Hydrogenaudio Forums
Hosted Forums => foobar2000 => Uploads - (fb2k) => Topic started by: anathema on 2004-01-21 02:53:38
Title: fuzzy fonts in foo_looks
Post by: anathema on 2004-01-21 02:53:38
sorry if this has been brought up before, but.. what's going on?
Post by: tk32 on 2004-01-21 03:00:52
you can set how you want text to be rendered in the ski file
either as a global, or for each sprite
like this:
section globals
int texthint texthint.AntiAlias
sprite artistfield
the choices are:
texthint.SystemDefault - default
texthint.SingleBitPerPixelGridFit
texthint.AntiAliasGridFit
texthint.AntiAlias
texthint.ClearTypeGridFit
- Windows XP only
you can also use numeric references 0-5 where 0 = system default, eg.
int texthint 4
is the same as
it's best to try out the different styles until the text is rendered how you like it
if you're still confused, i'll make a screenshot showing the different renderings
Post by: anathema on 2004-01-21 03:06:06
thanks for the quick response!
adding "int texthint texthint.SystemDefault" did the trick. are you sure it's set as default?
Post by: tk32 on 2004-01-21 03:07:44
hmm
to be honest, no - i'm not sure
but i'm glad it is better now
Post by: anathema on 2004-01-21 03:17:10
uh oh..
when I change the text rendering method, my right-aligned titles don't line up correctly.
Post by: tk32 on 2004-01-21 03:18:08
is it a single sprite
or 3 seperate sprites
attach the look/code
Post by: anathema on 2004-01-21 03:20:10
three separate.
section globals
list statemap states.None
list fontcolor color.black
int fontsize 8
int fontstyle fontstyle.Regular
string fontname "Verdana"
int halign 2
int texthint texthint.ClearTypeGridFit
sprite artistInfo
list rect int { 0 25 390 15 }
string fspec "%artist%"
sprite titleInfo
list rect int { 0 41 390 15 }
string fspec "%title%"
sprite albumInfo
list rect int { 0 57 390 15 }
string fspec "%album%"
Post by: tk32 on 2004-01-21 03:22:37
for a start, it best to use
int halign align.far
makes more sense than 2
let me see
can you attach the ski & graphics?
btw, i think AntiAlias is the default texthint
Post by: anathema on 2004-01-21 03:26:22
there aren't really any graphics.. I'm just trying to make something to go in the corner of my desktop to show album art and track info. here's the ski though.
Post by: tk32 on 2004-01-21 03:29:36
doh
just remembered win2k doesn't support 'cleartype'
it seems there is a problem with right-aligning cleartype text
one second...
Post by: anathema on 2004-01-21 03:30:39
it has the same problem if I use SystemDefault, if that helps you out.
Post by: tk32 on 2004-01-21 03:35:06
yes..
well, your system default seems to be cleartype too (XP is cleartype by default)
if you go to windows properties > appearance
i bet you will find cleartype enabled
ok - it aligns perfectly when the render type is not a grid fit
all of the grid fit render types misalign in right-align mode
the non-grid types are:
texthint.AntiAlias
test you skin with these render modes
i think you will find they line up correctly
Post by: anathema on 2004-01-21 03:39:49
hmm.. all of the "GridFit" options align poorly for me. weird.
well, maybe I'll just move to a different corner.
thanks for all your help.
edit: by the way, how would I go about having multiple lines in one sprite? maybe that would solve the problem.
edit2: never mind.. figured it out and that worked!
Post by: tk32 on 2004-01-21 03:44:50
there's currently no way to perform a 'carriage-return' inside a string
it simply spills over to the next line when it is too long in 'noclip' mode
i don't recommend this because you will have no control over which line the fields appear on
forget i ever mentioned it  - perhaps in a future version
edit: what do you mean figured it out? show me
Post by: anathema on 2004-01-21 03:45:45
actually using $char(13)$char(10) for line breaks seems to be working for me.
Post by: tk32 on 2004-01-21 03:46:25
really??!
wow - they used to get ignored by the parser
i never tried them in recent builds
now you've taught me something
Post by: anathema on 2004-01-21 03:49:33
haha, well now we're even.
edit: really? it's working fine for me now.
Post by: tk32 on 2004-01-21 03:53:36
yes - it is
sorry
it's because i'm using win2k
i have to use a little imagination to approximate how the cleartype will be
glad you go it sorted out
string fspec "$trim(%artist%$char(10)%title%$char(10)%album%)"
this is what i used
good teamwork btw
Post by: tk32 on 2004-01-21 04:00:16
one more 'tip'
in your text sprite, put
bool enabled false
that way it ignores mouse input, so you can still drag the look, even when over the text sprite
obviously, if you are planning to make the text clickable or something, then don't disable it - just thought it might be useful for you if this is just gonna be a display look
edit: good night - i need some sleep zzZZ
Post by: anathema on 2004-01-21 04:02:49
if you don't mind my asking a couple more questions..
1) how can I display the album art of the currently playing song rather than the currently selected song?
    edit: never mind about this one, figured it out
2) is there a way to pin a look to the desktop so that it isn't brought to the front when clicked?
Post by: tk32 on 2004-01-21 04:04:15
i'll answer these questions tomorrow, ok
perhaps danZ might even beat me to it
sorry - it's 4:00am here in London
Post by: anathema on 2004-01-21 04:05:56
awesome, thanks again for being so helpful. sorry to keep you up.
Post by: danZ on 2004-02-02 16:30:50
default text attributes are
antialiased
bold
tk32 has you covered on how to customize it all...
