Hydrogenaudio Forums
Lossless Audio Compression => Lossless / Other Codecs => Topic started by: man on 2003-10-02 13:03:38
Title: Monkey's Audio DirectShow Filters
Post by: man on 2003-10-02 13:03:38
Hi there,
I'd like to play Monkey's Audio file with WMP9  . I found the two following DirectShow Filers :
dsp-worx (http://dsp-worx.de/index.php?pg=projects&tid=18)
Ingo Ralf Blum (http://mt.physik.uni-freiburg.de/~ingo/)
They are both working, ie. *ape can be played with WMP, BUT none of them seem able to transmit Tag infos to the player, whatever the Tag format used with the monkey files is (APEv1, APEv2 or ID3v1).
Is there a way to make this working, especially with APEv2 tags (that's the native monkey tag format since 3.98a1 and my usual player is foobar) ?
Thanx very much in advance for your help.
Edit 1 : pb with urls corrected.
Edit 2 : additional info : I'm running Win2k.
