.085137","RMS":"0.657858"},{"Metric":"Mean amplitude","Regular":"0.000163","RMS":"0.001256"},{"Metric":"RMS amplitude","Regular":"0.129416","RMS":"1.000000"},{"Metric":"Maximum delta","Regular":"0.521088","RMS":"4.026469"},{"Metric":"Minimum delta","Regular":"0.000000","RMS":{}},{"Metric":"Mean delta","Regular":"0.023000","RMS":"0.177719"},{"Metric":"RMS delta","Regular":"0.034364","RMS":"0.265534"},{"Metric":"Rough frequency","Regular":"1863","RMS":{}},{"Metric":"Volume adjustment","Regular":"1.122","RMS":{}}]
stats in json:
[{"Metric":"DC offset","Overall":"0.000199","Left":"0.000199","Right":"0.000126"},{"Metric":"Min level","Overall":"-0.891266","Left":"-0.891266","Right":"-0.891266"},{"Metric":"Max level","Overall":"0.891235","Left":"0.891235","Right":"0.891235"},{"Metric":"Pk lev dB","Overall":"-1.00","Left":"-1.00","Right":"-1.00"},{"Metric":"RMS lev dB","Overall":"-17.76","Left":"-17.67","Right":"-17.85"},{"Metric":"RMS Pk dB","Overall":"-9.05","Left":"-9.05","Right":"-9.12"},{"Metric":"RMS Tr dB","Overall":"-49.86","Left":"-49.86","Right":"-49.78"},{"Metric":"Crest factor","Overall":"-","Left":"6.81","Right":"6.96"},{"Metric":"Flat factor","Overall":"10.24","Left":"10.86","Right":"9.43"},{"Metric":"Pk count","Overall":"56","Left":"61","Right":"51"},{"Metric":"Bit-depth","Overall":"16/16","Left":"16/16","Right":"16/16"},{"Metric":"Num samples","Overall":"555k","Left":null,"Right":null},{"Metric":"Length s","Overall":"12.574","Left":null,"Right":null},{"Metric":"Scale max","Overall":"1.000000","Left":null,"Right":null},{"Metric":"Window s","Overall":"0.050","Left":null,"Right":null}]
