Hydrogenaudio Forums
Lossless Audio Compression => WavPack => Topic started by: dobz on 2006-03-21 00:24:38
Title: wavpack codec_profile =
Post by: dobz on 2006-03-21 00:24:38
After encoding my files with wavpack high extra (-hx) it does not show the "Extra" after the codec_profile =
This used to show as expected in 0.8.3 but no longer does in 0.9 and it is a rather usefull indication, its nice to see how much more im able to squeze out of my older wavpacks which play on my rockboxed iriver h140
samplerate = 44100
channels = 2
bitspersample = 16
codec = WavPack
bitrate = 908
codec_profile = high Extra is missing here
encoding = lossless
md5 = A03C5D8CF9891E461AD9BC330F428060
tagtype = apev2
cue_embedded = no
8965236 samples @ 44100Hz
File size: 23 077 742 bytes
Post by: Duble0Syx on 2006-03-27 00:55:55
Not only is it missing that info it is also missing the "version=" & "format=" strings.
0.8.3
samplerate = 44100
channels = 2
bitspersample = 16
format = Integer
codec = WavPack
version = 4
bitrate = 708
compression = Lossless, High, Extra
original MD5 = 145abd102132bd62c1f4243ed55952ef
0.9
samplerate = 44100
channels = 2
bitspersample = 16
codec = WavPack
bitrate = 708
encoding = lossless
md5 = 145ABD102132BD62C1F4243ED55952EF
tagtype = apev2
cue_embedded = no
12705504 samples @ 44100Hz
File size: 25 511 024 bytes
Although I do like how replaygain is shown now and that it tells what tag type is used.  Would be nice to see this fixed in future versions, even if it is a minor detail.
