Hydrogenaudio Forums
Lossy Audio Compression => AAC => AAC - General => Topic started by: tHe_BiNk on 2001-10-25 12:35:46
Title: latest winamp(2) plug-in FAAC
Post by: tHe_BiNk on 2001-10-25 12:35:46
http://home.wanadoo.nl/~d.binken/ (http://home.wanadoo.nl/~d.binken/)
see dir for more info
Post by: john33 on 2001-10-25 14:03:52
Thanks ...... that works a treat!
Seeking and, unless I am imagining things, a significant boost in sound quality too?
john33
Post by: menno on 2001-10-25 14:48:32
how old was the version you used before? There hasn't really changed much to the actual library lately.
Menno
Post by: tHe_BiNk on 2001-10-25 15:22:26
It seems the display vbr does not work properly
on my win2000 + winamp v.2.76 system.
It goes up 97 -> 127 -> 128 -> 130 -> 132 and than
it stays there, but it does not go down, it this normal????
mp3 vbr goes 96 -> 128 -> 196 -> 160 -> 96 -> 256
Post by: bladeraptor on 2001-10-25 15:54:21
Thanks for this menno,
I really enjoy having the tagging support for AAC now through Winamp and the accurate track timings - the only problem is I will have to keep a copy of Ivan's plug-in to play some of the older files encode with the sub v.1 of the Psytel encoder. I ran through my PC today to dig up all my AAC files and check them in Winamp. Unfortunately in many cases the FAAD plug-in reports back 0.00 for the older files and won't play them whereas the old Ivan plug-in will play them happily and the latest files as well (although without the tagging support or correct time display) Will there be a resolution of this or should I just hold onto the older plug-in for now?
Regards
Bladerapotr
Post by: menno on 2001-10-25 15:58:44
the_bink:
about that bitrate display, I think I have the same problem too. But it's not code that I've written, I can look into it of course. If I can't find the problem I'll contact RageAmp t fix it, it was his coding.
bladeraptor:
If you mail me one of those file ( < 1.0 mb) or have some other way to get one to me, I'll see what I can do.
Menno
Post by: tHe_BiNk on 2001-10-25 16:23:45
The incorrect display of the vbr is not a real problem for me,
but you fanatic coders always want perfection.
Sound it what matters and that is near perfect (near cd quality).
Post by: john33 on 2001-10-25 16:45:53
menno
It was the build of 6 October.
john33
Post by: menno on 2001-10-25 16:50:16
OK, don't think I changed much that could affect the quality, since then.
Post by: Thor on 2001-10-25 17:54:37
Now can anyone upload some aac files so i can test this shiz?
don't feel like encoding
Post by: tHe_BiNk on 2001-10-26 12:53:46
Bug, when you turn on "buffer entire files into memory", it
loads all song into memory, so 1 cd makes winamp
require around 128mb........but when you reselect a song which
was already loaded into memory it adds it into memory
again?????
Resulting into the fact that every song played gets added into
memory, play the cd 4 times -> 4x128mb!!!!
btw you need to turn on the function and than restart winamp
to get it working.
Post by: menno on 2001-10-26 12:59:21
Hmmm, ok, I'll have a look at it. It shouldn't be possible that it loads all files into memory, that's only done when the play() function is called. Maybe winamp does that for some stupid reason, but I can't imagine.
Anyway, I'll check it out.
Menno
Post by: tHe_BiNk on 2001-10-26 13:26:30
It does not load them all at ones, but WinAmp keeps adding
every song that it plays even those it already added, so
if you replay a song 4 times it gets added 4 times to memory
and stays into memory, consuming 4 times the amount of memory.
btw this is the best forum to post bugs, right?
or do you prefer the (empty) http://sourceforge.net/projects/faac/ (http://sourceforge.net/projects/faac/)
or other forum?
Post by: menno on 2001-10-26 13:36:05
Bugs should be posted on the development page of http://www.audiocoding.com (http://www.audiocoding.com), you'll see how to when you get there.
Never mind adding this bug, I already fixed it :-)
I did forget to free the buffer where the file was read into. Beginners mistake :-)
Menno
Post by: tHe_BiNk on 2001-10-26 13:50:54
Thanx, what a good realtime service (M$ take a hint) LOL
Post by: TrNSZ on 2001-10-26 14:09:30
[deleted]
Post by: tHe_BiNk on 2001-10-26 14:25:37
ha-ha, we were both listening to Duran Duran.
Post by: ciber-fred on 2001-10-27 11:38:14
very cool stuff this url... is winamp3 plugin is build ?? i don't see the zip file for winamp3..
