Hydrogenaudio Forums
Hosted Forums => foobar2000 => 3rd Party Plugins - (fb2k) => Topic started by: nausea on 2009-01-31 16:25:34
Title: foo_podcatcher
Post by: nausea on 2009-01-31 16:25:34
This is a component for subscribing to, downloading, and playing podcasts in foobar2000.
Get versions 0.1.2 (beta) and 0.2.1 (beta) here: download foo_podcatcher (http://www.unkempt.co.uk/fb2k/foo_podcatcher.html)
To manage your podcast subscriptions open the Podcatcher UI from the View->Podcatch Manager menu. Here you can add new feed URLs and create playlists. The component will parse RSS 2.0 and Atom 1.0 feeds.
In the preferences you can set the download path and the time period over which to download from each feed automatically. The component will check for new podcasts 15 seconds after foobar2000 starts and then again every 60 minutes.
Known issue for 0.1.6+: Group headings don't respect UI colours and fonts reliably.
Recent changes:
Anyway, let me know if you find any problems, and post any feeds which don't seem to work.
Note for 0.2.x - this version has major changes to the way that feed and cast statuses are stored, so it is possible and likely that stability has regressed. As always, help me help you by submitting those crash reports!
Post by: thecircusfreak on 2009-01-31 17:40:59
It works!
I also like the ability of playing the files without downloading em, is sth I always needed.
Nausea, all the three pluigns of YOURS are AWESOME. Muchas gracias!
Post by: ojdo on 2009-01-31 23:42:45
Great plugin!
A bug report: The podcatcher UI seems to have problems with umlauts (ä,ö,ü) and probably other special characters in podcast titles. Names are truncated just before their occurence. Example feed (http://www.law-podcasting.de/podcast.php)
Post by: thecircusfreak on 2009-02-01 00:07:41
Some feedback:
-The time you create the  podcast playlist, the first song you ll play will have its seek bar disabled.
-If you remove a subscription you cant readd it.
-If oyu delete a track, you cant redownload it. On updates, podcatcher should check if downloaded files do exist.
And a little feature request although I undrstand this is just an alpha, an option to write published date in a file tag would be great!
Post by: lyh on 2009-02-01 09:17:52
how  to delete the program list? I remove the feed,but the programs list of the feed on the right side still exist.
and I download the mp3 files,but it download the file only 50k,but  the file is 12M.
It is so good.  woo
Post by: predator29 on 2009-02-01 09:47:28
u roxx mate!
the greatest plugin ever
a little feedback, to what i've just runed:
1) it started to auto download the episodes only after i've added a new feed
2) the url type feed:// isn't supported. i've changed it to http:// and it did work. (the feed is rss2, so it should be)
except these i have not found any bugs.
Post by: nausea on 2009-02-01 20:20:59
Thanks for the feedback guys. I've released a quick update with a few fixes. More will follow!
Is this with all feeds? If not could you post an example feed which has the problem. Thanks.
[quote author=predator29 link=msg=0 date=]1) it started to auto download the episodes only after i've added a new feed
2) the url type feed:// isn't supported. i've changed it to http:// and it did work. (the feed is rss2, so it should be)[/quote]
1) I guess this was after the first run, when you had to set the download directory. The items are still in the queue so you can trigger the download by updating the podcasts. I'll make this more elegant at some point...
2) Do you have an example podcast which uses feed:// "protocol"?
Post by: nausea on 2009-02-01 20:30:18
This was because of the encoding of the feed. It seems to work for the example feed now. Let me know if you come across any others with similar problems. It's easy to not notice character encoding problems when everything you listen to is in English...
Post by: predator29 on 2009-02-02 08:37:40
Yes, it was after the first run.
Sure, here are some: http://tilos.hu/podcast/ (http://tilos.hu/podcast/)
All of those are rss2, only the url type is different. Actually it works, if you change the url to http://
Post by: El Noire on 2009-02-07 23:08:42
Great plugin! I just did what the author recommended, put the Podcast Path to the "Podcast" folder (I created) in my library (D:/Music/Podcast) and created an autoplaylist "Podcast" (* HAS podcast) and everything turned out fine    I noticed the downloaded music files (I only subscribed to audio-podcasts) all have embedded art so I will try to display those in the Curacao elpplaylist ^^  Thanks for the great work!
Post by: wortels on 2009-02-10 14:35:46
Can you make it so that the plugin updates the playlist automatically even if not downloading podcasts? I would like to stream podcasts instead
Post by: nausea on 2009-02-21 12:25:16
Version 0.0.3 released. Main change is to the downloading UI. Now uses notification area to inform about new podcasts, downloads, etc. You can see the download progress of individual items in the Podcast Manager UI.
aliumalik: automatically updating playlists is on the TODO list for the next version.
predator29: I'll also look at the feed:// issue. As you say they work if you change the url to http:// so it should be easy...
Post by: --pv-- on 2009-02-21 20:09:38
Great. Would it even be possible to add ability to add an episode to the playlist after double clicking it in the list and even better navigating to the corresponding list item using keyboard and pressing enter key? Potcast manager window seems to be great it lists all the episodes. For me it would be nice to review that list and add to the playlist episodes I like. Or if playlist will be generated and streaming will be possible then I can let the plugin to generate the playlist and then remove the episodes I don't want to listen to.
thanks I love this plugin.
Post by: 2E7AH on 2009-02-22 01:29:08
"remove selected" button removes only one item although selects many in podcatcher
few suggestions:
one more display column: <description> element
maybe sort columns if title column is clicked
access to information in columns, at least ability to copy
one note: i had to rename .m4b extension to .m4a to be able to play the file (but that has nothing to do with this component, although it stores the info about it as .m4b so when creating playlist it of course looks for .m4b)
thanks
Post by: predator29 on 2009-02-22 11:51:52
i'm not sitting in front of my box, but i have a question. correct me if i'm wrong, but it came to my mind, if i delete a file in a file manager, does this plugin updates the status of the file to "not downloaded"? if it does, then pardon me  but if it doesn't than i would like to see this feature
Post by: nausea on 2009-02-22 12:02:16
It updates it to "deleted", and you should be able to re-download it manually.
Post by: bellingman on 2009-03-03 19:20:34
Something is seriously wrong here...
I set the download folder under Library->Preferences->Tools-Podcatcher, then ran View->Podcast Manager to load a podcast. I entered the podcast URL and clicked Subscribe... and nothing happens. The bottom panes don't get populated, nothing.
I tried with the following three URLs, same result. Restarting... nothing. Clicking every button on the page... nothing.
http://www.onthemedia.org/index.xml (http://www.onthemedia.org/index.xml)
http://pointofinquiry.libsyn.com/rss (http://pointofinquiry.libsyn.com/rss)
http://carollaradio.com/feed/ (http://carollaradio.com/feed/)
What am I doing wrong?
Post by: Jonas Nyrup on 2009-03-03 22:19:23
#bellingsman
Alle three feeds works for me.
It might takes a few seconds after you click suscribe before a windows pops up asking you to confirm the suscription.
#nausea
I don't know if I'm doing anything wrong, but I can't remove more than one file* at a time. *all those files in the right column in podcatch manager
futhermore, when I click on a random place in the left column, I can see files from earlier deleted feeds.
Post by: bellingman on 2009-03-03 22:24:25
Not for me. No matter how long I wait, nothing happens.
Post by: bellingman on 2009-03-03 22:39:24
I see the problem now: it does not recognize my proxy server settings. When I disconnected from my corporate network it works normally.
So I guess this is a feature request: please recognize the proxy settings as set in Windows Internet Options and prompt for authentication (as iTunes does, for example) or add configuration fields for the proxy server address, port, and username/password.
Post by: David Heath on 2009-03-12 13:04:30
Has anyone tried combining this with some kind of custom column which monitors whether you've played the track or not? One thing I like about iTunes is that it checks whether you've played the track, and it also picks up from where you've left off if you do happen to start it but then need to pause or play another track. I don't suppose a custom column which does the monitoring would be too difficult, but I'm not too sure about how to go about it.
I really like the component, but I think that the key in using it effectively is with a well-designed playlist.
Post by: Jleagle on 2009-03-14 13:37:16
Can anyone explain why this podcast wont work?
http://www.zen54064.zen.co.uk/Hospital%20R...Podcast%201.xml (http://www.zen54064.zen.co.uk/Hospital%20Records%20Podcast%201.xml)
Thank you.
Post by: nausea on 2009-03-14 17:54:28
The feed contains playlists (rather than mp3s or similar), and they aren't marked as type "audio", so the component ignores them. I'll have a think about how to handle this situation. Thanks for pointing it out.
Post by: Jleagle on 2009-03-14 17:59:26
Thanks alot, id love to uninstall iTunes and use this instead!
Post by: wortels on 2009-03-14 23:11:52
nausea did you get my PM?
Post by: thecircusfreak on 2009-03-17 09:36:38
Nausea, if you re gonna fix the above(not an issue really), mind you can register feed:// (or even itpc//) using new foobar versions.
Third party components can now register custom protocols with the File Types preferences page.
Secondly I dont know how you plan to implement "Playlist genereting UI", but a simple quick n dirty one is like album's list will do just fine imho. Just a Generate playlist's name textbox with a default  tagz value sth like: "%_pcast_name% podcast". If the user wants a unified playlist just removes %_pcast_name%.
Thanks for your work many many kudos!!!
Post by: ingver on 2009-04-01 21:50:58
awesome plugin. I've been waiting for this..
A couple requests/bugs:
Post by: tpijag on 2009-04-07 20:33:34
Small buglet.
I've XP set with Foobar in the quick launch area of the Task Bar.
Also, Foobar preference is set to minimize to notification area.
Foobar open but quiet [not sure yet if matters whether current status is paused or stopped]
Podcast runs one of it's 30minute updates.
Foobar will no longer respond to the notification icon to open. A mouse over the icon with show a pop up of "podcast" as current track.
Foobar will respond to the quick launch icon and appropriately opens the existing instance and all reverts back to normal.
just FYI
terry
Post by: DaveTheStalker on 2009-04-09 22:05:52
Forgive my ignorance with using Foobar, I'm new to it.  This is my first post.  I am really impressed with Foobar's ability to convert 24-bit/96khz FLAC's to WAV's while maintaining their full integrity.
I'm trying to use Pod_Catcher to subscribe to the Burnout Paradise CrashTV podcasts.  I'm not quite sure what exactly I should be doing to set up the podcast.
I'm having the same problem as bellingsman did.  Except, I'm not using a proxy at all with either of these links.
http://criteriongames.com/podcast/ (http://criteriongames.com/podcast/)
itms://ax.itunes.apple.com/WebObjects/MZStore.woa/wa/viewPodcast?id=282477732&ign-mscache=1 (http://itms://ax.itunes.apple.com/WebObjects/MZStore.woa/wa/viewPodcast?id=282477732&ign-mscache=1)
I have even changed that to "http" and still nothing happens.
My is E:\My Videos\Burnout Podcasts
If you'd look at the site, you'll see the "Subscribe to" link on the right side.  When I click on that, Winamp launches and it cannot load the podcast properly.  I'm wondering if there might be some sort of issue with the BOP podcasts that are causing problems?
Post by: tpijag on 2009-04-09 22:43:14
Very new to podcasts with Foobar myself....but are not those Video podcasts?
Foobar is a audio program.
terry
Post by: DaveTheStalker on 2009-04-09 22:49:21
terry
Yeah, you've got a good point.  I was just assuming FB had a video component like Winamp does.  Even with the video option checked in Winamp they don't load.
Post by: tpijag on 2009-04-09 22:51:00
No
terry
Post by: nausea on 2009-04-23 23:24:04
Updated to version 0.0.4 (alpha).
Implemented some of the planned changes, but not all of them yet.
Main change for this version are the podcatcher playlists which update as the feeds do. The notification icon conflict problems should also be fixed now, as the component now has its own icon. The icon does sometimes remain, which is a bug.
It seems to be stable, but let me know of any crashes or hangs.
Edit: quick release of v0.0.4b, which adds support for feed:// and itpc:// urls (including registering them in recent versions of foobar2000).
Post by: halabund on 2009-05-09 22:40:31
Why is the seek bar often disabled in foo_podcatcher playlists?  (I think it's only disabled on first play of each track, not the second one.)  This doesn't look like it's intentional, as the files are already downloaded, and seeking does work with keyboard shortcuts (just not with the seek bar).
Post by: ingver on 2009-05-09 22:46:14
halabund,
Umm are u sure those are downloaded tracks? I thought it played not dled tracks too... maybe i understood wrong...
EDIT: I checked, it seems to play tracks that are not downloaded in foo_potcatcher playlists. At first, when it's not locally cached, the seekbar doesn't work, which is logical as the file has not been downloaded fully. Additionally, it doesnt get the artist name when you haven't played the track yet. Downloaded tracks work all OK.
nausea,
anyway... great update but the icon is rather ugly. I've made a better one (imo) for u to use if you want.
(http://rv.pri.ee/madis/pildid/podcast.png)
also, it's weird but the podcatcher doesn't automatically download... i have to manually check and download every time...
and the last published/published column on all music files in the manager window is always the same - 1601-01-01 03:00:00
Post by: halabund on 2009-05-10 20:24:37
Yes, I am talking about downloaded tracks.  The very first time they are played after having been downloaded, the seek-bar is disabled (the handle does move, but cannot be moved with the mouse).  Despite this, seeking works with keyboard shortcuts.
With non-downloaded tracks, the seek handle does not move and cannot be moved---that is reasonable.  But I was talking about downloaded tracks.
Post by: ingver on 2009-05-12 16:49:52
well maybe the podcathcer ignores the fact that the tracks are downloaded and streams *all* the tracks from the playlist. In that case, it's a bug and should be fixed.
EDIT: so the downloaded tracks behave different from the not downloaded tracks. In that case my theory is incorrect . I personally don't have that problem... i think.
That is only possible when you play the tracks in the autoplaylist generated by the podcatcher. If the downloaded tracks have the same problem globally, then it's probably not the components problem. It could be a problem with the rss feed you're subscribed to.
Post by: Xezzy on 2009-08-21 15:53:32
It would be nice to have tag mappings on the go. All podcasters seems to use different tagging scheme, which breaks grouping in foobar...
Post by: Cablespider on 2009-08-21 21:43:45
I started using this today. This is hot! Thanks!
Post by: nausea on 2009-09-02 05:19:53
Released version 0.0.5. Available from all the usual outlets.
Post by: nausea on 2009-09-12 12:11:09
Now at version 0.0.6.
This version has a fix for garbage being appended to downloaded files, which caused problems with playback of non-mp3 files.
Post by: thecircusfreak on 2009-09-14 18:12:03
I get object not found errors with both versions .5 .6. Although server responds ok (200, as I see sniffing it) pod catcher responds with object not found. None of my subscriptions works, is it only me, why noone reported sth like that yet?
Also there is a bug in the way it handles (I think the years in)dates, test case subscription: http://www.awaretek.com/python/index.xml (http://www.awaretek.com/python/index.xml). I get this "Podcatcher: Error in RFC822 time formatting (31 Apr 2006 20:19:00 -0400).", when I am trying to update the podcast subscription
Post by: halabund on 2009-09-14 21:50:05
I'm glad this useful component is still being developed
I've just upgraded to version 0.0.6.  It seems that the seek-bar bug is still present:  the seek bar is non functioning (greyed out and not moving) the very first time a track is played from the playlist (but it is possible to seek using the shortcut keys).  This is about already downloaded tracks.
Also, in this new version the dates look a bit funny (http://img122.imageshack.us/img122/2185/podcatcher.png).
Post by: nausea on 2009-09-14 23:40:11
thecircusfreak:
I get the "object not found" error when the download location is not valid. Is that the problem you have?
Also, 2006 is ok, but April only has 30 days
halabund:
I can't reproduce the seek-bar problem. Perhaps there is a conflict with another component. As they are simply mp3s on your hard-drive after downloading (but perhaps not in your media library) can you reproduce the problem with some other unplayed file?
The date problem will be fixed for the next version. I was using superscript st, nd, rd, and th for the dates, but I guess not all fonts have those characters.
Thanks for the feedback.
Post by: thecircusfreak on 2009-09-15 13:17:21
Ouch, didnt think the feed was to blame!
Now  as far as the object not found problem, I checked it before reporting it, and the download location is there. I also tried  removing the subscription and readding it, but the problem remains. Check this for example: http://tv.nationalreview.com/uncommonknowledge/audio.xml (http://tv.nationalreview.com/uncommonknowledge/audio.xml)
Post by: nausea on 2009-09-15 14:03:21
[quote author=thecircusfreak link=msg=0 date=]Ouch, didnt think the feed was to blame![/quote]
Don't worry, it's still worth knowing about. I can add it to my test case list and at some point in the distant future when every other feature is implemented I can work on some sloppy date formatting code.
[quote author=thecircusfreak link=msg=0 date=]Now  as far as the object not found problem...[/quote]
The next version should help to identify the point of failure more precisely, and we can try to work it out.
Post by: thecircusfreak on 2009-09-15 16:22:33
duh, it was the download dir at the local drive which was set at the wrong place.
...and now  I also noticed that s exactly what you probably meant above. What I can say, maybe I'm a little on the slow side...
Thanks for all your efforts nausea.
Post by: halabund on 2009-09-15 22:20:18
nausea,
The seekbar problem seems to only be present when using Columns UI.  I removed %appdata%\foobar2000, removed all 3rd party components (except podcatcher and Columns UI), and then tested it with both UIs (removing the settings directory between the tests).
I'll post this in the Columns UI thread too then, but still: I've never experienced problems like this, except with podcatcher's playist.
The strange thing is that the problem occurs only the very first time the (downloaded) track is played.  If it is stopped, then played again, the seekbar is fine.
For the reference, here are the exact steps to reproduce:
1. Use a clean foobar2000 install (remove the settings files, %appdata%\foobar2000).  Make sure Columns UI is installed.
2. Start foobar2000, choose to use Columns UI (the program offers the option on first start).
3. Configure the download dir for podcatcher, subscribe to a podcast feed, and download the first podcast.
4. Create a playlist using podcatcher.
5. Play the downloaded track from the playlist.  Observe that the seekbar is greyed out and not moving.
EDIT: component versions:  podcatcher: 0.0.6, columns ui: 0.3.8.0
EDIT2: link to post in columns ui thread (http://www.hydrogenaudio.org/forums/index.php?showtopic=28647&view=findpost&p=657685)
Post by: nausea on 2009-09-16 00:06:11
Cool. I'll see what there is that can be done about it. Just guessing, but it may be something to do with the track not having any length info associated with it before the first play. Neither the RSS or Atom standards include this, but I think podcast feeds formatted for itunes (i.e. all of them) have an <itunes:duration> element which I'll try using in the next version.
In the meantime v0.0.7 is out with a few small changes.
Post by: nausea on 2009-09-16 10:38:03
There's a serious bug in foo_podcatcher v0.0.7. Anyone who downloaded it should upgrade to 0.0.7b now: http://www.unkempt.co.uk/fb2k/foo_podcatcher.html (http://www.unkempt.co.uk/fb2k/foo_podcatcher.html)
Apologies to anyone this affected, and no more late night updates I think...
Post by: thecircusfreak on 2009-09-16 16:32:00
also created playlists contain items from other subscriptions.
Post by: nausea on 2009-09-16 21:07:12
Thanks for reporting. Fixed in the just released version 0.0.7c.
Post by: LoopinFool on 2009-09-25 23:25:54
Nausea,
First of all, thanks for creating a really useful plugin! I've been dealing with some podcasts by manually downloading them and others with .m3u files containing URLs. I love having a central place to manage them which can update itself from the RSS feeds.
I'm having trouble with one podcast I found. The url is: http://feeds.wnyc.org/radiolab (http://feeds.wnyc.org/radiolab)
Looking at it in FireFox, it's clear that foo_podcatcher properly adds all the MP3 files that their XML correctly tags as "MPEG Layer 3 Audio" and have a file size. However, many of their media files have no MIME type or size listed. Those URLs do not get added to the feed's list in podcatcher.
I'm not sure the best way to deal with this. You could perhaps add them based on file extension, if the MIME type is empty. I know there are a lot of potential file types, but even just *.mp3 would help a lot.
I also emailed the radio show to point out the errors in their RSS feed.
Thanks,
- LoopinFool
Post by: Benji99 on 2009-09-26 07:21:00
I finally installed this plugin a couple days ago and I think it's fantastic!
I've been looking for a very long time for a podcatcher in Foobar, Thanks!!
I have a couple suggestions for future versions:
- I second the idea of automatically tagging downloaded files in a certain way (ie setting the genre to Podcast)
- I'd love to be able to change the title of the Podcast, For example I like to group my news, tech, etc podcasts, allowing us to do this would then change the the downloaded folder
- Instead of the above, allowing us to change the downloaded folder would be cool.
- Allowing us to filter podcasts from being downloaded using TAGZ
Anyway keep up the good work!
Post by: LoopinFool on 2009-10-02 21:36:16
Here's my main feature suggestion:
I'd like to have some podcasts download but others remain as links. I'm sure this would be a popular feature. Some feeds, like daily news articles and such would just be links for listening on my desktop when I have time. Others, like longer weekly podcasts should be downloaded so I can save them to another computer, memory stick, or portable media player.
It might be nice to have a "download all podcasts" option rather than a maximum of 10. It's not hard to just select them all and queue them, but what if a single RSS feed adds 20 items all at once. Only the last N would get downloaded with the current setting.
- LoopinFool
Post by: nausea on 2009-10-02 22:27:09
LoopinFool: The next major update will probably have per-feed preferences, including download locations and numbers to download. I'll also add a (turn it all the way up to 11) option to download all items in a feed.
Post by: ingver on 2009-10-03 19:23:28
Glad to see it updated! Only 2 things i noticed - the podcatcher tray icon is a bit blurry (I actually have disabled notifications so no problem) and the dates for podcasts are all "Jan 1st 1601" (without quotes)
Running Win7 64 bit
Post by: nausea on 2009-10-03 21:04:45
Do you have an example feed with the date problem?
Post by: ingver on 2009-10-04 15:35:22
http://ws.audioscrobbler.com/2.0/user/Ingver/podcast.rss (http://ws.audioscrobbler.com/2.0/user/Ingver/podcast.rss)
That's the only podcast I'm subscribed to right now... I tried an other one, worked fine. so it must be this specific podcast
Post by: Benji99 on 2009-10-12 20:34:51
Problem with unicode podcasts?
I just added a french language podcast, the title of the podcast is: Les années lumière
It seems that the podcatcher can't read podcasts with non-english marks since it's added as "Les ann"
Furthermore, it doesn't seem to be able to download any podcasts
If I try to queue up any podcasts, I get a message that reads: The file 'C:\Downloads\Podcasts - Foobar'Les ann with Yes or No, are shown as downloaded but are never actually downloaded.
Here is the podcast in question: http://rss.radio-canada.ca/radio/lumiere.xml (http://rss.radio-canada.ca/radio/lumiere.xml)
Hope this gets fixed!
Thanks and keep up the great work
Post by: LoopinFool on 2009-10-13 00:14:09
I noticed that the download directory has to exist for downloads to succeed. foo_podcatcher won't create the main download directory for you.
Perhaps that's your issue with downloads?
- LoopinFool
Post by: Benji99 on 2009-10-13 02:51:46
- LoopinFool
Hi LoopinFool,
the podcatcher downloads podcasts fine from all sources EXCEPT for the one I mentioned above with the non-english characters.
Sorry if I wasn't too clear.
Post by: sirDaniel on 2009-11-06 12:09:28
I found that plugin is very nice. Actually i am subscribing 2 podcasts. But i see room for improvements.
In podcatch manager window, I would add an description column (next to name, status url, etc..)
Better playlists managing. Is it possible that podcatcher would update a playlist in foobar with new podcasts detected? One playlist for all podcasts upated automatically
Is it possible to pass the Title and Description information to foo_textdispaly?
Post by: nausea on 2009-11-09 13:22:41
Released another quick update. Main change is that this includes debug information so I can make use of submitted crash reports.
Only other thing is a fix for the encoding in Benji99's feed.
sirDaniel: you can currently create an updating playlist with all podcasts by right-clicking on an empty area of the feed list in the manager dialog. From the context menu select "Create playlist (all)".
Post by: LoopinFool on 2009-11-09 17:52:08
Here's one quick suggestion for the auto-updating playlists.
It would be nice if they could (optionally?) be ordered oldest on top. Since foobar2000 plays lists top-to-bottom the chronology is currently reversed. You can manually reverse the playlist in foobar, but I've assumed it would get overwritten whenever the feed updates.
This would probably be a good candidate for a per-feed setting whenever you add those.
Thanks again for this great plugin! My wife has one main podcast she listens to, and the foobar2000/podcatcher combo has made it really easy for her.
- LoopinFool
Post by: nausea on 2009-11-11 23:46:48
Updated the first post with details of version 0.1.0.
For those interested, this version stores the feeds and podcasts in a separate file from the foobar2000 configuration, as it was causing it to balloon in size. Settings from version 0.0.x are transferred however.
Let me know of problems that have may have been introduced.
Post by: q-stankovic on 2009-11-15 18:51:39
Hello nausea,
since the podcatch manager doesn't show the files anymore in its window, i hope you will find a way to show the status of a file (just url, queued, downloaded).
Thanks for the component.
Post by: kaoruAngel on 2009-11-15 23:58:01
Hey nausea, just now trying to get into the podcast thang and found your component. First thing I've noticed so far is that the preferences page text is clipped.
(http://img196.imageshack.us/img196/2452/foobar2kpodcatcherpreft.png)
I'm using Vista x64 w/ my Font Size set to 120dpi. Occasionally I run into a program where the text isn't doesn't display right presumably because it doesn't adapt well to the dpi setting. Seems like this might be one of 'em.
Looking forward to getting my podcast groove on. Please PM me if you happen to fix this.
Post by: nausea on 2009-11-20 10:03:51
Released v0.1.0b. Only change is fix for a crash bug in the date parsing.
Hadn't seen this before the release, but will look into for the next one. I'll see if there is a standard way of handling this. I've wondered before what happens when people use non-default settings, but these things remain low priority until someone points them out, so thanks.
Post by: skyfish on 2009-11-27 05:44:52
Doesn't work with foobar v.1.0b
Post by: Hank H. on 2009-11-27 10:57:10
Thanks a lot for the great work, it's really appreciated.
I have one problem though: Whenever I shut down and restart foobar 0.9.6.9, the entries in my podcatch manager as well as in the podcast playlist are gone. Is this intended (don't think so)? Did I miss anything in the properties dialog?
Suggestions for the long-term evolution:
- opml import/export
- be able to add the podcatch manager as an UI-element.
Post by: odyssey on 2009-12-07 12:41:11
Please update it to work with foobar2000 1.0
Post by: nausea on 2009-12-11 00:57:58
Hank: Could you check your foobar2000 profile folder? You can find it from the General page of the foobar2000 preferences dialog. Is there a file called foo_podatcher_config.xml? If not can you think of any reason this might not be created, such as the folder being write protected?
I've released version 0.1.1b. The main changes are related to downloading podcasts.
There is a problem with v0.1.1 for XP users so I have rolled back for now until I work out what was causing it. If you downloaded the new version and are using XP I recommend you downgrade.
Above problem is fixed in version v0.1.1b, which is now released. Get it here: http://www.unkempt.co.uk/fb2k/foo_podcatcher.html (http://www.unkempt.co.uk/fb2k/foo_podcatcher.html)
This is still with the v0.9.6 SDK, so foobar2000 v1.0 beta users will still get the warning message on startup.
Post by: q-stankovic on 2009-12-13 10:56:33
Nice update and happy to see the component on foobar2000s components site! Thanks!
Post by: StuPC on 2009-12-13 19:53:43
I'm running foobar 1.0 beta 4 on Windows 7 and it's still giving a "not supported" error message when I start foobar... :-(
Post by: q-stankovic on 2009-12-13 20:50:30
Two posts before yours:
Post by: odyssey on 2009-12-13 22:16:29
[quote author=q-stankovic link=msg=673250 date=1260737430]Two posts before yours:
[/quote]
How come many other components doesn't exploit that message then?
Post by: Yirkha on 2009-12-13 22:30:25
Because many other components don't use the old/updated playlist_loader API.
Post by: nausea on 2009-12-13 22:35:05
They happen not to be using one of the depreciated SDK features this component does. I would expect (as it also happens to foo_lastfm_radio) that in this case it is my use of playlist_loader, which is being replaced in the new SDK. Peter has indicated that the new SDK will be released before v1.0 final, and when it is I'll be able to use the new replacement feature.
Post by: Hank H. on 2009-12-14 17:51:32
You are right, the folder is write protected and doesn't have the foo_podatcher_config.xml. And I have no clue where the write protection comes from, I can't remove it - it always comes back. I'm using Windows XP by the way, if anyone has an idea...
Post by: Hank H. on 2009-12-14 19:03:31
Well, about the write protection: Windows Explorer tells me it is protected. But that apparently doesn't mean much. The foobar database uses the same folder and works, as well as playback statistics. I can also create new files in that  folder. So there might be a different reason why foo_podcatcher doesn't create its config.
Moderation: Removed useless full quote of the preceding post.
Post by: sirDaniel on 2009-12-15 12:56:50
I see the plugin is impoving continuously, i like that. But with new features some older behaviour changed. When i create playlist for all, the newest podcasts are at the bottom. Is that intended or i messed wit something? Can i get the newest at the top of the playlist?
Ok now, while having playlist:all, when opening feed manager, the another playlist for just only one feed is created automatically. Can that creating "current" playlist can be turned off? I know it help at begining but i end up with deleting that playlist every opening of manager.
Another improvement would be option: Create playlist (selected).
Bug?: The value of dowloading podcasts speed is wrong. Ive got 128KB/s connection but value is oscillating between 11-17 kB/s in podcast downolad manager. Of course while using full speed.
Thanks for developiong that plugin, i just wanted to share my thoughts.
Post by: Hank H. on 2009-12-17 14:43:33
I chose the application install folder for my configuration files instead of the user profile folder. And voilà, podcatcher works.
I do however have the reported problem with incorrect dates with some podcasts. Doesn't bother me much.
Thanks for the component and for the advice!
Hank
Post by: RockandRoll19 on 2009-12-20 01:32:31
Hey! Thank you so much for your contribution to foobar. I've tried foobar in the past, and it has treated me well, but I've always thought "Hm, this needs a podcast support program" and lo and behold PODCATCHER!!! Anyways, I already have podcasts on my ipod, and the new stuff I download doesn't get added to the other podcasts it just get added to the music, I was wondering if there was a way to add the podcasts I've downloaded to the rest of the podcasts? Thanks.
Post by: ubiquitousnfunky on 2009-12-20 18:46:14
Hey! foo_podcatcher is great! I have some suggestions for improvements: (wishlist in oder of importance to me)
1. When new rss feeds are added, the date field is filled with the date from the feed, e.g. 2009-12-20. However, once the the mp3-file for an episode has been downloaded, the value from the file seems to be used. Some podcats however only put the year in the date field and the complete date in the title. - This is annoying when one has multiple podcasts and wants to sort them according to date so as to immediately see the most recent episodes from any podcast.
My suggestion would be for foo_podcatcher to have an option to overwrite the date field in the mp3-file after downloading with the (complete) date from the rss feed. Also, consistent date notation should be ensured if different rss feeds use different date formats to allow consistent sorting.
2. It would be great to be informed with a tray-icon when new episodes are available and have finished downloading. I.e. similar to the icon used by the "Feature Watcher" component. - Nothing too distracting, just a discrete hint to take a look at your podcasts at some point...
3. Podcatcher already has the option to download only podcast newer than X days, months, etc. It would be great if a fixed no of episodes could be specified, e.g. the newest 4, so as not be dependent on the publishing frequency of the podcast.
4. When adding a new rss feed and after downloading the newest X episodes, the newest X episodes from the feed are no longer grouped with the undownloaded episodes from the feed in the grouped with UI Columns and NG Playlist. They appears as if they belonged to two different albums. E.g. one album has the downloaded album art, the "album" with the yet undownloaded episodes has no album art. - After downloading the first X episodes the album art should be applied to all (also undownloaded) episodes and they should appear grouped in one single group.
5. When adding a new rss feed, all episodes available in the rss feed are added. I would find it useful if one could specify podcatcher to only show e.g. the last 10 episodes in the playlist. - Currently it is possible to delete episodes manually from the list when it becomes too long, but it would be great to automate this.
To me, these additions would make podcatcher absolutely perfect.
Many thanks nausea for the great work!
- ubiquitousnfunky
Post by: halabund on 2009-12-24 10:35:04
There is one thing that is slightly annoying about how foo_podcatcher works.  Some podcasts (http://www.scientificamerican.com/podcast/podcasts.cfm?id=60-second-science) use the same filename for every clip, so podcatcher overwrites the same file again and again (and pops up a dialogue to ask for permission for overwriting).  I don't know how other podcast downloaders handle this (if they handle it at all), as I have never used any other such program.  Perhaps they rename the files using the date?
Post by: nausea on 2009-12-24 13:45:41
Some podcasts use the same filename for every clip, so podcatcher overwrites the same file again and again (and pops up a dialogue to ask for permission for overwriting).
You can use title-formatting code in the download path, e.g. S:\Media\Podcasts\%album%\$date(%date%).%filename_ext%, and set per-feed settings if you don't want all feeds to use a particular path.
Post by: halabund on 2009-12-24 13:59:00
Ah, OK, that's great!  Didn't notice that possibility.
Post by: nausea on 2009-12-25 02:39:15
Versions 0.1.2 and 0.1.5 for foobar2000 v0.9.6 and the v1.0 betas respectively. Get them from the usual place: http://www.unkempt.co.uk/fb2k/foo_podcatcher.html (http://www.unkempt.co.uk/fb2k/foo_podcatcher.html)
0.1.5 has support for new SDK features including the preferences page and UI Elements for the Default UI. Known issues for this version include the Feed Manager group headers not respecting the Default UI colour scheme and the keyboard accelerators not working. I'll look into these in due course.
I'll be offline for a week or so now, but bug reports are still welcome. I'll deal with them when I'm back. And to those who celebrate it, Merry Christmas!
Post by: q-stankovic on 2009-12-25 18:24:57
... but bug reports are still welcome.  ...
Ok!
A doubleclick in download manager exactly on the text "no current downloads" causes foobar2000 to close - that doesn't happen in orher areas of download manager. Using version 0.1.5.
Post by: halabund on 2009-12-25 20:14:45
How can we turn on the "cover art" display in the feed manager in version 0.1.5?  Has this feature been removed?
Post by: q-stankovic on 2009-12-25 20:39:08
For me it seems to be removed also.
Here one issue more:
Removing podcasts by contextmenu -> Podcatcher -> Remove podcasts doesn't have a direct effect: you have to reload the podcatcher playlist.
Post by: nausea on 2009-12-25 23:03:53
[quote author=q-stankovic link=msg=675305 date=1261765497]A doubleclick in download manager exactly on the text "no current downloads" causes foobar2000 to close[/quote]Fixed in 0.1.5b. Thanks for letting me know.
[quote author=halabund link=msg=0 date=]How can we turn on the "cover art" display in the feed manager in version 0.1.5? Has this feature been removed?[/quote]The Podcatcher Feed Managed preferences can be accessed when "Enable Layout Editing Mode" is selected.
[quote author=q-stankovic link=msg=0 date=]Removing podcasts by contextmenu -> Podcatcher -> Remove podcasts doesn't have a direct effect: you have to reload the podcatcher playlist.[/quote]This is intentional (for now). The items are removed from database. But yes, it should be made clearer.
Post by: halabund on 2009-12-25 23:06:12
The Podcatcher Feed Managed preferences can be accessed when "Enable Layout Editing Mode" is selected.[/quote]
Ah, so then this is only accessible from the Default UI, but not Columns UI?
Post by: q-stankovic on 2009-12-26 00:02:51
You mean the foo_podcatcher_config.xml? I just can't recognize the sense of making removal visible not until the next loading.
In context of removed podcast (i guess the sense is to show only podcasts of interest) there is an annoyance:
You can only make all podcasts visible again if you update but this would ask you if you want to overwrite existing files. It seems to me that on one side foo_podcatcher isn't aware that these podcast was downloaded because of removal in database and on another side when it comes to storage on harddisc it "remembers" but still aks for overwriting. A little bit confusing, isn't it?
Edit
Idea: Maybe instead of removal from database marking "removed podcasts" inside database as invisible?
Post by: q-stankovic on 2009-12-26 15:13:07
Hello nausea!
Here a behaviour that seems mysterious to me as i cannot comprehend its meaning:
1. When you load a podcatcher playlist you have a list of entries wich fields (Artist, Album and Title) are builded by following rule: Artist = <parent author>, Album = <parent title> and Title = <title>. Also there is no display of length.
When you then doubleclick a  podcast for playing the length is displayed and content of the field are changing: Artist = first part of <title>, Album = last part of <parent title> and Title = second part of <title>. Why is that?
2. As long as foobar is open the changes described above are stored: you can delete the podcatcher playlist and reload it again even. But after restart of foobar2000 all changes are forgotten: Also the displayed length is away.
Would like to ask if a) the switching of fields content could be disposed and b) the display of length be kept.
Thanks for Podcatcher!
Merry Christmas!
Post by: AndyL on 2009-12-27 10:34:20
Many thanks for the updates!
Post by: wolver1ne on 2009-12-27 11:58:57
Finally! Have been looking for ever for a podcast plugin. Works great!
Is there a chance you could make a panel for Columns UI? Or am I missing something?
Post by: halabund on 2009-12-27 15:34:20
A chance for a minor improvement is making the "Open Containing Folder" context menu item work with podcasts (like with other on-disk files).  Of course it could only work with downloaded podcasts.  I would mainly use it when copying files to a portable device.
Post by: Hank H. on 2010-01-01 18:23:17
Request:
It would be great to be able to sort the subscribed channels by name etc. in the podcatcher feed manager. Otherwise it becomes quite confusing when you subscribe to lots of podcasts.
Post by: nausea on 2010-01-05 11:30:38
Released version 0.1.5c with some fixes and changes based on the recent feedback. http://www.unkempt.co.uk/fb2k/foo_podcatcher.html (http://www.unkempt.co.uk/fb2k/foo_podcatcher.html)
Regarding "Open Containing Folder" not being enabled. Not sure why this is, but it is and I'll look into it.
Post by: halabund on 2010-01-05 12:13:49
Thanks for making it possible to enable tile view without DUI again!  It seems that after playing around with podcatcher for long enough, the cover images get messed up every time, though I haven't been able to figure out what triggers this.  By "messed up" I mean that all cover images are there, but they're assigned to the wrong podcasts.  Toggling tile view might fix it temporarily.  Should I try to reset podcatcher by removing foo_podatcher_config.xml and re-subscribing to everything?
EDIT:  here's what happens: http://img52.imageshack.us/img52/9817/pctile.png (http://img52.imageshack.us/img52/9817/pctile.png)
Post by: nausea on 2010-01-05 12:43:50
No don't delete the file, it won't fix the problem. There will be a bug somewhere in the dialog code.
Edit: Ok, I've reproduced it. I'll look into it. Thanks for reporting.
Edit 2: And it's fixed.
Post by: Sebert on 2010-01-05 17:25:29
I've just discovered this. Finally I can uninstall Happyfish/iTunes. Thank you a lot !
Three questions:
Ist there a way to automatically download the images embedded in the feeds ?
Any plans for a panel version of this?
Some podcasts embed some html code in the "Comment" tag of the mp3 file. I am not good @title formatting, does any one know a way NOT
to display the html code, but just the text ?
Comment Entry:
<img src="http://www.dradio.de/images/39781/landscape/133,0/" height="100" width="133" border="0" align="left" hspace="4" vspace="4">Eines der Projekte, die sich auf dem 26. &quot;Chaos Communication Congress&quot; vorstellen, glänzt mit Stillstand – in der Luft: Die Mitglieder des Projekts Mikrokopter verändern die ferngesteuerten handelsüblichen Minihubschrauber oder bauen sie auch komplett selbst. <br clear="all"><br>Deutschlandfunk, Forschung Aktuell<br><a href="http://podcast-mp3.dradio.de/podcast/2009/12/29/dlf_20091229_1640_38ce6940.mp3">Direkter Link zur Audiodatei</a><br><p><br></p>
What I'd like to see (I don't mind the "&quot;"):
Again......Thank You !
Post by: nausea on 2010-01-08 23:01:26
Released version 0.1.5e. The "Open Containing Folder" context menu option should now be enabled for downloaded files.
Post by: Sebert on 2010-01-09 17:26:22
Ok, did some kind of half-ass job on fixing my formatting issue.
Two more feature requests:
- Some way to configure how often feeds should be checked for updates !
- Merge the "Remove Podcast" with "Delete File", so both can be done in one step !
Thanks for the update !
Post by: ctkatz on 2010-01-10 03:49:53
i would like to second the request for automatic tagging for downloaded podcasts.  since this plugin doesn't automatically set podcasts as podcasts for ipods (and the ipod plugin can't set podcasts as podcasts) it makes finding them in the music list a lot easier to find.
Post by: Conan76 on 2010-01-11 19:32:31
Hi !
Today I'm a new Foobar (v1.0) user ;-)
i've just installed Podcatcher to download my (only) podcast, but i've got a problem. My audio files are saved in network directory, and i've got a sub directory "Podcast".
But when podcatcher download podcast files to my network directory i've got an error :
http://www.azeroth.fr/audio/azerothep17.mp3' (http://www.azeroth.fr/audio/azerothep17.mp3') to 'file://\\a64\musique\Podcasts\Azeroth.fr\azerothep17.mp3'
Podcatcher: Error creating folder 'file://\\a64\musique\Podcasts\Azeroth.fr' (Invalid path syntax)
Podcatcher: Finished downloading podcast item(s).
Can you just add this possibility in podcatcher ?
Podcast source is : http://www.azeroth.fr/azerothrss.xml (http://www.azeroth.fr/azerothrss.xml)
Thanks, and sorry for my english
Post by: nausea on 2010-01-12 01:26:21
Downloading to network paths was broken in the previous release. Fixed in v0.1.5f.
Post by: saltaslt on 2010-01-12 10:30:48
no love (UI Elements) for Columns UI?
Post by: nausea on 2010-01-12 11:26:07
Not ruling it out, but am hoping some resourceful individual will create a UI Element containing UI Panel. That would keep my implementation cleaner, and help me focus on other features.
Post by: wiggedywoo on 2010-01-12 18:20:00
Any chance you can add support for download paths relative to the install directory? I currently have my foobar installed in portable mode and my media library path as ..\Mp3s\ . It would be nice to have the podcast download location set to ..\Mp3s\Podcasts\
Thanks for a top component.
Post by: q-stankovic on 2010-01-12 20:35:11
Hello nausea,
so far the downloaded and not downloaded podcast are placed in the podcatcher playlists.
What dow you think of a clean seperation of these two types?
I mean following: the feed manager offers the possibilty (button? checkbox) to switch between a online mode, that shows the online podcasts, and a local mode that would show only downloaded podcasts stored on disc. An automatic refresh of already open podcatcher playlists after changing mode would be nice.
Post by: Bodhi on 2010-01-12 21:34:15
Hi, is there any tutorial somewhere?
Post by: Sebert on 2010-01-13 18:32:06
For what? What do you want to know ?
Post by: nosgah on 2010-01-29 11:37:07
I second q-stankovic's request (#113). such a feature would be extremely helpful.
Post by: Zilog Jones on 2010-02-03 13:36:34
Yes, is there any way to indicate that a particular podcast has been downloaded or not? I was downloading an entire series, but closed Foobar before it finished and wasn't sure which it had actually downloaded outside of looking at the actual files in the destination folder. And when I re-opened Foobar it did not continue downloading, so I manually had to select the rest to download again.
Besides that it's a great component, thanks nausea!
Post by: Phog Allen on 2010-02-06 01:03:48
Well I am not Bodhi but I would add my request for a mini tutorial for the podcatcher functions. Please go easy on me. I am a newb to really getting in the guts of Foobar. Let alone expanded functionality like Podcatcher. There are two main things I am having trouble with. The podcatcher manager/interface or whatever it should be called. I am probably overlooking something simple but this is what I get when I look for the podcatching functions;
File>Update Podcasts. Doesn't seem to do anything.
View menu> Podcatcher Download Manager and Podcatcher Feed Manager. Clicking either one opens a small dialogue box. The Feed Manager is pretty straightforward. It has a box to paste urls to the feed you want. Easy. The Download Manager is a mystery. There is nothing there other than column names such as Title and Status. I managed to get the podcast I subscribed to to appear in the main player window. The only way they would download to a folder was to highlight them and right click. This brought up a menu with "Download Podcasts" and "Remove Podcasts" and an unhilighted "Podcast Properties" that was unclickable.
The only other items related to Podcatcher is a new tab that says of course, Podcatcher. This brings up nothing different onscreen than default or new playlist tabs. It looks identical but will have whatever podcasts you tried to download listed there. And last, there is a function under Library>Configure>Tools>Podcatcher  that lets you set file path, refresh dates, etc. I am also using Columns UI. Does this make a difference? When I go to nausea's podcatcher homepage, I notice his screenshot shows a nice interface on the left side of the screen and a list of his pods on the right. This is very clean and easy to understand. I would really like to bring up a screen/panel or whatever you call it that has a few of these functions listed together. BTW, my Columns display is the NG Playlists + Playlists Tabs if that makes a difference. Sorry to be so long but this a very useful component for Foobar and I vastly prefer to try to use Foobar vs stuff like Juice or iTunes.  I have used Foobar for a couple of years but only in a very rudimentary way.  I haven't done much customising of it and I am sure I am missing easy tweaks. So again. sorry for newb questions. And a big thanks to the author. Great component.
Post by: Phog Allen on 2010-02-06 15:48:24
Sorry guys. After further reading it would seem this is geared more toward the Default UI. Is this correct? I fiddled around with Layout>Enable Layout Editing Mode and got a configuration that is very close to the one shown on the homepage. One thing I have not figured out is the little panel(I think that is right) in the lower left corner of nausea's screenshot. I like it that the toolbar header has Title and Status there. This is quite easy and intuitive to read and understand what is going on with the file selected. What I can't figure out is how to get that toolbar. I went into the Layout Editing Mode and added the UI Element "toolbar header". Fine. Now how do you get it to provide the functions you need? I right clicked it and that brings up a menu of choices that seem to be the only ones available and title or status are not options. Is this panel or toolbar or whatever you call it something that was custom configured or is it part of a pre configured UI group? Thanks guys and sorry for the newb confusion. I really have been searching the forums for a hint about the toolbar functions but can't seem to find much talk of it.
Post by: Zilog Jones on 2010-02-06 18:57:16
I think this checks the feeds for updates. A pop-up in the System Tray should appear when it finds something new, but I guess nothing happens if there is nothing.
For me (in Default UI) it says "No current downloads." - I guess it will show file transfer status if it is downloading something.
Podcast Properties works for me when I select a single podcast - it diplays some data and IDs and stuff, and download status (didn't notice this before). It is greyed out if I select more than one.
It looks like the Download Manager.
Post by: fpd on 2010-02-06 19:38:26
I certainly hope this is possible but have doubts as to whether it is feasible as I would have thought that UI panels depend on the default UI's dll being loaded.  I very much would like to use the podcatcher in columns ui.
I believe a number of columns ui components eg Lyric Show Panel have been updated to support the default ui eg. the Lyric Show Panel, but of course understand if this will take a lot of coding time, I have a lot of respect for all the devs making plugins available to the public for free!
Post by: halabund on 2010-02-06 21:00:33
Problem report:
The Podcatcher playlists are editable (i.e. items can be deleted).  Since these playlists are managed and updated automatically by Podcatcher, shouldn't they be locked?  If my memory serves me well, they used to be locked in an earlier version, but I'm not sure...
Version info: fb2k 1.0, podcatcher 0.1.5f
Post by: nausea on 2010-02-06 22:03:46
Thanks for all the feedback. I'm currently working on v0.1.6, and will try to take these things into account.
The main changes implemented so far are a preference for re-tagging files on download (as a global and per-feed option), the Podcatcher Feed Properties Dialog implemented as a Default UI element, feeds are checked in parallel three at a time, and the component notes when podcast items were last "seen" in their respective feeds (which I might use in future versions for either manually or automatically removing "dead" podcast items).
I've had a partially successful go at making the group headers in the various dialogs respect the Default UI colours, but that's more complicated than you'd hope.
I'm working on a preference which analyses when and how often a feed is updated and will automatically adjust the update period accordingly. For example, if a feed has historically updated mid-day Tuesday, check half-hourly around then, perhaps hourly on the rest of Tuesday, and half-daily the rest of the week. Or if a feed hasn't updated for a few months, check it daily.
There is also a long-standing bug where update and download threads are lost(?) and don't return. This is evident when a download is stalled and more can't be started, or if the feeds can't be updated (and perhaps are all marked as queued). Restarting foobar2000 is the workaround. I think this happens on my laptop when it is put to standby in the middle of such an operation and I suppose some function in the thread doesn't time-out when it is woken. Anyway, that's something I need to investigate before the next release.
I'm busy at the moment though so it might take some time before release.
Post by: Phog Allen on 2010-02-07 02:38:59
Right you are sir. I just added it to the display and it looks great. Functional and to the point. Thanks for pointing it out. I have no idea why I didn't just try it. I tried almost every other option in UI Elements!
Nausea. Thanks again for the great component. This is what podcatching should be. Not a  bunch stuff you don't really use. I would love nothing more than to ditch Juice and Doppler for good. Foobar is such a good player and this kills two birds with one stone. Thanks again.
Post by: Spacious Mind on 2010-02-10 02:53:24
hi. thanks for such a useful app!
im new to all this stuff, and have been going through adding some podcast feeds, most of which work fine,
but i came across two that refuse to load into podcast catcher. . .. they claim to be RSS feeds on their sites, anyway, if theres any way to get them up please let me know
http://www.sfbrp.com/archives/category/podcast (http://www.sfbrp.com/archives/category/podcast)
http://www.matrixmasters.com/podcasts/Psyc...licThinking.xml (http://www.matrixmasters.com/podcasts/PsychedelicThinking.xml)
thanks!
Post by: Phog Allen on 2010-02-10 13:18:14
I have the same problem with this url; http://www.12byzantinerulers.com/rss.xml (http://www.12byzantinerulers.com/rss.xml). Foo_podcatcher would not subscribe to it. I gave it a go in Doppler and it worked there. Any ideas? Thanks.
Post by: Phog Allen on 2010-02-10 13:20:59
I am having similar issues with this url; http://www.12byzantinerulers.com/rss.xml (http://www.12byzantinerulers.com/rss.xml) Podcatcher won't subscribe to it. I checked this with Doppler and it worked there. Any suggestions? Thanks.
Sorry. Somehow I double posted this. It gave an error the first time and then showed both posts the next. I am not sure what happened.
Post by: sabio on 2010-02-10 19:18:39
Any chance to get "post-processing" for downloaded entries?
Say, I'd like to speed them up 25% with foo_dsp_sountouch, run through ReplayGain or maybe remove "audio banner" in the beginning with some external program.
Then you could also "generalize" re-tagging as one of post-processing actions.
Post by: Spacious Mind on 2010-02-11 20:34:39
hey, ive loaded a pretty big list of podcast feeds now, and it seems to be using a fair chunk of bandwidth every hour or so to update them all ( I am in new zealand where bandwidth is pretty limited!) .. . . .
is there a way to maybe make it update feeds upon loading foobar and not have anymore automatic updates after that ?
Post by: halabund on 2010-02-11 21:12:49
Spacious Mind: nausea mentioned in his last post (http://www.hydrogenaudio.org/forums/index.php?showtopic=69053&view=findpost&p=686089) that he's working on fixing that.
Post by: halabund on 2010-02-14 01:51:47
Another problem report:
I subscribed to the podcast from http://www.wnyc.org/shows/radiolab/ (http://www.wnyc.org/shows/radiolab/) using the feed URL http://feeds.wnyc.org/radiolab?utm_source=...mpaign=radiolab (http://feeds.wnyc.org/radiolab?utm_source=rss&utm_medium=hp&utm_campaign=radiolab)
However, the generated playlist only contains the podcasts up to last August.  The last one is "Proof" from Aug 10, even though many more have been released since, as can be seen in the feed (when viewed in the browser).  I also tried useing the feed URL http://feeds.wnyc.org/radiolab (http://feeds.wnyc.org/radiolab) , but it just gave me an empty playlist.
Post by: sabio on 2010-02-14 10:03:42
I guess the problem is that podcast author(s) didn't bother to update the feed file since August
Post by: halabund on 2010-02-14 10:35:46
As I already said, if you check the feed, you'll see that it has been updated.
Post by: sabio on 2010-02-14 11:22:21
Indeed. When you said about "seen in the browser" I thought you confuse web page content vs feed content.
But the feed really contains the new entries:
<pubDate>Mon, 08 Feb 2010 14:38:48 -0800</pubDate>
The problem I guess is the structural change of the feed. E.g. the latest entry with tag
<media:content url="http://feeds.wnyc.org/~r/radiolab/~5/ian8MWagS7w/radiolab_podcast10proof.mp3" fileSize="7982163" type="audio/mpeg" />
was on 10 Aug 2009. After that mp3 is only referenced in something like:
<enclosure url="http://feeds.wnyc.org/~r/radiolab/~5/DJFiSgBSIRU/radiolab_podcast15sum.mp3" length="0" type="" /><feedburner:origEnclosureLink>http://audio.wnyc.org/radiolab_podcast/radiolab_podcast15sum.mp3</feedburner:origEnclosureLink>
Post by: nausea on 2010-02-14 11:56:18
sabio is right. The problem with that particular feed is the blank type attribute for the recent entries. foo_podcatcher is looking for the "audio/*" type. There were also similar problems with some of the other feeds posted. I've made the next version more tolerant of these things and those feeds now work properly.
I'll release an update with these and some more changes in the next week or so.
Title: foo_podcatcher
Post by: TheNickromancer on 2010-02-17 04:51:29
Just recently got back into foobar too long of a stint with iTunes. I used iTunes to manage my podcasts, so I'm glad to see this component for fb2k! I hope you keep it going.
The only real complaint I've had was previously brought up by ubiquitousnfunky, regarding the date tagging...
Things do start to get quite messy when the dates from the feeds are simply replaced with the year, as I'd like to keep them in chronological order. If this can be fixed, or if theres some other kind of workaround, that would be much preferred.
Post by: nausea on 2010-02-27 04:14:31
Bump for version 0.1.6.
Don't forget to file any crash reports with the foobar2000 crash reporter. I haven't seen any reports since v0.1.5 but there are lots of changes in this release, so who knows what might have slipped through.
Go get it: http://www.unkempt.co.uk/fb2k/foo_podcatcher.html (http://www.unkempt.co.uk/fb2k/foo_podcatcher.html)
Post by: halabund on 2010-02-27 12:26:28
If the download location is changed, a φ is appended to the podcast name in the feed manager.  If re-tagging is enabled, a τ is appended.  Are these Greek letters really the symbols that you meant to append, or is it just misbehaving on my machine?
Another question: what is the Orphaned Podcast category for exactly?
Post by: nausea on 2010-02-27 12:34:46
Yes, they are correct. Delta for the download period, tau for tagging, and phi for download path. (There's some convoluted logic in there somewhere...)
They are meant to act as reminders/hints that a feed has custom preferences, but I'm open to ideas of other ways of showing this. The tile view could use overlay icons for example.
It's also possible to turn them off in the preferences.
Edit: Orphaned podcasts are those that remain if a feed is removed. The Orphaned Podcasts category provides an easy way of seeing these without having to pick them individually out of an all items Podcatcher playlist.
Post by: halabund on 2010-02-27 12:50:02
Oh, no, they're fine  And this is a useful feature.  It's just that using Greek letters seemed a bit unusual, so I was wondering if I was seeing them because of some font/display problem on my computer.
Thanks for the new version!  This is a big improvement over the previous one.  Re-tagging and handling incorrect mime types solved the two biggest annoyances.
Post by: halabund on 2010-02-27 13:28:30
I found a small problem:  There is something wrong with the artwork display in the Feed Manager. First, note that I don't have the Feed Manager docked into the main UI (because I use Columns UI).  Here's how to reproduce the problem:
start foobar2000
open the Feed Manager using View -> Podcatcher Feed Manager
wait a couple of seconds until all the artwork appears
close it
open it again
note that the default podcast icon is used for all the podcasts now
After restarting foobar2000, the proper artwork appears again, until the Feed Manager is closed and re-opened.
Another observation: Columns UI can display artwork inline in the playlist.  Most of the podcasts, however, just show the default image, even though they have their own artwork in the Feed Manager.  This problem was present in previous versions too, but I can't figure out what causes the missing artworks (seems mostly random).  Currently only the two very last items show an artwork here.  Previous items from the same podcasts lack the artwork too.  (Note: the artwork pane will only show an artwork for the same elements that have it in the playlist too.  I don't think this is Columns UI specific, it's just easier to see (and more noticeable) which items have an artwork and which don't when viewing them in the playlist, which displays the artwork for all items at the same time.)
EDIT: It may be that it's only shown for downloaded items in this version.
And a suggestion:  If it is possible to do, it would be useful to have the podcasts tagged with the full date (when re-tagging), i.e. year-month-day, not just year.
Post by: Sebert on 2010-02-27 15:41:15
Is there any way to make podcatcher remember which feeds it already downloaded?
When I am not interested in a feed item I first delete it via Podcatcher=> Remove Podcast and then delete the file.
The next time podcatcher checks the feeds it downloads everything again :-(
Post by: Benji99 on 2010-02-27 15:58:47
I have the exact same problem, although lately it doesn't seem to happen anymore.
It used to work 100% fine in the versions of Podcatcher for Foobar 0.9.x
No idea why it seemingly started working lately thoug, was using 0.1.5f, just upgraded to 0.1.6 and will see if it starts happening again.
Post by: Benji99 on 2010-02-27 18:33:00
Since I can't edit my post:
Nevermind it still does it. Seems to happen with really recent podcasts only (Maybe the last one?)
Post by: LoopinFool on 2010-02-27 22:32:31
I reported this one quite a while ago. I also contacted the WNYC people since they're no longer properly tagging their media files (as you figured out). They said they were really busy and would get to it "eventually".
I'm glad to hear it may now work in podcatcher 0.1.6. I'm still on 0.1.2 as I haven't upgraded foobar2000 yet.
- LoopinFool
Post by: nausea on 2010-02-27 22:34:06
Yes, that's something I haven't addressed yet. When a podcast is deleted it is completely forgotten about and so treated as new when the feed is updated again.
It would be simple to keep track of a list of podcast ids for deleted podcasts and ignore them in feeds, but the challenge would be in providing a way to let the user undo a delete.
Post by: halabund on 2010-02-27 23:53:46
Correction to my earlier post (can't edit any more):  The artwork seems to be only shown for downloaded items, but it is not shown for all downloaded items, just for a random subset.
@LoopinFool:  Yep, it works fine in 0.1.6 now.  If all the popular podcatchers followed the standard properly then these workarounds wound't be needed because publishers would be forced to be more careful ...
Post by: nausea on 2010-02-28 00:11:26
foo_podcatcher does not do anything to provide album art. The feed images you see in the Podcatcher Feed Manager when tile view is enabled are only used in that part of the UI. They are read from the feed and cached in the "feed images" folder under your default download folder. What you are seeing is embedded album art which foobar2000 is reading from the downloaded files. Sometimes it's there, sometimes it isn't.
Amen. Keep letting me know of any you which that don't work though.
Post by: Benji99 on 2010-02-28 00:36:04
Oh quick question, I never really figured out what's the purpose of the Podcatcher -> Remove Podcast option.
What does it do exactly? What happens if I don't remove a podcast, but delete the file?
What happens if I remove the podcast and don't delete the file?
Post by: nausea on 2010-02-28 01:09:53
This removes the items from foo_podcatcher's internal list of podcasts. It doesn't currently store any reference to the deleted item so when the feed is checked again it will be re-added to the list. This needs to be changed.
foo_podcatcher will recognise that the downloaded file has been deleted and will revert to using the online file.
The file remains but foo_podcatcher is not aware of it and it will not appear in any Podcatcher playlists. When the feed is checked again the removed podcast will be re-added to the list.
Post by: nausea on 2010-02-28 04:33:15
foo_podcatcher version 0.1.6b: http://www.unkempt.co.uk/fb2k/foo_podcatcher.html (http://www.unkempt.co.uk/fb2k/foo_podcatcher.html)
Post by: sabio on 2010-02-28 12:21:55
@nausea
Sorry for repeating the question.
But what do you think about my "post-processing" idea on the previous page (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=69053&view=findpost&p=686938)?
Do you find it worthy (considering implementing it) or is it "out of scope" for foo_podcatcher?
Post by: nausea on 2010-02-28 20:24:36
I like it. It's about finding time though...
Post by: bubi jackson on 2010-02-28 20:26:43
I've checked "Included only downloaded an new items" but not all downloaded podcasts are shown.
Do I miss something?
Post by: q-stankovic on 2010-02-28 21:35:06
Hello nausea,
i would appreciate if you could a comment to my request (http://www.hydrogenaudio.org/forums/index.php?showtopic=69053&view=findpost&p=679725) or if you thought about any other way of an better distinction between downloaded and not downloaded files.
Thanks for the updates!
Post by: thecircusfreak on 2010-02-28 23:20:29
@q-stankovic
You can just add a column  indicating it.(eg. checking if thee is or there isnt a "http://"  sting in the path of each playlist item.)
Post by: nausea on 2010-03-01 11:36:35
Released version 0.1.6c which fixes a crash when subscribing to an empty feed. Thanks to whoever submitted the crash report.
Not sure. Are the podcasts marked as downloaded (see the Podcast Properties under the Podcatcher heading in the track properties dialog)?
[quote author=q-stankovic link=msg=0 date=]i would appreciate if you could a comment to my request or if you thought about any other way of an better distinction between downloaded and not downloaded files.[/quote]As thecircusfreak said you could add a custom Local/Remote column, but I don't think there is a way of limiting it to Podcatcher playlists (perhaps there is in Columns UI?). I personally have a selection properties UI element in my setup and can see if the Podcast Offline URL property has a value. Not something with an elegant solution yet though, as the API doesn't give components access to the playlist appearance.
Post by: thecircusfreak on 2010-03-01 16:22:11
"I don't think there is a way of limiting it to Podcatcher playlists (perhaps there is in Columns UI?)"
Yes there is a limiting option in CUI.
In Default UI,  q-stankovic you  could just append a (N) to the title  of the few tracks that are a network location, a background change, or sth like that. All satisfactory solutions IMO.
Post by: bubi jackson on 2010-03-01 19:02:32
I think that was the point. Someone had "...;deleted" at the end after I changed the download location.
Thank you for the hint.
Another thing. I only allow 3 files downloading at once. Sometimes fb2k get freezed and I have to kill the process.
Just now I have the problem that the 5th download is still shown as queued and foobar got freezed.
Edit: And the fresh downloaded podcasts aren't shown again after restart.
Post by: nausea on 2010-03-01 20:29:39
That's a bug and needs fixing. Do you have a reliable way of reproducing it? Does it happen just as a track finishes downloading, or during the download at some point?
Did it happen with older versions?
Post by: bubi jackson on 2010-03-01 21:27:37
It happens during a download at some point - sometimes it's working sometimes not.
With this cast http://download.br-online.de/podcast/radiofeature/cast.xml (http://download.br-online.de/podcast/radiofeature/cast.xml) foobar freezes at every download.
About the older versions, I don't really know cause I've started downloading just now.
Thx for your time.
Post by: nausea on 2010-03-02 09:26:54
Haven't managed to reproduce.
A few more questions:
Does it happen if the Download Manager dialog is closed (including not embedded as an element in the UI)?
Do you see the dialog asking to overwrite already downloaded files? It's modal and could perhaps be appearing off-screen for some reason.
Post by: bubi jackson on 2010-03-02 16:07:02
fb2k 1.0.1. beta 2 - podcatcher 0.1.6c(beta) , XP SP3
First I thought it only happens if the Podcatcher Donwload Manager is open (not embedded) but then it happend also if it is closed - regardless of overwriting already downloaded files or not.
Sorry nausea, that I can't give you more hints, but now I think it's a problem of my configuration but I don't know why.
Post by: q-stankovic on 2010-03-02 20:32:58
@nausea & thecircusfreak
Thanks! I think i will create a general useful column: if it is a stream then nothing is shown - if it is a local file a special sign will be shown. In latter case i will use custom colors which shows if a local file is in library or not. That column might be helpful in other contextes too.
Post by: ctkatz on 2010-03-04 00:58:58
please forgive the extremely n00bish question, but can someone explain to me how to use the re-tag feature, what it does exactly (i know it re-tags, but does it take the title, artist, and album title of teh and put it in the id3 fields) , and if re-tagging these podcasts will force them in the podcast section on my idevices with the correct information.
Post by: thecircusfreak on 2010-03-04 03:02:56
A podcast essentially is an xml(description) file which links to a bunch of audio files. Well, it's pretty common that the actual audio files podcast is linking to are untagged files. What this option does is that it exports the tile,date,author etc from the description file and writes them to the corresponding id3 fields.
In case this is not enabled, you end up with a taggless file, which the only thing you know about  is its filename, usually sth like podcast11.mp3
I m not sure what you mean in the end, but podcasts are normal audio files. Your device  probably recognizes them by some tagging, maybe a podcast genre?. This is sth  you would have to do by yourself, podcatcher's retag wont do that.
Btw, nausea, I dont know if this is already happening, have you considered replacing tags only if the corresponded value is blank? Dont know if this is an overkill, I just bring it to your attention.
Post by: ctkatz on 2010-03-04 06:24:10
i am pretty ipod savvy, not foobar savvy.  i previously used winamp to sync to my players.  i stupidly updated the firmware and the person who developed the only plugin for winamp that recognizes the iphone and itouch gave up, so here i am and why i asked the question.  as i said, i figure that the files get tagged, i didn't know what was tagged and what enabled the tagging.  i ask because i have the re-tag feature enabled, and i downloaded and synced a podcast to my player.  addressing the bold part, not only did it not recognize the file as a podcast, it was not tagged at all.  i had enabled the feature in the preferences, but just in case i made sure it was enabled it for this podcast just to be safe.  its set to (use global value [re-tag]).  nothing happened, hence my question.
it was n00bish because i don't use foobar for anything other than to sync my players and am not familiar with all of its features not because i have never used an ipod before.  i hate itunes, it's why i went with winamp and now foobar to do my audio management.
Post by: LoopinFool on 2010-03-12 05:02:56
nausea,
I've got a podcast that seems to mess up foo_podcatcher's date parsing. Here are the relevant lines from the console window:
Podcatcher: Retrieving podcast feed 'http://feeds.feedburner.com:80/TwoDrinkMinimum?format=xml'
Podcatcher: Error in RFC822 time formatting (Sunday, 21 Feb 2010 19:00:00 PST).
Podcatcher: Error in RFC822 time formatting (Sunday, 14 Feb 2010 19:00:00 PST).
Podcatcher: Error in RFC822 time formatting (Sunday, 7 Feb 2010 19:00:00 PST).
Podcatcher: Error in RFC822 time formatting (Sunday, 31 Jan 2010 19:00:00 PST).
Podcatcher: Error in RFC822 time formatting (Sunday, 24 Jan 2010 19:00:00 PST).
Podcatcher: Error in RFC822 time formatting (Sunday, 17 Jan 2010 19:00:00 PST).
Podcatcher: Error in RFC822 time formatting (Thursday, 7 Jan 2010 20:00:00 PST).
Podcatcher: Error in RFC822 time formatting (Friday, 1 Jan 2003 20:00:00 PST).
Since it's from feedburner this may be an issue for more people than just me.
Feature request (I know other people are asking questions along these lines):
[blockquote]I'd like an option to have the Podcatcher playlist for a particular feed only show the "downloaded" items. That way I can easily get the playlist to only show the stuff I haven't listened to yet.
[/blockquote]
There is a workaround, though. I can use foo_podcatcher to manage the downloads and an Autoplaylist based on the path name. I don't think this is ideal (it pollutes my Library with podcasts for one thing), but it does work.
- LoopinFool
Post by: watercolor on 2010-03-29 08:36:00
Can I get Podcast infomation in TF?(e.g. $info(podcast_title),%feed_url%)
if no, please make this function.
Post by: Ben Laserlove on 2010-03-31 02:35:14
Is it possible to make Podcatcher automatically tag downloaded podcast episodes with "Podcast" as genre? This is suppose to make foo_pod recognize the Podcast as an actual Podcast and let me access it through the Podcast view on my iPod touch.
Post by: watercolor on 2010-03-31 04:01:40
if you use iPod Manager, try this TF on genre.
$if($strstr(%path%,YOUR PODCAST DIRECTORY),podcast,%genre%)
perhaps, disappointment this way not make podcast format.
Post by: skyfish on 2010-03-31 12:37:48
Thank you big time for adding re-tag, nausea!
Works fine, yet it would be really great to have an option to format the fields (title, album, artist, genre).
I know your time is limited, but hopefully this is somewhere on your list.
Very grateful for your work, thank you.
Post by: ctkatz on 2010-03-31 18:08:53
here's another n00bish question: where exactly can i set that?
Post by: Hank H. on 2010-03-31 22:08:30
thanks again, great component!
Is there a way to make it ignore caps when grouping channels by author? I.e. group "DKULTUR" and "dkultur" together, or "Radioeins" and "radioeins"?
Also it'd be great to be able to import/export opml in the future... for some reason all my channels vanished today (not sure if it was a crash), to re-import them would have been much easier using opml.
Otherwise it's just perfect...
Post by: ctkatz on 2010-04-03 04:24:51
you say there is an option to have all downloaded podcasts in a playlist.  how do you produce that playlist in the playlist tab lists?  the reason i ask is because there are some podcasts of radio shows that when downloaded are listed out of order in the podcast playlist.  i want to manually edit them in the correct order as you can't do that after the fact on the idevice.
Post by: watercolor on 2010-04-03 04:46:33
Preference->Tools->iPod Manager->Database->Metadata
of course, this way is not perfect. Podcast's format is not general mp3 files.
Post by: nausea on 2010-04-03 10:56:10
I've been working on what will become version 0.1.7.
The main changes so far are enabling the adaptive update schedule feature I'd mentioned in an earlier post, the ability to filter/search in the Podcast Manager dialog, and the option to tag all downloads with the "Podcast" genre.
The adaptive update feature still needs some tweaks, but the release should be within a few weeks.
Edit: The new version will also have a change to how the config is saved. It now writes to a new file (with a different name) and renames the old config file before renaming the new file to the correct config's name. Finally, and only if all the above worked, it deletes the renamed old config.
I've never had a problem with my config, but the other day I noticed that the foo_podcatcher config for my development foobar2000 install was corrupted and wasn't loading. Opening the file in a text editor revealed it was half written. I think what had happened was the computer restarted to install updates and the foobar2000 running the debug build of foo_podcatcher (which runs more slowly) was probably killed by Windows before closing cleanly. Perhaps this is what happened to Hank H.'s install?
The change should mean that if the new config is corrupted for some reason, the old one will still be there, and can either simply be opened by foobar2000, or manually renamed by the user as a last resort. Version 0.2.0 will use SQLite in the back-end to (hopefully!) avoid problems like this.
Post by: gowasabi on 2010-04-03 11:06:37
Thanks Nausea for your indispensable component, i would to ask you if possible to grab tracklist information from downloaded podcasts.
Post by: ctkatz on 2010-04-03 17:50:53
one feature request, can you place in one of the drop down menus, say included with the group of commands with update podcast and subscribe to podcast, a create podcast playlist that lists all downloaded podcasts from, say downloaded a week (or whatever date you set) ago?
Post by: Dereks on 2010-04-10 19:11:58
First of all thanks for the wonderful plugin. Now I basically am able to cut the cord with the iTunes.
but there is only one more request. is it possible to make the plugin able to recognize video podcasts. Of course foobar is not a videoplayer, but it's able to read mp4 files and I simply send them to my iPod with foo_dop plugin. if podcatcher was friendly with them too that would have been perfect!
Post by: mmcc73 on 2010-04-15 01:42:00
I have a couple very basic questions about podcatcher. For what its worth, I'm using Columns UI.
I can't seem to get the podcatcher playlist to sort by date descending. Clicking on the column header doesn't do anything. Other playlists seem to be able to sort properly. Am I doing something wrong?
Also, how can I make a podcast go away? For example, the radiolab podcast has entries back for several years. I'd like to remove ones I've already listened to or don't plan to listen to. If I "remove podcast", they seem to come back the next time the podcast is updated.
Some visual indicator of the download status in the playlist would be great.
Post by: pruuat on 2010-04-15 03:37:12
Can anyone tell me where to download foo_podcatcher? I haven't been able to get the links on the home page (http://www.unkempt.co.uk/fb2k/foo_podcatcher.html) to work. Would like to get both versions 0.6.1d and old_school 0.1.2 for foobar2000 v0.9.6.9.
Thanks for any help.
Post by: nausea on 2010-04-15 11:26:18
Are you using Internet Explorer 6? I've known for a while that it doesn't like the way the files are served, but no one ever complained so I left it. I've just done some Googling and fixed it though, so try again.
Post by: nausea on 2010-04-18 04:52:12
Released v0.1.7. Check updated first post for details.
Post by: icedtea on 2010-04-18 11:24:12
thanks for 0.17 any chance we could see a CUI version anytime soon?
Post by: Sebert on 2010-04-18 19:41:12
First of all thank you a lot for the update.
One question: I do not get the purpose of the "archive" feature. You can move podcasts you do not want in there, but as soon as you delete it from there it gets downloaded again?
And are there any news concerning the podcatcher memorising what feed items you've already downloaded but deleted?
I have 10 GB podcasts on my HD and I cannot delete them because unless they are really old (= aren't in the feed anymore), they just get downloaded again.
The archive feature seems to be a workaround for that, but this way my Archive Playlist will become huge within a short time, if every feed item I do not want has to be moved in there.
Post by: icedtea on 2010-04-19 04:27:45
A couple of bugs
* Show only downloaded does not work
* Recently downloaded podcasts shows multiple entries for some podcasts
* Podcatcher used to show feeds like Podcatcher: Feed Name but now no matter what feed I select the only feed is Podcatcher
Post by: Sebert on 2010-04-19 10:47:09
One more thing:
Most of the podcatcher commands cannot be assigned to a hotkey. The only action offered by podcatcher in the Hotkey config is "Download Podcast" !
I seriously hope we do not frustrate you with our constant critique
Post by: nausea on 2010-04-19 13:57:04
Just released v0.1.7.1 with a few fixes: http://www.unkempt.co.uk/fb2k/foo_podcatcher.html (http://www.unkempt.co.uk/fb2k/foo_podcatcher.html)
Sebert: The archive is indeed intended as a workaround for deleted podcasts being re-added as soon as you update. The Archive playlist essentially provides a way to see a list of the removed podcasts, so that the archive action can be undone. An archived podcast should not appear in any other playlist, so if it does let me know. Archived podcasts in 0.1.7.1 are no longer automatically downloaded.
icedtea: The show only downloaded preference only affects the playlists created by right clicking in the Feed Manager and selecting Create Playlist (these are the Podcatcher: Feed Name playlists you remember). The main playlist includes all non-archived podcasts. I haven't fixed the "Recently downloaded podcasts shows multiple entries for some podcasts" bug yet though. Thanks for reporting it and expect a fix soon.
Post by: mmcc73 on 2010-04-19 14:52:40
I just downloaded 0.1.7.1. It looks like a big improvement - thanks!
My suggestions:
- Provide a way to delete all downloaded podcasts associated with archived podcasts
- Sorting by date ascending/descending doesn't seem to work
- Give a way to build columns containing the stuff in the podcast properties (stuff that is in the Properties tab of the properties dialog, not the Metadata tab). I'm using Coumns UI by the way.
Post by: mjed on 2010-04-19 15:14:03
I downloaded 0.1.7.1 hoping it would fix the crash on startup bug, but foobar still crashes immediately. I'm on Windows 7 x64 with foobar 1.0.2, if that helps.
Post by: nausea on 2010-04-19 22:38:38
Hmm... if you could submit a crash report that would be very useful. I'll try and get a new version out tonight.
Post by: mjed on 2010-04-20 01:27:52
How do I do this?
Post by: nausea on 2010-04-20 10:41:09
Released v0.1.7.2. Hopefully this time I've got it right...
About submitting crash reports: When foobar2000 crashes, normally a dialog pops up with options to view and submit a crash report and minidump file. I can then download these and use them to easily determine the exact place in the code where the crash occurred. Very useful.
Post by: icedtea on 2010-04-20 10:56:23
Thanks nausea my podcast setup is almost perfect. The recently downloaded podcasts playlist + archiving works wonders. I was wondering if there is any way to access the "Podcast Downloaded" information so that I can put it in a column something like %podcast_downloaded%
Thanks again now I don't even need a panel as all newly downloaded podcasts come to a playlist
Post by: mjed on 2010-04-20 17:01:43
Podcatcher still hangs foobar.
I do not get this option. Foobar becomes unresponsive immediately upon startup until I end the task.
Post by: nausea on 2010-04-20 22:29:49
This is a different problem to the one I fixed then. Did this happen with previous versions? Or is this the first version of foo_podcatcher you've tried?
Post by: mjed on 2010-04-21 05:21:29
Never happened with any previous version. It's definitely foo_podcatcher- when I remove it, everything works fine.
Post by: Androidmonk on 2010-04-21 07:44:51
My foobar hangs too.
I find that after installation, foobar is fine until I subscribe to the first podcast. Then it hangs/crashes, especially when I try the edit/feed manager.
It's definitely podcatcher that crashes foobar since all other components are default, and everything's fine again after I remove the dll.
I am running latest foobar (v1.0.2.1). Oh, and the auto troubleshooter still says "No known problematic components found."
Post by: icedtea on 2010-04-21 07:47:50
nausea the podcatcher playlists aren't sortable is this intended?
Post by: dafnis on 2010-04-21 10:14:55
Hi there,
Both 0.1.7.1 and 0.1.7.2 crash my fb2k on startup; 0.1.6d beta works fine with fb2k 1.0.2.1.
I'm not getting any crash report dialog either.
If you need more detailed feedback, please let me know how to better test it.
p.s. this is one of my favourite components, thank you for your work
daf
Post by: nausea on 2010-04-21 10:55:27
I've put v0.1.6d back up at http://www.unkempt.co.uk/fb2k/foo_podcatcher.html (http://www.unkempt.co.uk/fb2k/foo_podcatcher.html) while this bug is worked out.
Androidmonk: When you say "especially when I try the edit/feed manager", do you mean it doesn't hang when the manager dialog is not open? That would be very useful information.
mjed & dafnis: The fact that it didn't happen with older versions is helpful, and should narrow it down. Thanks.
icedtea: The lack of sorting is by design, but could change in future versions as a bunch of people seem to want to sort. The playlists are currently all sorted by publish date, except the Recently Downloaded Podcasts playlist, which is sorted by date downloaded.
Post by: dafnis on 2010-04-21 11:09:25
And now a feature request:
Due to a couple OS crashes my podcatcher forgot what podcasts were downloaded during the session, and so on system restart kept asking if it should overwrite existing files. If foobar has been running for several days in a row, it means a lot of files.
So I wonder if it would make sense to perform the new "safe" config file updating at predefined intervals, or even in a paranoid mode every time a podcast is downloaded successfully.
thank you
Post by: nausea on 2010-04-22 11:37:46
Have released 0.1.7.3, with a fix for a hang when the update period is set to daily. http://www.unkempt.co.uk/fb2k/foo_podcatcher.html (http://www.unkempt.co.uk/fb2k/foo_podcatcher.html)
Lots of thanks to Androidmonk and mjed for their help with this, and extra props to dafnis for solving it in the end. Awesome!
dafnis: version 0.2 will use a proper database backend, giving the behaviour you describe.
Post by: dafnis on 2010-04-22 12:04:10
0.1.7.3 working fine here, thanks a lot.
p.s. looking forward to 0.2
Post by: mjed on 2010-04-22 14:01:57
This works great, thanks!
Post by: icedtea on 2010-04-23 07:56:21
nausea wouldn't it make sense to save the feed image/folder.jpg to the podcast folder so that the album art panel in dui/cui can show the image? Most files don't have the image embedded
Post by: nausea on 2010-04-24 02:15:08
Version 0.1.7.4 released. It has a fix for the context-menu keyboard shortcuts bug. You will have to re-set the download shortcut with this release.
Yes it would. It would be a slight change though to how the image downloads work, as they are currently only downloaded as needed by the Feed Manager dialog. I'll look at implementing this for a future release. It would of course not enable album art for not downloaded podcasts.
All those looking for auto-backup, foo_jesus appears to save the foo_podcatcher settings.
Post by: skyfish on 2010-04-24 13:08:38
The ability to set genre is great, nausea, but some hardware players (Sansa etc) require «Podcasts» instead of «Podcast» to function properly.
Would it be hard to put a text field there instead of checkbox? It would also help non-english users.
I also really hope foo_podcatcher would have the Title, Artist, Album & Genre text fields one day.
Retag is useful, but some casters have a very messy tags
Is it on your list, if I may ask?
Post by: --pv-- on 2010-04-24 20:59:36
Hello,
I am also amazed. This component is great.
2 little comments:
perhaps it requires handling of more encoding. For me the following podcast fails and I think it's because of the iso-8859-2 content encoding: http://www.lumen.sk/podcast/rozhlasova_hra.php (http://www.lumen.sk/podcast/rozhlasova_hra.php)
There is an accessibility problem related to sliders and static texts in the main preference page and also custom feed properties dialog.
Static texts which give a textual representation to nearby sliders should be placed after the slider in the azorder too.
I don't think there is some spec for this but for  me as a blind user it would be nice if the static text displaying help text would be placed first in the azorder eventhough they are usually displayed at the bottom.
Post by: Sebert on 2010-04-26 12:02:00
Again a question concerning the Genre - podcast tag.
Foobar properties only show the genre "Podcast" if I open the file at least once. If I just select the feed item and select properties the tag is still empty, if I open it, the tag is suddenly there. Why is this?
And thank you for fixing the keyboard sortcut thing !
Post by: icedtea on 2010-04-30 15:47:49
Nausea can we have a "All Downloaded Podcasts" to complement "Recently Downloaded Podcasts"?
Post by: ctkatz on 2010-04-30 16:36:48
another request if you may:
would it be possible to include the normal foobar right-click menu functions in the download folder as well as those commands you have there already?
Post by: TheNickromancer on 2010-05-05 06:28:51
Topping that, I'd really like a "Newest Downloaded Podcasts" that shows only the most recently released downloaded podcast for each feed, mainly for easy syncing to my iPod. The current "Recently Downloaded Podcasts" works well enough for now, but I have to avoid downloading any old podcasts if I want to maintain that.
Great work so far, nausea - we really appreciate your efforts.
Post by: luci on 2010-05-25 16:08:12
Thanks for your work, you are almost there.
The Archive feature is confusing: I thought an archived podcast would go somewhere else (a different folder?) for long-term storage, but apparently the archived episodes are not downloaded at all. If you want to say "Do not download", why don't you say so?
I don't see how the takeup rate would be decent without an OPML import function.
Post by: luci on 2010-05-25 18:23:14
For some reason it hangs and or craches when I add the following feed:
http://stke.sciencemag.org/rss/podcast.xml (http://stke.sciencemag.org/rss/podcast.xml)
Post by: ingver on 2010-05-25 22:26:30
I think I mentioned this before (like half a year ago). My podcast items still show "1601-01-01 03:00:00" as date.
all of them (all my subscriptions are from last.fm, so maybe that's the culprit, others seem to work)
I would really appreciate help since the weird date messes up my grouping , maybe u could do an option to use "podcast downloaded" in "DATE" field of the downloaded podcasts? (not sure what would happen to the undownloaded then )
Oh, and is it possible to add podcatcher podcast manager and download manager permanently to the layout? as panels (columns, whatever). I'm talking about columns UI.
otherwise awesome add-on
Post by: nausea on 2010-05-25 22:49:27
luci: That feed works for me. Are you using the most recent version (v0.1.7.4) of foo_podcatcher? If so, can you give me an overview of your settings?
ingver: Do you have an example feed from Last.fm I could look at?
Post by: ph1 on 2010-06-05 02:11:51
I successfully was using fb2000 v1.0.2 with 0.1.6 of podcatcher, and thought I'd update to fb2000 v1.0.3 and v 0.1.7 simultaneously.  First, forgive the noobie question, but is there a preferred sequence/method for updating to more recent versions (and in the process preserving the subscribed feeds)?  Does update methodology differ if updating using portable vs installed fb2000?
Unfortunately when I now try to subscribe to a known feed (including several listed above as "working") nothing happens as it did/does in previous versions.  I don't get a response from podcatcher asking if I want to add the subscription, nothing...just sits there after I type in the feed.  It must be something basic, but I don't know what settings/etc I've screwed up.
I have tried this with both portable and installed versions of fb2000.
Finally, is there a convenient way to determine what version of podcaster is currently being used?
Again, apologies for basic questions.  REALLY love the plugin!!!
Post by: LoopinFool on 2010-06-05 02:39:49
I can answer the version question.
Go to preferences in foobar2000 (File->Preferences menu or Ctrl+P). Click on "Components" in the upper left corner. All of your installed components are listed there with their version strings.
- LoopinFool
Post by: nausea on 2010-06-05 14:34:12
...is there a preferred sequence/method for updating to more recent versions (and in the process preserving the subscribed feeds)?  Does update methodology differ if updating using portable vs installed fb2000?
Your subscribed feeds should be maintained. There's no real change between 0.1.6x and 0.1.7.x in that regard. The foo_podcatcher_config.xml file is stored in the foobar2000 profile directory. You can find out where that is on the General page of the preferences.
Are the Podcatcher entries in the foobar2000 View menu?
Post by: ph1 on 2010-06-06 03:37:11
Thanks for your help on trying to solve my problem stated above.  More details, now that I understand things a bit better.
I have two portable foobar2000 I use, in two separate directories.  One v1.0.2.1, the other v1.0.3.
I use podcatcher 0.1.7.4 and it seems to allow new subscriptions (and download existing subscriptions) fine with fb2000 v1.0.2.1.  However, when I try podcatcher 0.1.7.4 with fb2000 v1.0.3, using a copy of the config.xml file I used when testing with fb2000 v1.0.2.1, while the "subscribe to podcast" menu item is available and can be chosen, when a new feed URL is entered, no response occurs (where there should be "do you want to subscribe to this feed").  Furthermore, it appears that while existing feeds in the config.xml file are recognized, updates fail on them.
Any suggestions as to why podcatcher 0.1.7.4 doesn't function the same with my fb2000 v1.0.3 portable (and presumably installed) version as it does with my fb2000 v1.0.2.1 portable version would be appreciated!  I guess my other plugins I use in my two versions of fb2000 I've tried this on aren't exactly identical, but I shouldn't think having not yet installed other plugins when I upgraded to fb2000 v1.0.3 should cause this issue.
Thanks for ideas!
Post by: nausea on 2010-06-06 03:46:36
...when a new feed URL is entered, no response occurs (where there should be "do you want to subscribe to this feed").  Furthermore, it appears that while existing feeds in the config.xml file are recognized, updates fail on them.
Do you see any relevant messages in the foobar2000 console (View/Console)?
My first guess is that it's failing to connect to the internet. The current behaviour is for feed updates to fail silently, even if it's a new feed. (This should be changed.)
Post by: ph1 on 2010-06-06 04:53:24
Yeah, that makes sense, and it IS the problem.  Console indicates that failing to connect to the internet.  What I don't understand is why I can fire up FB2000 v 1.0.3 and not be able to connect and then 5 seconds later fire up FB2000 v 1.0.2.1 and have it connect to the internet fine.  But that must be my problem, either some setting I inadvertently made in the v 1.0.3 or my firewall settings (though I disabled my firewall).
Post by: nausea on 2010-06-06 05:22:49
Proxy settings perhaps?
Post by: m_foo on 2010-06-07 17:35:36
Hi there, I just tried Podcatcher and I like what I see, but I stumbled on a little problem (for the record: I use foobar2000 1.0.3 (regular install) and Podcatcher 1.7.4 on Windows Vista 32-bit).
On this (http://www.idesherpa.se/podcast) site, in Firefox's podcast subscription interface, all episodes of the podcast are named Download.mp3 and when I try to download an episode after the first one Podcatcher asks me if I want to overwrite Download.mp3. Here, there is room for improvement because if I click "yes" the episode is overwritten (not desirable) but if I click "no" it doesn't download the episode. There should be an option to rename files with identical filenames (perhaps in preferences or podcast-specific preferences). When I had downloaded several episodes (overwriting the existing file) the podcast listed several episodes with the same duration and with the same title as the first episode, but when I deleted the podcast and added it again and downloaded another episode first the duration changed to the duration of that episode but the title was still the same as the first one. But here comes the funny part; when I download an episode from Firefox (directly to disc, bypassing Podcatcher) it renames the file to [name of episode].mp3 and when I open the file in foobar2000 the title says [name of episode]. I don't know if this is some evil voodoo that the site uses but if Firefox can catch the new filename then it should be possible for Podcatcher.
By the way, thanks for all your hard work and despite my issues, this plugin great.
Post by: Sebert on 2010-07-13 01:00:19
@nausea
Any news on this fabulous component?
Post by: nausea on 2010-07-13 10:59:57
m_foo:
I had his problem too at one point. The download path in the location accepts title formatting, which defaults to something like S:\Media\Podcasts\%album%\%filename_ext%, but you can change it to something like to solve your problem:
S:\Media\Podcasts\%album%\$date(%date%)\%filename_ext%
or S:\Media\Podcasts\%album%\%title%.$ext(%filename_ext%)
You can do this either globally in the preferences, or on a per-feed basis by double clicking the feed in the Feed Manager, and then double clicking one of the listed properties.
Sebert: I've been working on v0.2.0 again recently. I've basically done the database integration, and am slowly bringing the feature list to parity with v0.1.7.4. When that's done I might release it to get it more widely tested before adding new features. No ETA yet though.
Post by: m_foo on 2010-08-04 08:19:12
nausea:
thanks for the tip!
Post by: kopf on 2010-08-11 19:34:52
I have a problem - if I have "Download podcasts from All Time" selected, and quit foobar2000 during the first, full download of the podcast's history, it doesn't pick up where it left off. In fact, it refuses to download anything when I click "Update All".
How do I get the plugin to check what it's downloaded and download what's not there?
Post by: Sebert on 2010-08-16 14:53:12
Another feature request: A possibility to backup your subscribed feeds (just the info, not the files), I am thinking of something like a OPML export/import or something like that !
Reason: Foobar2000 just crashed and now all the feeds are gone, I have to look for the feed url for each of them and add them manually !
Post by: Synthetic Soul on 2010-08-31 10:48:33
Apologies if I've missed this in the thread, but I couldn't find an answer.
Is there any reason why some podcast episodes are downloaded and others are played from their remote location?  I'm pretty anal, and I like to have an archive of the shows I listen to.
NB: Episodes in question have the download and updated date of "1601-01-01 01:00:00".
Many thanks for this component, it's very useful to me.
Edit: Bah, just answered my own dumb question!  I assume this was because I had the automatic time range as "1 day".  This machine is my work machine, so if a podcast was released over the weekend it was deemed too old to download I assume.  I have updated now to "All time".  That said, it was showing up as a new podcast, but just not being downloaded. I'm still a little confused at the conflict between these two facts... and on checking again I guess I would be directed to the "Include only downloaded items in Podcatcher playlist" checkbox.  If I had this checked (which I didn't) presumably there would be better parity between the two.
Post by: thecircusfreak on 2010-09-02 09:49:10
...and of  course you can manually download any past podcasts.
Also a visual indicator showing(using a script)  if  a podcast is in a local location or not might help you reducing any  confusions.
Post by: Synthetic Soul on 2010-09-02 10:03:23
A playlist indicator is a very nice idea, and maybe a combination of both your suggestions would be a nice solution.
As it is I'd rather be lazy and use "All time", so I don't have to change my column script specifically for podcatcher, or do any more clicking than I have to.  I know, I'm lazy.
Post by: phoenixwpf on 2010-09-07 08:02:11
hi,nausea! thank you for such it's an excellent plugin!
but i met some problem when i subscribe to podcasts which need username and password, in itunes it will popup a window for you to type your username and password, i didn't find such a thing in the plugin.
it says: Unable to open item for playback (Authorization Required (401))
hope you can add the function in the new version!
thank you!
Post by: Wacky on 2010-09-09 12:04:17
thank you!
Try this, it allowed me to use foo_podcatcher with subscription sites. Enter the podcast url in this format:
http://username:password@rss.rest_of_url.whatever (http://username:password@rss.rest_of_url.whatever).
Post by: keats on 2010-09-17 10:59:06
Is there any way to access the properties added by podcatcher (like Podcast Status) through queries? Something like %podcatcher_podcast_status% ? I'm especially interested in adding a column to my playlist view showing whether or not an episode has been played and/or downloaded. A list of all possible variables would be even nicer...
(Question has been asked before by others, but wasn't answered yet.)
Post by: Synthetic Soul on 2010-10-25 17:34:53
I was going to ask this same question.  I'm just trying to get myself together* with podcasts on my iPod, and I use foo_podcatcher and foo_dop.  The plan is not to listen to them in foobar, but use foobar to transfer them to my iPod.  If the genre tag is only set on play this won't help me.
* On a vaguely related note, I recenly discovered smart playlists (http://www.apple.com/itunes/podcasts/) which makes listening to multiple podcasts much easier (useful when running, and unable to mess about too much). Only relevant in the fact that my playlist looks for the "Podcasts" genre value.
Post by: wiak on 2010-11-07 04:44:25
hey. nice addon for foobar2000, i miss one thing, option to sort in foobar2000, a standard playlist can sort after date, bitrate, codec, album, artist etc but not  foo_podcatcher
Post by: FroL! on 2010-11-16 18:20:27
First of all, thanks for that awesome component!
Have you any plans to make synchronization with google reader. It will be cool... I guess it is no so hard to implement.
Post by: thecircusfreak on 2010-11-17 19:41:43
@wiak,  you could create an autoplaylist  to the folder podcatcher saves its podcasts.
Post by: Tom_W on 2010-11-18 12:48:10
i miss one thing, option to sort...
I agree. I know this has been raised before and Nausea said it might be implemented in the future.  Just adding my support for this request.
Also, does the Podcatcher playlist work with Columns UI grouping scripts? I have some unexpected grouping behaviour, but I can't see anything in the metadata to explain it. Is this connected with the sorting?
- Good workaround, this solved my grouping issues as well.
It would still be great if this behaviour was standard in the Podcatcher playlist though.
Tom
Post by: yam655 on 2010-11-23 20:09:40
Files and directories are being created without an Owner on Fat32 volumes in Windows 7.
Not all files and directories have this problem, but some do.
On a Windows 7 system set the Podcast directory to sit on a FAT32 volume.
Subscribe to some podcasts.
Download some shows.
This is easiest to see if you have it configured to show the File Size in the Playlist columns.
Notice that not all shows show a downloaded size -- even though the Podcast Status shows that they are downloaded (and the context menu switches to "redownload".)
In a CMD window, you can use "DIR /Q" to list the owner. In my case, I see "//Everyone" and "..." the files/directories. The files/directories that show an owner of "..." with "DIR /Q" show up as having no owner when I use the "Owner" column in the Windows Explorer. These files/directories can not be deleted.
Better yet, since this only happens on Fat32 volumes -- and Fat32 volumes lack the "Security" tab in the File Properties -- there is no easy way to correct the problem. Once I realized the problem I copied what I could to another volume and reformatted as NTFS.
Post by: yam655 on 2010-11-29 18:55:35
It looks like I was wrong.
It isn't limited to just FAT32 volumes. Also, I'm not sure if it is a Foobar2000 bug or a Windows bug.
The problem happens when you have filename or directory that ends in an ellipsis.
It appears that Windows Explorer -- and the CMD echo > FILE / mkdir will not let you create a filename/directory ending in an ellipsis.
I had logic in place to shorten directory names (and I may have used similar logic for the filenames earlier, but I am not sure) which resulted in an ellipsis if the directory name was shortened.
All of my directories with ellipsis in them show as not having an Owner in Windows Explorer.
Post by: yao on 2010-12-08 16:51:30
Hello
Thanks for the great plugin.
Just one question.
Is it possible to access the "Podcast description" tag that is visible in metadata and make it a column in foobar? Or retag it to another standard tag in the file? The automatic retaging uses only "Podcast Title" but not the "Podcast Description" where in my case is more important information than in "Podcast Title" tag.
Post by: perler on 2010-12-13 18:41:06
would you be interested in working with doggcatcher (android podcast fetcher/player):
http://www.doggcatcher.com/node/1314 (http://www.doggcatcher.com/node/1314)
regards,
PAT
Post by: Sebert on 2011-01-05 14:38:43
Any news on this?
Post by: Speech on 2011-01-10 18:46:58
I noticed that if you compare byte by byte the files downloaded by Podcatcher and the original file downloaded from the podcast stream with any other download tool, they are different.  Why does Podcatcher change its content (most probably the tags, but it looks like not only them).
Post by: nausea on 2011-01-11 12:28:35
There's a bug in 0.2.0 where podcasts are always retagged on download. I expect this is what you are seeing.
I've posted 0.2.2 with a fix for this. Thanks for letting me know.
Post by: Speech on 2011-01-12 14:02:43
Thanks!  Version 0.2.2 fixed this, indeed.
However, as an avid podcast listener (70 different podcasts at the moment), I encountered these problems:
1. I need to download all my podcasts in one Windows folder, then put every file from one podcast feed into a subfolder (alternatively, put all the podcast files into one folder, but rename them so that you can know what they contain).
However, every podcast producer has their own naming rules and you have to change the name of the folder in advance, otherwise it would be a mess.
When I changed all the download folders Podcatcher assigned to every podcast (it took me a while!), I noticed that Podcatcher rather created files with the name of the intended folders, instead of folders where to put every file (did I do something wrong, I don’t know, because there is no user guide for Podcatcher!).
Moreover, these files didn’t have the .mp3 extension, some had a partial name (it seems that the ‘ sign confused Podcatcher) and some files became almost impossible to delete from Windows (a file containing a space at the end, because Podcatcher created a partial name).  In other words, it was a bigger mess.
This means I still have to use FeedDemon instead of Podcatcher for now.
2. Another problem: it’s impossible to create custom playlists that fit my needs.
I listen to all these podcasts, but I have a selection to listen on foobar, another to listen on my smartphone.
So, I managed to create a selection of podcast feeds that are meant to be listened on foobar.
However, I have no control over this list: I would like to only see there new and downloaded podcasts.  If I listen to some, I would probably automatically delete them (except in some cases if they are really good and want to keep them) and I don’t want to see them anymore.  The problem is, Podcatcher would still put them into the list, so I’m never sure where I stopped and what podcast I have listened to or not.
I hope my descriptions are clear enough.
If these two problems were solved, Podcatcher would start to be usable, in my opinion.
As additional features, I would like to see:
1. The Podcatcher playlists not locked, so that I could manually add some old podcast files from my hard disk to listen immediately instead of creating a new playlist.
2. If you don’t assign a download folder to podcast files, you can still listen to them, but where are they stored?  Because I hope they don’t go to some obscure folder and accumulate on my hard disk without me being able to get rid of them.
3. Believe or not, Podcatcher is not easy to use for new users, even if you are a long time foobar user.  A user guide for Podcatcher would be absolutely necessary, in my opinion.
4. Let me add, as another user said, that accessing specific podcast tags like %podcast_downloaded% would be very useful.
5. Also, the new feature of importing OPML files, unfortunately is incompatibile with an OPML exported from FeedDemon.
Let me know what you think about this.
Post by: q-stankovic on 2011-01-14 17:53:07
Thanks for the updates, nausea!
I described a behaviour here (http://www.hydrogenaudio.org/forums/index.php?showtopic=69053&view=findpost&p=675426) that still seems mysterious to me: i can't explain what and why it is happening. Hope, you can say some words to it.
I have one small feature request: i would like to have an option so that a doubleclick instead of a singleclick sends the content to the podcatcher playlist. The singleclick behaviour causes the changing of podcatcher playlist in situations i don't want the changing: f.e. using context menu of other podcasts.
Post by: nausea on 2011-01-15 02:24:36
q-stankovic:
Sometimes feeds have different infos for the casts than the files themselves, and no length. When foo_podcatcher creates the playlists it uses the info from the feeds, but when you play a file foobar2000 gets the tags from the file. You can use the retag downloads option to help with this.
Speech:
Thanks for the detailed comments.
The download path needs to have a filename included, for example: file://S:\Media\Podcasts\%album%\%filename_ext%
(I now realise that the feed preferences dialog says 'Location' rather than 'Path' - in an earlier version it was in fact a directory.)
I'm concerned about files with illegal characters being created, and I'll look at this this weekend. I replace illegal characters, but perhaps there are additional rules I need to account for.
I'll take your playlist feature requests into account when making changes. I like the idea of automatically archiving listened podcasts, or not listing them based on the playcount, but I hesitate about deleting files because of the "except in some cases if they are really good and want to keep them" case. There is already a preference to only show downloaded and new podcasts in playlists.
I haven't been able to find any example FeedDemon OPML files online, so could you send me one in a personal message on the forum here. A single outline element should be enough.
Also, foobar2000 streams not downloaded podcast files over http. So don't worry, they are not filling up you hard-disk somewhere.
Post by: hm2k on 2011-01-15 14:16:03
Great concept, only problem is that it didn't seem to work with the feed I gave it:
http://svdnews.typepad.com/sander-van-door...ts-in-sa-1.html (http://svdnews.typepad.com/sander-van-doorn-news/2011/01/check-out-the-latest-tracklisting-from-sanders-hit-radio-show-and-podcast-identity-and-get-those-opinions-and-thoughts-in-sa-1.html)
- via iTunes: http://bit.ly/cCGY10 (http://bit.ly/cCGY10)
- via RSS: http://bit.ly/bUBeTs (http://bit.ly/bUBeTs)
I used the RSS version, but nothing happened.
Is it just me or is this some kind of bug/problem?
Ta.
Post by: q-stankovic on 2011-01-15 17:28:54
I am not sure how that can help me: generally i don't download the files of a podcast - just when i need them on other devices. would it be a great loss of performance to load the info from files on creating the podcatcher playlist?
Post by: zilog8 on 2011-01-28 06:08:17
I'm sorry if this has been covered before, but I did a search on this thread for "pause" and "resume" and didn't find anything.
So, long story short, I have a very unstable internet connection and would really appreciate being able to resume downloads. Pausing would also be a nice touch.
Also, there's a slight bug: Sometimes, when a download goes awry and then I quit foobar, the foobar2000.exe process remains running until I kill it with Task Manager.
Post by: Hank H. on 2011-02-01 12:38:57
opml-export doesn't work here (version 0.2.3/foobar 1.1.2). When I choose "export", type in a filename and click "save", the dialogue closes but nothing happens - there is no opml-file.
One more minor request: While podcatcher is downloading, the download-dialogue gets in the way/covers the podcatcher-playlist, especially when there are several different downloads going on. It would be nice to be able to minimize or at least move the download-dialogue.
Thanks for your great work!
Post by: HiRsch on 2011-02-01 12:57:01
hi there,
i just upgraded to the current version of podcatcher. now it keeps asking me if i wanted to subscribe to one of my podcasts. the window just keeps popping up again and again, wether i click "yes" or "no".
any suggestions on how to solve this?
cheers
Post by: Synthetic Soul on 2011-02-01 16:43:40
foo_podcatcher 0.2.3 beta keeps trying to download items which are no longer in the feed, I think.
I created a feed by scraping a website.  Since feeding it to foo_podcatcher I have made various changes, including limiting the number of items.  foo_podcatcher seems to still be trying to download items which are no longer in the feed.
Is there some sort of cache that records what needs downloading which it is still using because the orignal error was seen to be temporary?  Is there any way I can tell it to give up?  The current "Download Range" is not being adhered to.
Seems like it would be good to update the queue using the current feed.  Also, or alternatively, some way to tell it to give up after X tries, if that is indeed my problem.
Post by: anfromme on 2011-02-01 20:51:12
Thanks for this great plugin - very handy indeed.
However, I found some behaviour regarding tagging that IMHO is a bug that needs to be fixed. The behaviour is seen for all podcast feeds I'm subscribed to.
Here's an actual example for a podcast from this feed:
http://www.dradio.de/rss/podcast/sendungen/diereportage/ (http://www.dradio.de/rss/podcast/sendungen/diereportage/)
Say the FEED info for a podcast is this:
Artist: DKULTUR
Title: Der geläuterte Samenspender
Album: dradio-Die Reportage
Date: 2011-01-09
Now, once I start playing the podcast, the info is read from the remote FILE, and it looks like this:
Artist: Wenderoth, Andreas [Note: this will be different each time, depending on who authored the podcast in question]
Album: Deutschlandradio Kultur
Date: 2011
This is also the info that the file contains when I download it directly (if you want to check: http://podcast-mp3.dradio.de/podcast/2011/...05_61ec8bc0.mp3 (http://podcast-mp3.dradio.de/podcast/2011/01/09/drk_20110109_1305_61ec8bc0.mp3) )
This is all fine.
But now I try downloading using foo_podcatcher.
If I choose "re-tag" globally, the FEED info is read and then written to the downloaded file. I guess this is functioning as designed.
If I choose "don't re-tag" for the feed in question, the behaviour is the same, i.e. it looks the "don't re-tag" doesn't actually get applied if I set it for a particular feed.
But that's not what bugs me.
Here's the issue:
If I choose "don't re-tag" globally, the file is downloaded, and the tags are wiped from the downloaded file. So instead of the tags in the file (which are there and which I would actually like to have in the downloaded file), I get a file without any tags whatsoever, which shows up - quite unpleasantly - like this:
Artist: ?
Title: drk_20110109_1305_61ec8bc0
Album: ?
Date: ?
I'm using foo_podcatcher 0.2.3 beta.
Post by: HiRsch on 2011-02-02 07:35:27
my podcatcher keeps buggin me about one feed i have.
every 60 seconds it asks me if i want to subscribe to it. wether i click yes or no doesn't matter.
the console says:
Podcatcher: Finished checking for new podcasts. Checking again in 60s.
it only seems to check this single feed. although the global settings say to check hourly. it then tries to download a file from that feed, creating a *.part file, just to tell me in the console:
Podcatcher: Downloading podcast item 'http://www.astrobio.net:80/video/http://traffic.libsyn.com/arewealone/AWA_11-01-24.mp3' to 'file://D:\-= Downloadz =-\Podcasts\NASA Astrobiology Magazine\AWA_11-01-24.mp3'
Podcatcher: Error downloading 'http://www.astrobio.net:80/video/http://traffic.libsyn.com/arewealone/AWA_11-01-24.mp3' (Length of object is unknown)
Location not parsable: "D:\-= Downloadz =-\Podcasts\NASA Astrobiology Magazine\AWA_11-01-24.mp3.part", reason: Unsupported file format
it worked fine for all other episodes from that particular feed.
using 0.2.3 beta.
cheers
EDIT:
looks like i solved the problem.
deleted the feed, closed everything, deleted the *.part file and restarted foobar.
then added the feed again.
suddenly stopped asking about subscribing to the feed every minute. seems like the file in question is a video. it just tried to download it once, didn't work, and then it stopped triying, and therefore stopped bugging me about it.
strange thing though, but looks like it's ok now ;-)
Title: foo_podcatcher
Post by: nausea on 2011-02-02 09:54:50
Thanks for the reports. Looks like there are still some issues around downloading and retagging. I'll try and take a look this weekend.
HiRsch: do you have the url of the feed that keeps asking you to subscribe? It might help me debugging the issue.
Post by: HiRsch on 2011-02-02 11:45:22
that would be: http://www.astrobio.net:80/podcast.xml (http://www.astrobio.net:80/podcast.xml)
but as i edited in my last post, after deleting the feed, restarting foobar, and adding it again it stopped. i looked into some of the episodes' links though and think the problem might be there, as some of the late episodes show weird "podcast online" urls.
Post by: Synthetic Soul on 2011-02-02 14:05:12
FYI I removed the feed in question in #258 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=69053&view=findpost&p=741876) and re-added it to no avail.
Post by: driesn on 2011-02-02 15:10:58
I have a problem with the context menu of Podcatcher (version 0.2.3), using Foobar 1.1.2.
Under "context menu" in "preferences", Podcatcher has 4 options: download, archive, restore and delete podcast. All of them are enabled.
However, when I right-click on a file in the Podcatcher playlist, the last two options don't appear in the Podcatcher context menu.
Does anybody have any solutions?
Post by: nausea on 2011-02-02 20:33:41
... Podcatcher has 4 options: download, archive, restore and delete podcast. All of them are enabled.
Restore and delete only apply to archived casts. So if you archive a cast, go to the Archive playlist, and right click there you should see delete and restore.
Synthetic Soul: Deleting the casts will stop them trying to download if they aren't in the feed anymore.
Post by: Speech on 2011-02-03 22:22:07
Speech:
Thanks for your answer and for fixing the bugs I mentioned in two consecutive versions.
Also, as you requested, I sent you a FeedDemon OPML file by a private message.
I was able to follow your suggestion, but unfortunately every podcast producer has their naming rules.  If I want my podcast folder to be easy to understand and not to be a mess, I still have to manually set a download folder for each podcast.  Why can't I just change the title of every individual podcast in the Podcatcher Feed Properties, so that it's not necessary to assign a specific download path to every one of them?
Moreover, there are still illegal characters in v. 0.2.3.  As you may have noticed if you imported my OPML file and set a specific folder for podcasts (take the same name as the "outline text" tag from the OPML file, don't just keep the default download folder), podcasts containing ' or ( will transform into incomplete file names with no folder and no extension!  I consider this a serious bug, since it prevents other podcasts from being downloaded into the same file!
Now that I know better Podcatcher, I agree with you that automatically archiving podcasts would be an interesting option for most users.  Also, automatically deleting podcast files (such as the File Operations plugin does) would another interesting option; I would just delete everything by default and, if I want to keep a podcast (I rarely do), I would just restore it from the Windows Recycle Bin.
Another point I want to make is to be able to just download some podcasts, but not include them in an automatically generated playlist like "Recently downloaded".  For instance, I have some podcasts I always listen to on my Nokia smartphone, so I just want Podcatcher to download them, then I will transfer them on my digital MP3 player.  (In an utopia world, I would better like to synchronize foobar/podcatcher and my Nokia, so that I can send any podcast and also keep the "listened" indicator and keep the last position in a partially listened podcast.  But that would be too much to ask.)
One last thing: when I delete a podcast feed from the list, there are still bits about it still left in the foo_podcatcher.dll.db configuration file.  Is this file condemned to keep all the history and always grow?
I hope everything is clear here, because I put together several ideas in one post.  Hopefully they help you to build a better Podcatcher.  Thanks anyway for what you've done already!
Post by: Synthetic Soul on 2011-02-04 12:07:12
That's not my experience.  In fact, to test further I have completely removed the feed now (not re-subscribing as I had unsuccessfully before), and choosing "Update All Podcast Feeds" has still resulted in these download errors!
It's very possible that I'm overlooking something basic, but I just can't see what!
Post by: nausea on 2011-02-05 02:24:52
Synthetic Soul: You will need to delete the casts too. They will be in the Orphaned Podcasts 'feed' playlist (but will need to archived before being deleted). I've changed the behaviour in the next version to not try to download archived or orphaned casts, and to allow orphaned casts to be directly deleted.
Speech: Thanks for the OPML file. I haven't been able to reproduce the illegal characted bug though. Could you let me know the exact download path and feed/cast combo that produces it? Thanks.
Post by: Speech on 2011-02-06 21:59:29
Well, it's very simple:
1. Take whatever podcast you subscribed to.
2. In the Podcatcher Feed Properties window for this podcast, assign a download path to it (i.e. "D:\My documents\Downloads\Podcasts\This isn't my best podcast (but I still like it)\%filename_ext%" ) (I purposely put the 2 illegal characters I discovered in the folder name.)
3. Watch where your files will be stored (i.e. "D:\My documents\Downloads\Podcasts\This isn" - the latter being a file with no extension, not a folder).
Post by: Synthetic Soul on 2011-02-08 14:58:17
Thanks nausea.  Have now deleted podcasts.  Will report back if I still get error, but presume this will sort it.
Really handy extension BTW; many thanks.
Post by: nausea on 2011-02-11 11:31:22
I've just put v0.2.4 up at http://www.unkempt.co.uk/fb2k/foo_podcatcher.html (http://www.unkempt.co.uk/fb2k/foo_podcatcher.html)
This has fixes for some of the bugs that have recently come up including the one where HiRsch's feed kept trying to re-subscribe. (The feed is badly formed so its unique id kept changing.)
Speech: I've realised that as the download paths are processed for tags you need to escape quotes and parentheses. So your example would need to be entered as D:\My documents\Downloads\Podcasts\This isn''t my best podcast '('but I still like it')'\%filename_ext%
Post by: zilog8 on 2011-02-16 13:01:24
Hey, not that it's a big deal or anything, but I think the download rate calculation is off by an order of magnitude. For example, when I'm downloading a podcast, the rate in the status usually bounces between 6kB/s and 13kB/s. Besides my connection being about 100kB/s, there's also the fact that at these rates a 28MB episode would take like 45 minutes or so to download, yet they always finish in about 5 minutes. Just something odd I noticed, and thought I might as well mention.
Thanks for a great plugin BTW; between this and the ipod-synch plugin, I've been able to kick iTunes to the curb completely
Post by: bbrabant on 2011-02-23 19:43:39
Hello everyone,
I updated to the latest version of podcatcher (0.2.4) and foobar (1.1.3). Now I am unable to resume playback of a podcast after switching to another playlist.
With a previous version of podcatcher (0.1.7.4) I was able to resume playback of the podcast. It would not restart the podcast.
To reproduce this issue:
- start playback of a podcast
- during playback (do not stop) choose a track from another playlist (via double mouse click)
- return to the same podcast (via double mouse click)
- the podcast restarts at the beginning instead of resuming playback where you left off.
Could this issue be fixed. For now I have downgraded to version 0.1.7.4.
Greetings,
Ben
Post by: Vittorio on 2011-03-02 09:14:37
Hi, there's something I don't get:
foobar Automatic updater always tells me that there is an update available, although I've downloaded the latest version from http://www.foobar2000.org/components/view/foo_podcatcher (http://www.foobar2000.org/components/view/foo_podcatcher), which currently should be 0.2.4, but since 0.1.7.x I've never seen a stable/final release on the component page http://www.unkempt.co.uk/fb2k/foo_podcatcher.html (http://www.unkempt.co.uk/fb2k/foo_podcatcher.html) e.g. now there only is a beta release foo_podcatcher 0.2.4 (beta)
Where do you get the final ones from ?!?
Post by: Bryter on 2011-03-02 19:20:41
So can i download podcasts, or will they only be downloaded after i play them? If i can download them without playing, how can i do that?
Post by: kalla77 on 2011-03-04 12:55:26
Hi.
I'm trying to get a podcast wich is protectet with a username and password.
The feed adress is: http://audio.zeit.de/podcast/zeitaudio_abo.xml (http://audio.zeit.de/podcast/zeitaudio_abo.xml)
I allready tried to ad my username and pw to the adress like this: http://user:password@audio.zeit.de/podcast/zeitaudio_abo.xml (http://user:password@audio.zeit.de/podcast/zeitaudio_abo.xml)
But then I get the following error:
Unable to open item for playback (Authorization Required (401)):
"https://premium.zeit.de/audio/10_Wissenschaft_dl.mp3?ER_Do=prepareBuyDocument&Abo_Document=/media/11/10/10_Wissenschaft_dl.mp3&Abo_ServerName=horchen.zeit.de"
Do I have a chance to catch the podcast using foo_podcatcher?
Post by: Synthetic Soul on 2011-03-04 13:24:46
That URL just returns RSS for me.
There's no authentication required.
Maybe the answer is to move to the UK.
Edit: Sorry, I see, attempting to access an MP3 from that lists results in an authentication request.  The MP3s are on a different subdomain using HTTPS, which is possibly why authenticating yourself on audio.zeit.de does nothing.
Post by: kalla77 on 2011-03-05 22:02:00
And there is probably no way I can authenticate myself on that https subdomain, right?
Post by: DanielSmedegaardBuus on 2011-03-07 19:04:41
Seems only two people other than me has addressed the fact that video podcasts are ignored
So here's from the few of us: It would be great if podcatcher would download these podcasts as well. Of course, fb2k isn't a video player, but there are a couple of good reasons not to reject unknown media as I see it:
* fb2k kicks ass, as does podcatcher, and having to keep a different app open to retrieve video podcasts just seems like cheating on a beautiful wife with an ogre.
* forward compatibility: plugins may provide functionality that we haven't thought of yet, such as video playback (think xmms/winamp). Is the audio restriction really set in stone, or is it just that we don't have a plugin to handle video media? Or will the next version of foobar2000 natively support video?
* some plugins, like the DTS decoder even demuxes DTS from mkvs to play just the audio part. This makes sense for a wealth of video podcasts that are mostly talk anyway, such as debates, tedtalks, etc.
I don't see any reason to not allow the (stupid/courageous) user to add a non-audio podcast. The XML is the same, and the retrieval also. But then ofcourse, I know nothing of the innards of podcatcher. But from one developer to another, here's a big thank you for making this in the first place, and an echo of "please add video podcasts, too... ooooo... ooooo... oooo..."
Daniel
Post by: foxehoscar on 2011-03-07 20:44:38
Love the plugin. I can't live without it! :-)
I did have a question, though. I read through the forums, and notice a few people asking about sorting. As of the latest version (0.2.4 beta), sorting does work. However, everytime I select a different podcast feed (or even select the same one from the Feed List), the sorting reverts back to oldest first. Is there any possible way to make it default to sorting by newest first? I scoured the options panel, and didn't come across anything. Also looked to see if there were any column options part of foobar2000 itself and couldn't find anything.
Perhaps there's something I'm missing? In any case, keep up the good work. :-)
Post by: tactile on 2011-03-11 10:22:50
I'm having a few problems with saving podcasts.
In the 'Path to store downloaded podcasts (Use Title Formatting)' field I enter the string:
'F:\Jake's Music\Podcasts\%album%\%filename_ext%'
This should correspond to the folder\filename:
F:\Jake's Music\Podcasts\PodcastName\Ep01-foo.mp3
But it is creating the following folder:
F:\Jakes Music\Podcasts\IOT\IOT ep 1 - foo.mp3
For some reason the folder/file creation is ignoring the  '  in F:\Jake's Music\ and creating a whole new branch of folders to store the downloaded files in, starting with F:\Jakes Music\
Is this a simple Title formatting problem or is it a limitation of podcatcher?
Thanks in advance
Post by: Speech on 2011-03-11 11:30:22
Thanks in advance
Your question was already answered on the previous pages.
Post by: tactile on 2011-03-11 12:07:19
Thanks in advance
Solution located here: Post 271! (http://www.hydrogenaudio.org/forums/index.php?showtopic=69053&st=250&p=743240&#entry743240)
tl;dr Use ' to prefix characters that are not being parsed e.g F:\Jake's Music should be written F:\Jake''s Music
Post by: DanielSmedegaardBuus on 2011-03-11 12:39:02
+1
Seems to be not only when selecting another feed, but each time a new episode starts. It's pretty much impossible to listen to a podcast feed back-to-front.
Also, is it possible to manually tag an episode as "listened"? As it is, I have to let the playhead run out before the status is updated automatically, even if the last minute of the podcast is just jingle music or something that should've been trimmed by the publisher in the first place
Post by: Speech on 2011-03-12 12:25:03
I've downloaded v. 0.2.5 today and already noticed a regression (at least it isn't in the change log): you can't move podcasts inside your podcast playlist.  This is annoying, since you don't always want to listen them in the same order they were retrieved.
nausea, could you please fix this bug?
Post by: bbrabant on 2011-03-12 12:47:46
This issue is fixed in podcatcher 0.2.5.
Thank you very much.
Greets,
Ben
Post by: blausand on 2011-04-12 14:18:31
Thanks a lot for the plugIn, it helps my favorite music player to follow me into the new cloudy era...
Again, great work! I will just start a new thread with a great idea! watch out for "waveform bitmap"
Cheers from Cologne,
blausand
Post by: N/A on 2011-04-30 20:41:21
Hi, i want to thank you for this plug-in, really makes fb2k powerful, but i have an issue with it. Im using ESPlaylist and i cant download pod-casts, since the Podcatcher context menu is unavailable. Can you fix it or create an optional short-cut for people with custom play-list components?
Post by: q-stankovic on 2011-04-30 22:33:58
Why don't you ask the developer of the custom-playlist component to solve its bug? How nausea should solve something that is caused by another component?
Post by: blausand on 2011-05-03 00:33:53
New Idea for waveform bitmap now online HERE (http://www.hydrogenaudio.org/forums/index.php?showtopic=88035&hl=waveform+bitmap)!
[blockquote]- including a poll, so make sure you vote for it, folks! Soundcloud's fashion is going RSSable  [/blockquote]
Post by: N/A on 2011-05-05 19:24:08
[quote author=q-stankovic link=msg=754068 date=1304199238]Why don't you ask the developer of the custom-playlist component to solve its bug? How nausea should solve something that is caused by another component?[/quote]
Because i don't know if the plugin is still in development, plus it would be way easier to just press Ctrl+PgDwn to download a podcast, rather than right-clicking through the menus.
Post by: blausand on 2011-06-06 13:08:28
Again, i love it, i love it.
Since i sold my soul for a Samsung Galaxy S2, i need to migrate my podcast adresses to the gadget now.
This is not the first time i wondered why podcast adresses can't even be copied from foo_podcatcher's properties dialog.
Am i missing something, or do i really have to retype the URLs as of now?
I hope you find an hour for improving the properties dialog, or (better) two hours for adding an export functionality for the urls of all podcasts the user has subscribed over time.
cheers and hang loose!
Post by: Speech on 2011-06-08 00:27:05
You can export all your feeds to OPML.  Read the first page of this forum.
Post by: blausand on 2011-06-08 03:37:00
Sometimes i think i get old ) Thanks a lot, ma'm, for bringing a light to the blind.
Post by: Nugstar on 2011-06-11 18:41:47
Hi, thanks for the awesome plugin.
I'm having an issue with this feed: http://www.abc.net.au/rn/podcast/feeds/ss1.xml (http://www.abc.net.au/rn/podcast/feeds/ss1.xml)
It seems there are some errors due to it's most recent update. However, podcatcher seems unable to handle the xml errors and ends up causing a large memory leak (99% ram usage) on my system.
Could you have a look into this?
Thanks,
Nugs
Post by: Mr. Pedantic on 2011-06-11 21:40:05
Just wondering, is it possible to manually add podcasts to a subscribed feed? I have 27GB of podcasts on iTunes, and I don't really want to download them all again. So could I add a feed and get the plugin to scan the folder I set as the download location for already-present episodes?
Post by: Hank H. on 2011-07-04 21:11:32
I'm having huge troubles: When podcatcher (0.2.5) tries to update the feed list, foobar (1.1.7) freezes and becomes unresponsive. I subscribed to about 40 podcasts, I guess. It used to work yesterday...
I found two foo_podcatcher.dll-files inside the foobar configuration folder. One is 831kb, the other 29MB. And of course a foo_podcatcher.dll.cfg plus one more foo_podcatcher.dll in the user components folder. Is this normal?
Also, the opml-export still doesn't work. When I type in a file name and click "save", it doesn't save anything. That's why I don't want to delete the podcatcher config and lose all my subscriptions.
Any idea?
Post by: sylla on 2011-07-09 10:49:04
This is great. Would it be possible in future versions to automatically set the genre of downloaded files to something else?
Post by: kopf on 2011-07-16 02:43:13
Please, for the love of god, make this component be automatically upgradeable from within foobar2000.
Here I was with an old version of foo_podcatcher, which was refusing to properly download some BBC podcasts due to some bugs, and not knowing what was wrong, since I update my components from within foobar2000 regularly. It had never occured to me to go to the official website and upgrade manually, which I now did, and everything's running smoothly.
There's no need for that.
Post by: Fibonacci on 2011-07-25 07:39:28
Hi. I'm using podcatcher 0.2.5 Beta with foobar 1.1.7 and when I open the feed Manager the application just crashes! I think it's because of a specific feed but I'm still unable to remove it from the manager because of the crashes... Any help?
Post by: Helgi on 2011-08-03 22:59:05
Does anybody know why podcatcher is no longer able to download podcasts from this feed: http://minnesota.publicradio.org/tools/pod...s/top_score.xml (http://minnesota.publicradio.org/tools/podcasts/top_score.xml)
When I try to download it with podcatcher I get a popup saying "Error downloading podcast."
In the console it says:
Podcatcher: Downloading podcast item 'http://download.publicradio.org:80/podcast/minnesota/classical/programs/2011/08/03/top_score_20110803_128.mp3
' to 'file://C:\Users\Helgi\Music\Podcasts\Top Score with Emily Reese - Minnesota Public Radio\top_score_20110803_128.mp3_'
Podcatcher: Error opening 'http://download.publicradio.org:80/podcast/minnesota/classical/programs/2011/08/03/top_score_20110803_128.mp3
' for reading (Bad Request (400))
Post by: Robertina on 2011-08-06 18:20:07
Maybe the Podcatcher component can't handle the appendix that seems to be added to the mp3 download addresses? Subscribing to the Top Score podcast with Opera, the episode's article says
Download:
http://download.publicradio.org/podcast/mi...0110803_128.mp3 (http://download.publicradio.org/podcast/minnesota/classical/programs/2011/08/03/top_score_20110803_128.mp3)
After the download from this URL, Opera's Downloads Window however states (appendix = ?_kip_ipx=191366326-1312645280):
http://download.publicradio.org/podcast/mi...6326-1312645280 (http://download.publicradio.org/podcast/minnesota/classical/programs/2011/08/03/top_score_20110803_128.mp3?_kip_ipx=191366326-1312645280)
Post by: Helgi on 2011-08-10 01:09:53
Whatever it was it doesn't seem to be a problem anymore.
Post by: godrick on 2011-08-19 00:46:37
Love this component, but having trouble with podcast downloads that are interrupted for whatever reason.  I find that for partially downloaded subscribed podcasts, I am currently restricted to just listening to whatever I caught on the first download attempt.  I cannot find a way to resume or re-download a partial download of a subscribed podcast other than manually going to the podcast website, finding the specific individual partial podcast, and individually downloading that.
I'd love to have a way to have subscribed podcasts recognize that a podcast was not completely downloaded and give me another shot at fixing it.  Any suggestions?  thanks
Post by: kopf on 2011-08-30 18:18:58
Any chance we could have foo_podcatcher apply per-file replaygain automatically upon downloading podcasts?
Seems like a no-brainer to me...
Post by: yao on 2011-09-01 17:30:57
Is there any way to make the interrupted broken files redownload automatically? I often loose connection to the net and many files do not come in full form, I only find it out when I try to listen to each one and redownloading one by one when discovering it come broken is really the worst option. Thanks for the help!
Post by: godrick on 2011-09-22 23:53:11
After trying to download subscribed podcasts for a while, I'd like to request the following enhancements:
- correctly recognize when a download is partial or complete
- upon interruption or erroring of a download before completion, resume download from the point of error or interruption rather than start over
- upon interruption or erroring of any download, proceed to the next item in the queue rather than also erroring out (wiping out) the entire queue
- if wiping out the entire queue upon any download error cannot be avoided, then automatically refresh feeds and create a new queue without having to exit Foobar.
Glad to clarify any of the items above.  Thanks for this component!
Post by: Hank H. on 2011-10-06 13:25:41
Why is it that the seekbar is disabled when playing a podcast as a stream directly from the internet? As far as I remember, this used to be different...
Post by: Hank H. on 2011-10-13 10:41:19
Also, there is a duration shown in the playlist before a file is played. However, the info vanishes as soon as playback starts, then, there's no %playback_time_remaining%. Am I missing something?
Post by: halabund on 2011-10-19 16:04:35
Recently every time I start foobar2000, it maxes out the CPU and does so much disk access that my computer practically stops.  I found that it's because of foo_podcatcher.  This problem makes it quite inconvenient to use the program.
I have version 0.2.5, and these days I mostly use foobar2000 for podcasts (not music), so I don't start it up very often.  I have 10 podcast sources added (it sounds like a lot, bust most of them don't update frequently).  I have had this setup for a very long time so there are lots and lots of already downloaded podcasts.
EDIT:  Is podcatcher simply not able to handle this much?  I have now removed those podcasts I don't listen to frequently and removed all but the smallest auto-playlists (in the all-feeds playlists there were ~1400 items, thanks to some frequently updated one-minute podcasts).  Hopefully this'll fix it.
Post by: aleangel14 on 2011-10-20 10:00:33
Hi, I installed this plugin in my foobar player but I can not add any feeds. When I go to "View-> Library-> handler podcast feed", I can click only create a playlist but does not add anything. What's wrong? I use foobar v1.1.8 & Xch4nge.
Post by: Sebert on 2011-10-26 11:38:53
Just use File => Subscribe to Podcast Feed
Has anybody heard from nausea ? I tried to contact him, but so far he hasn't reacted !
Post by: moosix on 2011-11-28 19:43:42
As erst of the users I must admit that it's a damn good plugin, my congrats.
Nonetheless I've got one RFC : add an option to edit feed General data, like Author, Title, ... and especially Image and Offline Image.
The reason behind it is because some podcasts do contain an invalid URL to their logo or too long names etc.
like: http://www.ninjatune.net/solidsteel/rss.xml (http://www.ninjatune.net/solidsteel/rss.xml)
J
Post by: yao on 2011-12-07 16:45:00
Hello,
Is the development and bug fixing of this nice component completely dead?
Is there any way to contact its creator nausea? Does he responded to anyone anywhere?
It would be wonderful plugin if the problems mentioned in previous questions will be solved, but I have a fear the project is now unfortunately dead and  if so, does anyone knows any alternative way for integrating podcasting with foobar?
Thanks so much
Post by: Прон on 2011-12-10 21:03:10
There is one barrier to me switching full time to foobar and this podcatcher app: I need the option to manage my backlog of 'casts. iTunes has the option of setting storage preferences: how long to keep a podcast, how many to keep, and so on. Without that, I'm quickly swamped.
I've been through the backlog of posts and didn't see anyone else asking about this. If I missed something, I'll be glad to hear about it. Thanks.
Post by: Speech on 2011-12-11 08:44:01
Try it; everything you ask is there, but you have to set it manually.
Post by: godrick on 2011-12-11 14:06:41
Speech, I'm also interested in features that control how long to keep a podcast and how many to keep, but I can't find those settings.  Could you please point out where they are?  thanks
Post by: Speech on 2011-12-16 16:12:03
Foobar properties / Tools / Podcatcher / Time range
or settings for individual feeds:
View menu / Podcatcher Feed Manager - double click on the feed you are interested in changing
I hope this helps; this is all podcatcher has for now.
Post by: godrick on 2011-12-16 17:13:26
@speech: I'm aware of those settings, so I'm confused: in post #317 you stated that the retention features requested in post #316 were present, but in post #319 you seem to acknowlege that podcatcher only has what amount to download options and none of the retention features you previously stated to exist.
What am I missing?
Post by: plissk3n on 2011-12-22 15:05:54
What am I missing?
I think when you set the option for example at 1 month it will download all the podcasts which are published within the last month and when the time goes bye it will delete every podcast which is older than one month.
When you configure your podcatcher you could configure all your podcasts that they would be downloaded exactly to the path were you have them saved allready. Also the filename has to match!
When this circumstances are given foo_podcatcher will ask you if it shall download the file again and replace the old file or just take the old file and import it to your podcasts.
It's a bit complicated and you have to click for every single podcast on "No" when you are asked if it's shall replace the file but you don't have to redownload the files.
I've got the same problem while using ESPlaylist. Did you found a solution?!
I've got also another question. I am listening to this podcast: http://distrikt.podomatic.com/ (http://distrikt.podomatic.com/) which I can highly recommend to electro/techno fans. In foobar I add http://distrikt.podomatic.com/rss2.xml (http://distrikt.podomatic.com/rss2.xml) to my podcasts. But there are only the last 15 Podcasts in the feed. The old ones are in this feed: http://distrikt.podomatic.com/archive/rss2.xml (http://distrikt.podomatic.com/archive/rss2.xml)
Since they are both called the same ("Distrikt") They are stored in the same folder. It is possible to join them also in foobar to one?
Greetings
Post by: godrick on 2011-12-22 18:50:42
Have you directly observed this behavior, or are you speculating?  I've not observed such behavior, nor would I logically expect such from the description of that setting, which specifically only mentions "downloading".  thanks
Post by: plissk3n on 2011-12-22 19:31:57
Since I've got only one podcast which I set to keep to "All time" I am only asuming it. Will try it and let you know ;-)
I think the words:
are very clear.
Greetings
Post by: Azevedo on 2011-12-28 17:58:30
Hey everyone!
I'm trying to dock/embed podcatcher into columns ui interface but it won't give me the podcacther panels into columns ui layout config.
Is it possible?
Post by: yo-less on 2011-12-28 20:40:28
Hi everyone. Love the plugin!
I have a feature request of my own, or maybe this is already possible somehow but I simply haven't realized it yet...
Would it be possible to somehow prevent some of the files from a podcast from being downloaded? I have several podcasts I have subscribed to and they sometimes have episodes I'm really not interested in. So would it be possible to exclude them with some kind of filter (E.g. exclude episodes starting with "week in review" or other labels)? People could then maybe also prevent episodes that are too large from being downloaded and so on.
This is a feature that no podcatcher out there seems to have, so maybe this would be another reason for people to switch over to foo_podcatcher... . I have no programming expertise but if this is doable without much effort I would love to see it implemented.
Also as far as I can tell it is so far not possible to sync the downloaded files with an mp3 player, right?
Post by: plissk3n on 2012-01-09 10:53:34
I think the words:
are very clear.
Greetings
Sorry I was wrong, it doesn't delete old podcasts. Plese insert this feature or explaine us what we are doing wrong :?
Post by: yao on 2012-01-11 15:41:49
Hello, is there any chance to find out whether this plugin was abandoned by its author Nausea? It seems that for almost a year now he is not responding to any questions neither did he appeared on the forum since last February. Does anyone know whether the project is already dead?
Thank You
Post by: mmmm on 2012-03-20 13:11:03
I would like to see the ability to select a number of entries that are downloaded, eg last three episodes, instead of the periodical selector.
An auto-delete function, eg keep last three episodes, would also come in handy.
I'm currently using firenze to aquire my podcasts (http://code.google.com/p/firenze/). Check it out if you're searching for an alternative.
Post by: Sebert on 2012-03-23 15:34:01
Yes, apparently this project is dead. Nausea as a developer seems to be gone for good, I hope he is alright and that nothing has happened to him.
I've recently uninstalled foo_podcatcher because of various problems (double/triple entries, huge archive).
I use media monkey now to download & manage my subscriptions & combined with an "Album List" panel in Foobar2000 dedicated for my podcasts.
Post by: DrGerm on 2012-05-28 02:25:31
I try adding the following, and nothing happens. Nothing shows up, downloads, etc. Is it because the feed requires a username and password?
http://rss.premiereradio.net/coast/podcast.xml (http://rss.premiereradio.net/coast/podcast.xml)
Post by: thecircusfreak on 2012-05-28 15:53:13
probably
you could try adding the feed in this manner, it might work:
http://username:password@rss.premiereradio...ast/podcast.xml (http://username:password@rss.premiereradio.net/coast/podcast.xml)
Post by: Sebert on 2012-10-18 10:23:38
I managed to contact nausea, and asked him if the project was truly dead, this this what he told me:
Nausea/Mr Unkempt wrote
Not sure if it's dead, but I haven't worked on foo_podcatcher for a bit now. I've worked on this though: https://t.co/Ue0VaHe3 (https://t.co/Ue0VaHe3)
I asked him if he could make an "official" statement here in this topic, but unfortunately he never annswered me again.
There is an email adress on the Google Play page above. Maybe he'll react/answer if enough people write him !
Post by: Narwhalsmustdie on 2013-01-02 01:44:27
I recently tried to download a couple podcasts with foobar2000 and it recognized them, but when I went to download one it just gave me an error that said Error downloading podcast. Is there something I can do to change this?
Post by: the1nnovator on 2013-01-26 14:24:30
Great plugin!
It would be also very useful if you added a feature of automatic download of all podcasts whose download wasn't finished during the previous run of foobar2k.
One more question: is it possible to create a column in podcatcher's playlist (using syntax commands) that will represent podcast status in playlist, i.e. using %status% command or something like this?
Post by: blausand on 2013-03-01 01:40:39
Hey there!
After promoting foo_podcatcher as the most elegant solution and installing it on any student's machine, i have to say today:
What worth is a podcatcher that is not able to receive a .m4a stream?*
For those i'm better off using the browser's HTML5 abilities (and following the podcast clicking the shownotes on the podcast's homepage).
On the other side, foobar fails for my need of connecting with my one and single media player to the emerging streaming services like jamendo or jango, stripping off the unwanted webpage content.
And so foobar as a whole loses a lot of ground these days.
* e.g. Chaos Radio Express (http://cre.fm): .m4a, 44.1kHz Stereo AAC SBR 48kbps
Post by: roughnecks on 2013-12-11 16:03:09
Hello,
I was trying to download some music from this podcast hosted at archive.org: http://mcastmusic.wordpress.com/feed/ (http://mcastmusic.wordpress.com/feed/)
Problem is the following:
Podcatcher: Downloading podcast item 'https://ia801000.us.archive.org:443/34/items/Nova-RadicalMinorShock/RadicalMinorShock.mp3' to 'file://K:\Podcast\m_cast radio\RadicalMinorShock.mp3'
Podcatcher: Error opening 'https://ia801000.us.archive.org:443/34/items/Nova-RadicalMinorShock/RadicalMinorShock.mp3' for reading (Security error)
Can you help?
Thanks,
Simone
Post by: yiNXs on 2014-12-02 14:53:45
I realize this is likely dead, but I just have to ask this in the off chance it'll ever get picked up again: would you consider making an option to sort the lists in reverse? So the latest podcasts are on top instead of at the bottom on the (usually large) list? It may seem like a small thing, but it makes keeping track of updates (per subscription) so much less of a hassle.
Post by: LL25255252 on 2014-12-14 14:19:30
Here's what you can do:
Create autoplaylist with this query pattern:
%path% HAS _Radio_Shows SORT DESCENDING BY "$date(%added%)",SORT BY %title%
"_Radio_Shows" - replace it with your own directory of podcasts.
For %added% - added date -  you need to install Playback Statistics 3.0.2 plugin (if you don't have it already).
http://www.foobar2000.org/components/view/foo_playcount (http://www.foobar2000.org/components/view/foo_playcount)
Post by: karasuhebi on 2015-05-29 19:24:27
Is there a way to make this component delete files that are older than X amount of days?
Post by: i2087426 on 2016-01-01 08:04:43
Is there anyway to get the source code for this? Would love to start a new project for podcasts.
Title: Re: foo_podcatcher
Post by: yurithedragonhalf on 2019-01-05 18:39:54
Ok what am I doing wrong I have it all set up but it's not downloading anything?
